      01-08-2009, 08:45 PM   #1
reRESERVEDFX
(oO (||||) (||||) Oo)
reRESERVEDFX's Avatar
Drives: 06 BMW Z4 3.0i 03 BMW M5 DINAN
One Touch Blink Signal
Hey
I learned at my dealership that they could not turn on the one touch/three blink indicators because its not available in ANY Z4. It's a huge inconvenience for me since I really got used to it. Anyone knows a way around it? Some retrofit perhaps?
And one more thing. When I had my loaners 09 528i and 09 x5 3.0si, I realized that whenever u turn the wheel during standstill you can clearly see Adaptive Xenons rotate towards the corner. However I could not see that in my 05 Z4. Does that mean Z4's don't have Adaptive Headlights?
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red
      01-08-2009, 08:52 PM   #2
jragan
Imola Lover
jragan's Avatar
06-08 model year (corrected from "All" based on info from GP20) Z4s have the option to enable the one-press=three-flash. (Although I wish it did four instead of three...I drive fast but change lanes slowly )
Z4s only adjust the lamps vertically. They do not move horizontally with steering changes.
Hers: 997-1 C4S: Pics
      01-08-2009, 08:54 PM   #3
reRESERVEDFX
Even the new ones with "dual xenons"? (sorry, that's how I call the new ones with two lenses instead of one ) Well then I will have to go and see a different dealer.
      01-08-2009, 09:07 PM   #4
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Originally Posted by jragan View Post
All Z4s have the option to enable the one-press=three-flash.
Only facelifted Z4's have that feature. Can't be enabled on '03~'05 Z4's.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      01-08-2009, 09:09 PM   #5
jragan
Imola Lover
jragan's Avatar
I stand corrected, then. Thanks for the additional info!
      01-08-2009, 09:10 PM   #6
GP20
Originally Posted by reRESERVEDFX View Post
Hey
What model year is your Z4? Your sig says '06 and you mentioned '05 in your post. And space gray didn't become available until '08. The one-touch turn signal feature can only be enabled on '06~'08 Z4's.
2016 BMW M3
2008 BMW Z4M coupe
      01-08-2009, 09:11 PM   #7
reRESERVEDFX
05, I will correct that in a second. I will take the picture of the color tomorrow morning. Do you guys know any way around it maybe?
      01-09-2009, 11:49 AM   #8
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
If it's an '05, it's Sterling Gray (has a bit of a red undertone to it). In '06-07 it was changed to Silver Gray, which is what I have. Then in '08 it became Space Gray.
As for the lights, you can double check with your dealer but likely the other guys are correct and it's not an option on your model year.
      01-09-2009, 04:00 PM   #9
CalRick
Drives: '15 M235 & '95 M3 tracktoy ;
2016 X3 Xdrive28d  [0.00]
2015 BMW M235i  [0.00]
1995 BMW M3  [0.00]
It should be available on your 06, though many of the dealers don't know it and/or they don't bother looking for it when they do the setup.
Since I had heard of the feature on one of these boards (and it's listed in the owners manual,) I asked mine to do it when I first got my 07 and was having the DRLs initiated and they told me the same line you were getting - not available on E85/6s. I read more about it on these boards - somewhere there is a FAQ that has the setup table of all the available defaults and settings (check bimmerfest and bimmerforums as well, it's in there somewhere) - and hit them up for it again when I took it in for its annual oil change and they had no problem doing it this time.
      01-09-2009, 07:08 PM   #10
AtoB
AtoB's Avatar
Drives: Z4M
my wife '3' has it, it's a smart feature, i'd love to have it done to my 06.
      01-10-2009, 12:55 AM   #11
TopDown
TopDown's Avatar
Drives: 2017 G30 540i M Sport
I had my Z4MR programmed at the dealership. It's a one-time free service where you bought the car, otherwise the dealership can charge you. BTW, I also had them enable the daytime running lights, which on the Z4 is so dim that it's barely noticeable.
Mine
G30 540i M Sport
Hers F36 440i Gran Coupe
      01-10-2009, 09:53 AM   #12
AtoB
AtoB's Avatar
Drives: Z4M
so did you just ask your service advisor if they could program the 'One Touch Blink Signal' function to your car? and that was it?
A
      01-10-2009, 10:21 AM   #13
jragan
Imola Lover
jragan's Avatar
A
See here: http://www.bimmerfest.com/forums/sho...6&postcount=12 as to the available options. Although, as stated earlier, some options may only be available on later models.
Also keep in mind that if the dealer is wanting to charge you an arm and a leg to perform this, you can always go to a private BMW shop who will be much cheaper. Since the e85/e86 use the "older" computer, most private shops will have a terminal that will be able to program it.
      01-10-2009, 10:25 AM   #14
TopDown
TopDown's Avatar
A
First took my car to a dealer that was closer to home to have 1200 mile service performed. While there, I asked if they could program. SA said they could, but because I did not purchase car there they would have to charge me. Went on to explain that it's a one-time freebie where you purchase the car. Following week I took it to the dealer where I bought it, asked SA they could program, and he said sure. SA confirmed the one-time freebie policy.
Mine
G30 540i M Sport
      01-12-2009, 07:48 AM   #15
AtoB
AtoB's Avatar
Drives: Z4M
thanks guys! i'm going to give it a shot next time my car goes in.
my buddy is the head tech at my dealer, so i can press him on it.
      01-12-2009, 08:47 AM   #16
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
180
Drives: Z4M
my stealer asked $70 to activate it. rip-off
      01-12-2009, 03:00 PM   #17
jgorman13
Drives: 2005 Z4 3.0i, 2008 C300 Sport
yea i have an 05 as well. they couldnt do the triple signal activation when i asked. Only the facelifted models. It sucks because my last two cars had the feature and i got really accustomed to it
