04-11-2009, 02:04 PM | #287 | |
Rep 18,866
Drives: BMW
1. Disconnect iPod from cable 2. Remove battery cables, negative first 3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system. 4. Allow cables to remain disconnected for about 5-7 minutes 5. Reconnect battery cables onto battery, negative last. 6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed. Let me know if these steps correct the problem.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
05-07-2009, 02:52 PM | #289 |
Rep 18,866
Drives: BMW
Just released this week, the Silverline PRO kit adds a new operating mode called SMART Mode. This mode allows users to switch between Locked and Display Modes using the Hold button on the iPod. This supplemental guide only applies to users who have selected to set the DICE kit to SMART mode. This is done using the DIP switches on the interface module.
Display mode is especially great for those iPhone/touch users and the Pandora app or internet radio. More info here: http://www.zpost.com/forums/showthre...62#post5075562
05-27-2009, 09:08 AM | #291 |
Rep 701
I GOT IT TO WORK!!!
ZERO NOISE NOW. I can confirm that the Radio Interface - Dice Silverline kit is indeed totally free of any interference compared to the Trunk Interface kit. The iBus digital noise or what ever it was... Dit Dit Dit noise I was experiencing from the trunk interface kit was bordering on my deal breaker limit. The Radio Interface kit is only slightly more complicated to fit but the quality of audio is far superior to the Trunk Interface kit. From my testing the R40 Dice Silverline harness for the Z4 and maybe some other BMW models needs to be modified to work with vehicles with SatNav. See pic below for details.
05-27-2009, 11:15 AM | #292 | |
Rep 18,866
Drives: BMW
06-04-2009, 01:54 AM | #293 | |
Rep 847
I have had terrible noise problem too with the trunk cable and haven't had a chance to drive down to OC. Did you get the radio interface kit to work WITH a navigation unit? I can't stand the noise anymore |
06-04-2009, 05:17 AM | #294 | |
Rep 701
Noise is totally gone and SatNav works 100%. Just follow the illustration in my original post for directions and you won't believe the difference. I had searched hundreds of posts on every forum to find a solution and there was no definite fix I could find to this very common issue. I'm glad I nutted out the problem and hopefully all others with this problem will be able to benefit from my experimenting. I went through three Dice kits and finally ordered the R40 Radio harness as a last ditch effort as I knew there had to be a solution. Then after not getting SatNav with the R40 harness I had to fix that issue. Now I have! I feel E.A.S. and Dice should amend their website to reflect this modification instead of recommending the 'Trunk Interface' kit for vehicles that have SatNav. This was not an option for me. For me the 'Trunk Interface' kit with the associated interference was unacceptable. I would not recommend the 'Trunk Interface' kit to anyone as even if the noise is not too bad with it, the alternative will be infinately better with the 'Radio Interface' kit.
06-04-2009, 11:40 AM | #295 | |
Rep 18,866
Drives: BMW
At least with us - you have a choice on which kit to choose from. We're also here for support if needed.
06-04-2009, 03:42 PM | #296 |
Rep 847
Thanks! Did you install the module in that empty space under the radio? Also, where did you run the wires to, i.e. where do you put the ipod?
06-04-2009, 06:36 PM | #297 | |
Rep 701
I leave my iPod in my Z4-MC permanently.
06-04-2009, 09:10 PM | #299 | |
Rep 701
The R40 harness comes standard in the Dice Silverline 'Radio Interface' kit. Maybe you could swap yours over depending on how long ago you bought it.
06-05-2009, 03:15 PM | #300 |
Rep 847
Yeah I already asked Tom but I bought it last year so I can't exchange it Maybe I can swap it with someone who ordered the wrong harness or wants to switch from radio to trunk. You saved the day with the info
06-05-2009, 04:59 PM | #301 | |
Rep 701
Just ask yourself, are you seriously going to miss a lousy $40.00 anyway? It's really a small price anyway for the R40 harness. For the difference it makes it is well worth the cost, you won't regret the swap. Ok so you made a mistake and ordered the worng kit, doesn't matter. I think the Dice install cost me well over $500.00 with all the extra shipping and additional return shipping costs after 3 exchanges and plus flat battery issues. However, it was the BEST money I have spent in ages! I have to lock the steering wheel after I remove the ignition key on my Z4 to make sure there is no drain on the battery but after much research that cured any possible current draw. At the end of the day I do not regret buying the Dice or dealing with E.A.S. as they have a great customer service and support system and the Dice iPod kit really is a great product. There are always going to be small issues in any retro install when trying to intergrate iPod into a vehicles OEM audio system but with time and patience you can work them out.
06-05-2009, 05:42 PM | #302 | |
Rep 847
At $500 however I would definitely buy Intravee II unit which IMO is superior to the Dice unit in functionality, options and ease of navigation. Of course it is alsoo more expensive: $250 for the unit and another $50-100 for the Alpine iPod adaptor that's necessary. In the end what's important is that you got it to work properly and you also learned something that can benefit others as well Now THAT is well worth $500. |
06-17-2009, 10:56 AM | #303 |
Rep 105
I have a 2006 Canadian Z4M Coupe. I have premium package and navigation (no THX system). I am pretty sure I am prewired for a CD changer. What kit do I need? Do I have analog DSP or digital DSP?
Thanks |
06-17-2009, 11:29 AM | #304 |
Rep 18,866
Drives: BMW
All 2006+ models are Analog DSP, the additional converter is not needed.
07-22-2009, 07:31 PM | #306 |
Rep 847
Ok now I have a new problem! I got the R40 cable that connects to the back of the radio, took out the radio and can't figure out what the R40 (the end that doesn't connect to the radio) should be plugged into! I have navigation, if that makes a difference. I couldn't find any guides to install the radio interface
07-22-2009, 08:12 PM | #307 | |
Rep 701
There are probably no instructions included with the R40 cable because the installation is both extremely obvious and basic they didn't believe anyone could possibly need them. The R40 plug goes into the radio and the R40 socket end connects to the cable that was originally connected to the factory radio. There is also a breakout cable on the R40 that connects to the Dice Silverline module.
07-22-2009, 09:31 PM | #308 | |
Rep 847
HAHA definitely NOT one of my brighter moments I can't believe I couldn't figure that out, specially since I retrofitted the nav myself and had installed all those cables in the first place! Now that it's done the sound quality is amazinG! Until now I had so much noise that it was like using an FM transmitter. Now it's crystal clear! Thanks for the help |
