03-17-2016, 09:57 PM | #1 |
Rep 115
Fresh set of VMRs arrived today - WITH PICS
After waiting over a month for VMR to finish powder coating a set of v721s, they finally arrived today at long last. I will have some mounted pics posted here soon. Super stoked with how these turned out!
03-18-2016, 08:51 AM | #3 |
Rep 904
03-18-2016, 10:06 AM | #4 |
Rep 115
Haha I had some difficulty removing the stock wheels and thought I'd try some prying. Never seen wheels stick so tightly to the rotor after the lugs have all been removed. Obviously I would use a different tool when removing my new VMRs.
03-20-2016, 05:58 PM | #7 |
Rep 439
Nice! The color is subtle and works really well with the black.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
03-21-2016, 08:57 AM | #9 | |
Rep 904
BTW, why does your front end look lowered, but the rear looks like stock height? Wheels looks great otherwise! They don't stand out as much as I thought they would. |
03-21-2016, 02:19 PM | #12 |
Rep 25,989
Those turned out beautifully! I love it! Don't forget to post in the Show Off Your VMR Wheels thread!
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
03-21-2016, 10:35 PM | #13 |
Rep 115
Thanks guys! I hear what you're saying about the stance difference between the front and the rear. There seems to be a ton of extra space in the back, but up front the stance is near perfect. VMR recommended a size 30 sidewall for the rear, and a 35 up front, which is likely the reason for the difference. I could easily fit a 35 in the rear and it would look a lot better than the 30 IMO.
03-21-2016, 10:41 PM | #14 |
Rep 115
03-22-2016, 10:55 PM | #17 |
Rep 2,874
With 235/35/19 in the front, you should of went with 265/30/19 in the rear to be more closer in rolling circumference to the front. 255/30/19 is slightly smaller in rolling circumference compared to the 235/35/19 front. If it doesn't rub, I would do 245/35/19F and 275/30/19R to get rid of that stretched tire fitment. 245/275 are perfect for an 8.5/9.5 wide wheels.
03-22-2016, 11:03 PM | #18 | |
Rep 115
03-23-2016, 12:40 AM | #19 |
Rep 2,874
30% of 265mm is approximately the same sidewall height as 35% of 235mm. 35% of 265mm or 255mm would make the rear sidewall taller than the front sidewall - although, this would fill in the wheel well a bit more, but it would also increase your rake (rear end being even taller). It's also best to keep the overall rolling circumference as equal as possible (same sidewall heights) front and back to keep all the electronic nannies happy.
03-23-2016, 11:14 AM | #20 | |
I plead the 5th.
523
Rep 1,519
255/30/19 255mm (width) * .30 (profile) = 76.5mm thick sidewall. From there you can calculate the total outer diameter by multiplying the sidewall thickness *2 and adding in whatever wheel diameter (in millimeters) you're using. There are 25.4mm in one inch, so you multiply the wheel diam by 25.4 to convert to mm: 2(235*35) + 19*25.4 = 647.1mm outer diam (or 25.48") 2(255*30) + 19*25.4 = 635.6mm outer diam (or 25.02") - 1.78% difference from fronts compared to 2(255*35) + 19*25.4 = 661.1mm outer diam (or 26.03") - 2.16% difference from fronts For what it's worth, I'm guessing they made the recommendations to ensure a rub-free fit. The outer diams are only 1.81% different which is well within the golden rule (F + R should have less than 3% difference in OD). Those rear tires are recommended for wheels ranging from 8.5" to 10" so you should have no issues. Looks good to me but preferences differ. Oh, and if anyone is too lazy to do the math there are a few nifty calculators out there like this -> www.1010tires.com/Tools/Tire-Size-Calculator Many use the calculators but I think it's good to understand why/how things change rather than just knowing the answers, hence the brief explanation above Onto the pics! Are you lowered? If not, plan on it? These things look bitchin', I think the color accentuates the concave on the 9.5" too. Looks way deeper than my 18x10 VMR's, albeit they're a different model. With a drop and OEM rear spoiler I think you would take things to another level, would love to see that combo!
-Matt
03-23-2016, 11:23 AM | #21 |
Rep 115
Thanks Tiltmode, this is all news to me so thanks for the insight!
I'm still on a stock suspension but this will be my next upgrade. I'd like some H&R coilovers, but that will probably have to wait a while. Any recommendations? |
