03-20-2013, 01:53 PM | #1 |
Rep 155
2008 z4 with nav and dsp. ipod interface?
I am looking for an ipod interface that works with my car. Dice seems to be too expensive.
I found USA SPEC PA12-BMW-DSP. I have good experience with USA SPEC product on my old honda. Has anyone tried this product? Does this work with my car? USA SPEC site list only up to 2007 z4 and says nothing about 2008 and later models. What other options do I have if this is not compatible? |
03-21-2013, 12:00 AM | #2 |
Rep 231
If you can find one Intravee II and alpine 420i works great!
03-22-2013, 12:57 PM | #3 |
More of this than that!
29
Rep 817
Here is a good buy.
http://www.amazon.com/DICE-DUO-100-B.../dp/B004I6JR24 or http://www.ipodcarpros.com/iPod/iPho...duct_info.html or http://www.ebay.com/itm/DUO-100-BMW-...item3f1c96c3ba I have this in mine...and it works flawlessly. Good luck.
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
03-27-2013, 12:17 PM | #4 |
Rep 501
Would those work in a 2006 with nav (and what I think is DSP)? Would that allow control/navigation of the ipod with the buttons on steering wheel and on the head unit?
03-27-2013, 12:50 PM | #5 | |
29
Rep 817
However, I have no idea if having NAV also gives you DSP (others can chime in here). As for steering wheel control...yes, I have the DICE and full control using wheel buttons. p.s. Here is one being sold on ebay with DSP module. http://www.ebay.com/itm/Dice-Silverl...item3cd029dcda
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector Last edited by bucko521; 03-27-2013 at 12:55 PM.. Reason: added info: |
03-27-2013, 12:58 PM | #6 |
Rep 501
Thanks. Sorry for the thread hijack but I feel like it's similar enough where I shouldn't make another thread. DSP is that menu where you can choose different audio EQ "presets" right? If so, I believe I have that option. Unless there's a better way to check (like with an option code via VIN search or something).
So if I do have DSP, I could use one of the above kits, but I'd have to buy an i-BMW-DSP module as well? |
03-27-2013, 02:15 PM | #7 | |
29
Rep 817
Yes, same kit, but you need the added module. Gotta say I would be lost without my DICE.
03-27-2013, 09:40 PM | #8 |
Rep 2,557
Intravee II = The best solution
I gotta say, if you have NAV, the Intravee II with alpine 420i and alpine HD radio = total integration. The best but the most expensive. You get what you pay for. This is one bad a$$ device. Check out all the options, especially the extras menu, you can even display the acceleration and deceleration G-forces, max speed, max rpm. on the nav screen. I know someone who is getting ready to return their lease and will be pulling it out before they return their car and will have it for sale.
Intravee_Users_Guide_V6.02-6993.pdf 1. Introduction .................................................. .................................................. ..................................... 1 1.1. User Interface Mode .................................................. .................................................. ................. 1 1.1.1. UI Mode 1................................................. .................................................. ........................... 1 1.1.2. UI Mode 2................................................. .................................................. ........................... 1 1.1.3. UI Mode 3................................................. .................................................. ........................... 2 1.1.4. UI Mode 4................................................. .................................................. ........................... 3 1.1.5. UI Mode 5 & 6 .................................................. .................................................. ................... 5 1.2. Setting the UI Mode .................................................. .................................................. .................. 5 1.2.1. Setting the UI mode with a PC .................................................. ............................................. 5 1.2.2. Setting the UI mode with the head unit .................................................. ............................... 5 2. Single Line display UI Modes 1,2,3 and 4 .................................................. ............................................. 7 2.1. The double key press issue .................................................. .................................................. ........ 8 2.2. Intravee Single Line Menu Reference .................................................. .......................................... 8 2.2.1. Menu Overview .................................................. .................................................. ................. 8 2.2.2. Main Menu .................................................. .................................................. ........................ 9 2.2.3. Source Selection Menu .................................................. .................................................. .... 10 2.2.4. Searching .................................................. .................................................. ......................... 10 Auto Song Search .................................................. .................................................. ........................ 11 Percentage Search .................................................. .................................................. ...................... 11 2.2.5. iPod source specific menu .................................................. ................................................. 11 Source Type .................................................. .................................................. ............................... 11 Now Playing .................................................. .................................................. ............................... 12 Song Search .................................................. .................................................. ............................... 12 Album Search .................................................. .................................................. ............................. 12 Artist Search............................................ .................................................. ..................................... 12 Playlist Search .................................................. .................................................. ............................ 12 Random Mode .................................................. .................................................. ........................... 13 Random Off .................................................. .................................................. ............................ 13 Random Song .................................................. .................................................. .......................... 13 Random Album .................................................. .................................................. ....................... 13 Repeat Mode .................................................. .................................................. ............................. 13 Repeat All .................................................. .................................................. ............................... 13 Repeat Song .................................................. .................................................. ........................... 13 2.2.6. CD Changer source specific menu .................................................. ...................................... 13 Source Type .................................................. .................................................. ............................... 13 Now Playing .................................................. .................................................. ............................... 14 File Search .................................................. .................................................. .................................. 14 Folder Search .................................................. .................................................. ............................. 14 Random Mode .................................................. .................................................. ........................... 15 Random Off .................................................. .................................................. ............................ 15 Random Folder .................................................. .................................................. ........................ 15 Random Disc .................................................. .................................................. ........................... 15 Repeat Mode .................................................. .................................................. ............................. 15 Repeat Off .................................................. .................................................. .............................. 15 Repeat Track .................................................. .................................................. ........................... 15 Repeat Folder .................................................. .................................................. .......................... 15 Repeat Disc .................................................. .................................................. ............................ 15 Intro Scan .................................................. .................................................. ................................... 15 Disc Select .................................................. .................................................. .................................. 15 Track/Folder Selection Mode .................................................. .................................................. ...... 15 ii 2.2.7. DAB Tuner source specific menu.............................................. ............................................ 16 Source Type .................................................. .................................................. ............................... 16 Now Playing .................................................. .................................................. ............................... 16 Presets .................................................. .................................................. ....................................... 16 Preset Bank .................................................. .................................................. ................................ 16 2.2.8. HD Radio source specific menu .................................................. .......................................... 16 Source Type .................................................. .................................................. ............................... 16 Now Playing .................................................. .................................................. ............................... 17 Presets .................................................. .................................................. ....................................... 17 Band .................................................. .................................................. .......................................... 17 Seek Mode .................................................. .................................................. ................................. 17 Distance .................................................. .................................................. ................................. 17 Local .................................................. .................................................. ....................................... 18 Manual .................................................. .................................................. ................................... 18 Digital .................................................. .................................................. ..................................... 18 2.2.9. Sirius/XM source specific menu .................................................. ......................................... 18 Source Type .................................................. .................................................. ............................... 18 Now Playing .................................................. .................................................. ............................... 18 Presets .................................................. .................................................. ....................................... 18 Preset Bank .................................................. .................................................. ................................ 19 2.2.10. Presets Menu .................................................. .................................................. .................. 19 2.2.11. Setup Menu .................................................. .................................................. ..................... 19 Setup Keys .................................................. .................................................. ................................. 19 Reset Key Defaults.......................................... .................................................. ........................... 24 Setup Display .................................................. .................................................. ............................. 25 Scroll Parameters .................................................. .................................................. .................... 25 NP Timeout .................................................. .................................................. ............................ 25 Display Length .................................................. .................................................. ......................... 25 Fast Update (UI2 Only) .................................................. .................................................. ............ 25 Lead Char (UI2 Only) .................................................. .................................................. ............... 26 Setup Search .................................................. .................................................. .............................. 26 Auto Song Search .................................................. .................................................. .................... 26 Percentage Search .................................................. .................................................. ................... 27 Setup Language .................................................. .................................................. ........................... 27 Auto .................................................. .................................................. ....................................... 27 English .................................................. .................................................. .................................... 27 Deutsch .................................................. .................................................. .................................. 27 Dutch .................................................. .................................................. ..................................... 27 Français .................................................. .................................................. .................................. 27 Italiano .................................................. .................................................. ................................... 27 Español .................................................. .................................................. .................................. 27 Extras .................................................. .................................................. ......................................... 27 Vehicle Info .................................................. .................................................. ............................ 27 Control .................................................. .................................................. ................................... 30 Extras Setup .................................................. .................................................. ........................... 33 OBC Display (UI1 and UI4 Only) .................................................. .................................................. ... 36 Enable .................................................. .................................................. .................................... 36 Text Item .................................................. .................................................. ................................ 36 OBC Target .................................................. .................................................. ............................. 39 Start Delay .................................................. .................................................. ............................. 39 iii Speed .................................................. .................................................. ..................................... 39 End Delay .................................................. .................................................. ............................... 39 Final Delay .................................................. .................................................. .............................. 39 2.2.12. Diagnostics Menu .................................................. .................................................. ............ 39 Reboot .................................................. .................................................. ....................................... 39 Reset Counts .................................................. .................................................. .............................. 39 Power Ctrl Off .................................................. .................................................. ............................ 39 Power Ctrl On................................................ .................................................. ............................... 40 iBusd .................................................. .................................................. .......................................... 40 iBusm .................................................. .................................................. ......................................... 40 Netd .................................................. .................................................. ........................................... 40 Netm .................................................. .................................................. .......................................... 40 Appm .................................................. .................................................. ......................................... 40 Pings .................................................. .................................................. .......................................... 40 Critm .................................................. .................................................. .......................................... 40 2.2.13. Status Menu .................................................. .................................................. .................... 40 Boot Count .................................................. .................................................. ................................. 40 Boot Fatal Count .................................................. .................................................. ......................... 40 Recovery Count .................................................. .................................................. ........................... 40 Sleep Fail Count .................................................. .................................................. .......................... 40 Watchdog Count .................................................. .................................................. ......................... 41 IPC Count .................................................. .................................................. ................................... 41 Run Time .................................................. .................................................. .................................... 41 2.2.14. About Menu .................................................. .................................................. .................... 41 Firmware Version .................................................. .................................................. ........................ 41 Firmware Build .................................................. .................................................. ........................... 41 Serial Number .................................................. .................................................. ............................ 41 Build Date .................................................. .................................................. .................................. 41 3. Multi Line Menu UI Mode 6 .................................................. .................................................. ............ 42 3.1. Control Keys .................................................. .................................................. ........................... 42 3.2. Initial Setup .................................................. .................................................. ............................ 43 3.2.1. Nav System Setup .................................................. .................................................. ............ 43 TV Module .................................................. .................................................. ................................. 44 Mk 1, Mk 2 and Mk 3 Nav computers with Software 3-1/31 or lower .............................................. 44 Mk 3 Nav computers with Software 3-1/40 or higher and Mk 4 Nav computers .............................. 44 Mk 4 Nav computers with Software 4-1/40 or higher .................................................. .................... 44 3.2.2. BMW Mini .................................................. .................................................. ....................... 44 3.3. Intravee Menu Reference .................................................. .................................................. ........ 44 3.3.1. iPod Source .................................................. .................................................. ..................... 45 Main Menu .................................................. .................................................. ................................ 45 Random Mode .................................................. .................................................. ........................ 45 Repeat Mode .................................................. .................................................. .......................... 45 Pause/Play .................................................. .................................................. ............................. 46 Now Playing Menu .................................................. .................................................. ...................... 46 Now Playing Screen .................................................. .................................................. ..................... 47 Alternate Now Playing Screen .................................................. .................................................. ..... 48 Extended Song ID3 Now Playing Screen .................................................. ........................................ 48 Extended Album ID3 Now Playing screen .................................................. ...................................... 49 Extended Artist ID3 Now Playing screen .................................................. ........................................ 49 Search Menu .................................................. .................................................. .............................. 50 iv 3.3.2. MP3 CD or DVD Source .................................................. .................................................. .... 51 Main Menu .................................................. .................................................. ................................ 51 Random Mode .................................................. .................................................. ........................ 51 Repeat Mode .................................................. .................................................. .......................... 51 Intro Scan .................................................. .................................................. ............................... 52 Pause/Play .................................................. .................................................. ............................. 52 Now Playing .................................................. .................................................. ............................... 52 Static Now Playing Screen .................................................. .................................................. ........... 53 Search Menu .................................................. .................................................. .............................. 54 Combined Search Menu .................................................. .................................................. .............. 54 Disc Selection Menu .................................................. .................................................. .................... 55 3.3.3. Audio CD or MD Source .................................................. .................................................. ... 56 Main Menu .................................................. .................................................. ................................ 56 Random Mode .................................................. .................................................. ........................ 56 Repeat Mode .................................................. .................................................. .......................... 56 Intro Scan .................................................. .................................................. ............................... 57 Pause/Play .................................................. .................................................. ............................. 57 Now Playing .................................................. .................................................. ............................... 57 Static Now Playing Screen .................................................. .................................................. ........... 58 Disc Selection Menu, 6 Disc Changer .................................................. ............................................. 59 Disc 1-6 Selection Menu, 12 Disc Changer .................................................. ..................................... 59 Disc 7-12 Selection Menu, 12 Disc Changer .................................................. ................................... 60 3.3.4. DAB Radio Source .................................................. .................................................. ............ 60 Main Menu .................................................. .................................................. ................................ 60 Preset Banks 1-3 .................................................. .................................................. ...................... 61 Dynamic Range............................................. .................................................. ............................ 61 Now Playing .................................................. .................................................. ............................... 61 Static Now Playing Screen .................................................. .................................................. ........... 62 Secondary Static Now Playing Screen .................................................. ............................................ 62 Presets Menu .................................................. .................................................. ............................. 63 Auto Store .................................................. .................................................. .................................. 63 DAB Station Secondary Service........................................... .................................................. ........... 63 3.3.5. HD Radio source .................................................. .................................................. .............. 64 Main Menu .................................................. .................................................. ................................ 64 Next Band .................................................. .................................................. .............................. 64 Now Playing .................................................. .................................................. ............................... 65 Presets Menu .................................................. .................................................. ............................. 65 Auto Store .................................................. .................................................. .............................. 66 Seek Mode .................................................. .................................................. ................................. 66 Distance .................................................. .................................................. ................................. 66 Local .................................................. .................................................. ....................................... 66 Manual .................................................. .................................................. ................................... 67 Digital Only .................................................. .................................................. ............................. 67 3.3.6. Sirius or XM Radio Source .................................................. .................................................. 67 Main Menu .................................................. .................................................. ................................ 67 Preset Banks 1-3 .................................................. .................................................. ...................... 68 Category Search (Sirius Only)............................................. .................................................. ........ 68 Now Playing .................................................. .................................................. ............................... 68 Static Now Playing Screen .................................................. .................................................. ........... 69 Presets Menu .................................................. .................................................. ............................. 69 v 3.3.7. Aux Source .................................................. .................................................. ...................... 70 Main Menu .................................................. .................................................. ................................ 70 Now Playing .................................................. .................................................. ............................... 71 3.4. Search Menu type .................................................. .................................................. ................... 71 3.4.1. Standard Search Menu .................................................. .................................................. .... 72 3.4.2. Fast Search Menu .................................................. .................................................. ............ 72 3.4.3. Advanced Search Menu .................................................. .................................................. ... 73 3.4.4. Percentage Search .................................................. .................................................. ........... 74 3.5. Source Menu .................................................. .................................................. ........................... 75 3.6. Setup Menu .................................................. .................................................. ........................... 75 3.6.1. Setup Display .................................................. .................................................. ................... 77 Now Playing .................................................. .................................................. ............................... 78 Art./Alb./Song .................................................. .................................................. ......................... 78 Art./Song/Alb. .................................................. .................................................. ......................... 78 Alb./Art./Song .................................................. .................................................. ......................... 78 Song/Art./Alb. .................................................. .................................................. ......................... 78 Song/Alb./Art. .................................................. .................................................. ......................... 78 Alb./Song/Art. .................................................. .................................................. ......................... 78 Language .................................................. .................................................. .................................... 79 Time Outs .................................................. .................................................. .................................. 80 Headers........................................... .................................................. ............................................. 80 Reset Hdr Defs. .................................................. .................................................. ........................... 81 Long Fields .................................................. .................................................. ............................. 88 Short Fields .................................................. .................................................. ............................ 88 Nav Type .................................................. .................................................. .................................... 89 Auto .................................................. .................................................. ....................................... 89 TV Module............................................ .................................................. .................................... 89 Mk1 or Mk2............................................... .................................................. ............................... 89 Mk3 < 3-1/40................................................ .................................................. ............................ 89 Mk3 >= 3-1/40 .................................................. .................................................. ......................... 90 Mk4 < 4-1/40................................................ .................................................. ............................ 90 Mk4 >= 4-1/40 .................................................. .................................................. ......................... 90 High OBC .................................................. .................................................. .................................... 90 High OBC Text .................................................. .................................................. ......................... 91 Enable High OBC............................................... .................................................. ......................... 91 Scroll Speed .................................................. .................................................. ............................ 91 Repeats .................................................. .................................................. .................................. 91 Start Delay .................................................. .................................................. ............................. 91 End Delay .................................................. .................................................. ............................... 91 Final Delay .................................................. .................................................. .............................. 92 Text Size .................................................. .................................................. ..................................... 92 3.6.2. Setup Keys .................................................. .................................................. ....................... 93 Reset Key Defs. .................................................. .................................................. ........................... 98 M/F Wheel .................................................. .................................................. ............................. 99 M/F Wheel LKP .................................................. .................................................. ...................... 100 Head Unit .................................................. .................................................. ............................. 101 Head Unit LKP .................................................. .................................................. ....................... 102 Numbers .................................................. .................................................. .............................. 103 Numbers LKP .................................................. .................................................. ......................... 103 3.6.3. Setup Search............................................ .................................................. ........................ 104 vi Standard .................................................. .................................................. .................................. 104 Fast Search .................................................. .................................................. ............................... 104 Advanced Search .................................................. .................................................. ....................... 104 Auto Song Search .................................................. .................................................. ...................... 104 Percentage .................................................. .................................................. ............................... 104 Scroll Direction .................................................. .................................................. .......................... 105 3.6.4. Usage Options .................................................. .................................................. ............... 105 Source Options .................................................. .................................................. .......................... 106 iPod AutoName .................................................. .................................................. ..................... 106 Set Src Name .................................................. .................................................. ......................... 106 Port Override .................................................. .................................................. ........................ 107 Enable Actions .................................................. .................................................. ....................... 107 Change Actions........................................... .................................................. ............................ 107 Key Memory............................................ .................................................. ................................... 108 Source .................................................. .................................................. .................................. 108 Blink Count .................................................. .................................................. ........................... 108 Auto Pause .................................................. .................................................. ........................... 108 Sticky FF/RW .................................................. .................................................. ............................ 109 Auto Pause .................................................. .................................................. ............................... 109 Audio Processor .................................................. .................................................. ........................ 109 3.6.5. Diagnostics .................................................. .................................................. .................... 109 Reset Counts .................................................. .................................................. ............................ 109 Reboot .................................................. .................................................. ..................................... 110 Power Ctrl Off .................................................. .................................................. ........................... 110 Power Ctrl On................................................ .................................................. ............................. 110 Status .................................................. .................................................. ....................................... 110 Boot Count .................................................. .................................................. ........................... 110 Fatal Boot Count .................................................. .................................................. ................... 110 Recovery Boot Count .................................................. .................................................. ............. 110 Sleep Fail Count .................................................. .................................................. ..................... 110 Run Time .................................................. .................................................. .............................. 111 Error Log .................................................. .................................................. .................................. 111 Logging .................................................. .................................................. .................................... 112 ibusd .................................................. .................................................. .................................... 112 ibusm .................................................. .................................................. ................................... 112 netd .................................................. .................................................. ..................................... 112 netm .................................................. .................................................. .................................... 112 appm .................................................. .................................................. .................................... 112 pings .................................................. .................................................. .................................... 113 critm .................................................. .................................................. .................................... 113 3.6.6. About .................................................. .................................................. ........................... 113 Hardware .................................................. .................................................. ................................. 113 Serial Number .................................................. .................................................. ....................... 114 Manufacture Date .................................................. .................................................. ................. 114 Hardware Type .................................................. .................................................. ...................... 114 Hardware Version .................................................. .................................................. ................. 114 CPU Type .................................................. .................................................. .............................. 114 Net CPU Type .................................................. .................................................. ........................ 114 Software .................................................. .................................................. .................................. 114 Firmware version .................................................. .................................................. .................. 115 vii Build Number .................................................. .................................................. ........................ 115 Bootloader Version .................................................. .................................................. ............... 115 Net Firmware version .................................................. .................................................. ............ 115 Net Bootloader Version .................................................. .................................................. ......... 115 Menus .................................................. .................................................. ...................................... 115 Menu Family .................................................. .................................................. ......................... 116 Menu Version .................................................. .................................................. ........................ 116 Key Actions Version .................................................. .................................................. ............... 116 Header Definition Version .................................................. .................................................. ..... 116 Switch .................................................. .................................................. ...................................... 117 Switch Type .................................................. .................................................. ........................... 117 Number of Net Ports .................................................. .................................................. ............. 117 Number of Aux Ports .................................................. .................................................. ............. 117 Serial Number .................................................. .................................................. ....................... 117 Software version .................................................. .................................................. ................... 117 3.7. Extras .................................................. .................................................. ................................... 117 3.7.1. Vehicle Info .................................................. .................................................. ................... 118 Vehicle Status .................................................. .................................................. ........................... 119 Outside Temperature .................................................. .................................................. ............ 120 Coolant Temperature .................................................. .................................................. ............ 120 Vehicle Speed .................................................. .................................................. ........................ 120 Engine RPM .................................................. .................................................. ........................... 120 Fuel remaining .................................................. .................................................. ...................... 120 Maximum Vehicle Speed .................................................. .................................................. ....... 120 Maximum Engine RPM .................................................. .................................................. .......... 121 Maximum Coolant temperature .................................................. .............................................. 121 Acceleration in G. .................................................. .................................................. .................. 121 Deceleration in G................................................. .................................................. .................... 121 Light Sensor .................................................. .................................................. ............................. 121 Dimmer State .................................................. .................................................. ........................ 121 Ambient Light Sensor .................................................. .................................................. ............ 122 Auto Light............................................. .................................................. .................................. 122 Environment .................................................. .................................................. ......................... 122 PDC Info .................................................. .................................................. ................................... 122 Nav Info .................................................. .................................................. ................................... 123 Gyro Voltage .................................................. .................................................. ......................... 124 Logic Supply Voltage........................................... .................................................. ..................... 124 Battery Supply Voltage .................................................. .................................................. .......... 124 Sensor Supply Voltage .................................................. .................................................. ........... 124 Nav Temperature .................................................. .................................................. .................. 124 GPS Status .................................................. .................................................. ............................ 124 Journal .................................................. .................................................. ..................................... 124 Service Info .................................................. .................................................. .............................. 127 Vehicle Network Type .................................................. .................................................. ........... 127 Fuel Type .................................................. .................................................. .............................. 127 Fuel Used .................................................. .................................................. ............................. 127 Bi-Annual Check Due Date .................................................. .................................................. ..... 127 Previous Service type .................................................. .................................................. ............ 127 Oil Changes .................................................. .................................................. ........................... 127 Inspections .................................................. .................................................. ........................... 128 viii Device Info .................................................. .................................................. ............................... 128 3.7.2. Control .................................................. .................................................. .......................... 129 Setup Clock .................................................. .................................................. .............................. 130 Time Zone .................................................. .................................................. ............................ 130 Daylight Saving Time .................................................. .................................................. ............. 130 Auto Set .................................................. .................................................. ............................... 131 Update Now .................................................. .................................................. .......................... 131 GPS Time .................................................. .................................................. .............................. 131 GPS Date .................................................. .................................................. .............................. 131 Status .................................................. .................................................. ................................... 131 Mirror Folding .................................................. .................................................. ........................... 131 Fold Mirrors .................................................. .................................................. .......................... 132 Unfold Mirrors .................................................. .................................................. ...................... 133 Fold Duration .................................................. .................................................. ........................ 134 Auto Locks............................................. .................................................. ..................................... 134 Auto Lock .................................................. .................................................. ............................. 135 Auto Unlock .................................................. .................................................. .......................... 135 Park Unlock .................................................. .................................................. ........................... 135 Light Control .................................................. .................................................. ............................ 135 Blink Count .................................................. .................................................. ........................... 135 AEs as DLR .................................................. .................................................. ............................ 136 On Unlock and On Unlock .................................................. .................................................. ...... 136 Nav Control .................................................. .................................................. .............................. 139 Map Zoom Menu.............................................. .................................................. ....................... 139 Nav Audio Off .................................................. .................................................. ........................ 142 Miscellaneous .................................................. .................................................. ........................... 143 Auto Close .................................................. .................................................. ............................ 143 BT Pairing .................................................. .................................................. ............................. 143 Auto Recirc. .................................................. .................................................. ........................... 143 3.7.3. Extras Settings .................................................. .................................................. ............... 144 Vehicle Type .................................................. .................................................. ............................. 144 E38/E39 .................................................. .................................................. ................................ 144 E39 Late .................................................. .................................................. ............................... 145 X5 To Sept 03 .................................................. .................................................. ........................ 145 X5 Sept 03 On .................................................. .................................................. ........................ 145 Range Rover .................................................. .................................................. .......................... 145 E46 Type 1 .................................................. .................................................. ............................ 145 E46 Type 2/Z4 .................................................. .................................................. ....................... 145 Display Units .................................................. .................................................. ............................ 145 Metric .................................................. .................................................. .................................. 145 Imperial .................................................. .................................................. ................................ 146 Metric (Imp.) .................................................. .................................................. ......................... 146 Imp. (Metric) .................................................. .................................................. ......................... 146 Vehicle Only .................................................. .................................................. .......................... 146 Vehicle (Alt) .................................................. .................................................. ........................... 146 Alt (Vehicle) .................................................. .................................................. ........................... 146 Speed Correction .................................................. .................................................. ...................... 146 Disclaimer .................................................. .................................................. ................................ 147 Reset Journal........................................... .................................................. ................................... 147 PDC Settings .................................................. .................................................. ............................. 147 ix Auto Display .................................................. .................................................. .......................... 147 Rear Only .................................................. .................................................. ............................. 147 High OBC .................................................. .................................................. .............................. 148 PDC Units .................................................. .................................................. ............................. 149 Boot Open Message .................................................. .................................................. .................. 150 |
