08-21-2011, 11:42 PM | #1 |
Rep 476
Spark plug nerds and experts: how do these look? (high-resolution macro SLR photos)
Just pulled these today from my VT2-500 boosted S54. I replaced them with the same, but my first question: I've heard some recommend cooler temperature ranges for FI motors; what do you think?
The most concerning thing to me is plug #3. It appears to have oil on the threads, and the spark plug galley for only that plug has a strange-looking flat spot drilled into it which also appears to have some oil sitting in it. Why does only plug #3 have this difference? Do the plugs speak of rich running or too high a heat temperature? I notice tiny whitish crystals on them which I have heard can indicate too high a temperature plug. Photos below--first each plug 1-6, then a new plug for comparison, then a detail on plug 3, then a series of shots into the plug 3 galley showing the weird region containing some oil. |
08-22-2011, 09:50 AM | #2 |
Bad Lieutenant
232
Rep 3,517
My guess is #3 was loose and not torqued to spec (overheated as a result) as well as the plug well grommet needs replacing. When was the last time the valve cover was removed, for say, a valve adjustment? Were those grommets re-used perhaps? The other plugs don't look too bad, actually. I'm surprised ESS didn't recommend a cooler plug or going to iridium.
08-22-2011, 10:00 AM | #3 |
Rep 5,328
ess recommend the stock plugs........
if its good enough for them, its good enough for me... your plugs seem to running well, lots of sooty black is to rich, your seems to indicate a good burn, if your AFRs are in the 11s and your plugs look this they do id be happy with that... what were your AFRs @ WOT again??
08-22-2011, 12:06 PM | #4 | |
Rep 476
What is the purpose of this "plug well" and its grommet? Why does only cylinder #3 have one? Yeah, I read quite a bit online about it being standard practice for even low-boost S/C applications to use at least one temp range cooler plugs; I think perhaps ESS wants to keep the "this works great with completely stock/OEM everything else; totally bolt-on!" appeal. What are the characteristics of iridium plugs specifically that you think might be desirable for a VT2-500 S54? |
08-22-2011, 12:09 PM | #5 |
Rep 476
I need to actually extract the chart from the dyno data because it involves a few extra steps I haven't gone through yet, but when I saw it at the Dynapack event it was 11.5-12 IIRC. I have no real problems at WOT aside from low boost, but the mixture is definitely off in lower exhaust flow scenarios which have been causing misfires.
I'm in the process of procuring OEM Euro headers (probably CSL) though absolutely dreading doing another header replacement just 1-2 months after I put the AA headers in. Also information on how to handle sensor positioning when converting USDM to Euro is pretty hit-or-miss at best, lol, and means I couldn't do the entire job myself (3 new sensor bungs to weld in that the AA headers have integrated). |
08-22-2011, 01:33 PM | #6 | |
Rep 5,328
The v8 cars are running 650hp on stock plugs which i believe are basically the same as our ones, our 500hp isnt really stressing them, probably the same situation with the coils as well ;-) i recently swapped my plugs at insp 2 @ 10,500 miles and tbh i noticed no difference in the way the kit behaves.
08-22-2011, 01:53 PM | #7 | |
Bad Lieutenant
232
Rep 3,517
08-22-2011, 02:17 PM | #8 |
40
Rep 1,481
If any of you FI guys have the chance to pull your heads and bench them...one thing that we turbo guys like to do is index several sets of plugs and mark their respective positions for future installation.
Having the plugs all sitting at the same cross-points to valves can make for very consistent burning and plug life. The only plug that will show a difference then will be a starvation or overage from intake design. |
08-22-2011, 02:26 PM | #9 | |
703
08-22-2011, 03:04 PM | #10 | |
Rep 476
I will contact BMW to try to determine what work was recorded as performed during Inspection I. I didn't realize a valve adjustment was called for then as well. Beedub, how the heck did you get Inspection II done around just 10k miles?! Sad to see that BMW is probably doing poor work on this job, as I have the extended maintenance package (which amusingly, I confirmed will still pay for the bulk of the Inspection II work since the S/C kit doesn't complicate the job). |
08-22-2011, 03:07 PM | #11 | |
Rep 476
What do you mean by your last sentence? |
08-22-2011, 03:10 PM | #12 | |
Rep 11,667
08-22-2011, 03:40 PM | #13 |
Rep 5,328
arhh i love this engine section... so much good info in here :-)
08-22-2011, 03:52 PM | #14 |
Bad Lieutenant
232
Rep 3,517
I wonder how the indexing would work on the plugs with the crush washers. For iron block engines, with the tapered design, I had a bag of these copper "washers" designed for a little extra twist to index. Not sure how beneficial it would be for the S54, but it's got a good geek factor.
08-22-2011, 03:55 PM | #15 |
Bad Lieutenant
232
Rep 3,517
Especially the valve adjustments, easier on the Z chassis, by far, and you can use more precise feeler gauges than the techs are allowed to use.
08-22-2011, 04:32 PM | #16 | |
40
Rep 1,481
Last sentence......a lean or rich plug anomaly could be an indicator that the intake manifold is staving air or receiving too much compared to other cylinders. We consider these things when engineering a modded intake. |
08-22-2011, 06:01 PM | #17 |
Rep 2,138
Drives: Me
Three years ago, when I pulled the Vanos off the Roadster (M54) to replace the internal Vanos O-rings, I replaced all the upper valve cover seals. All the seals came in one kit. It was so easy to change out, even a cave man could do it.
If you feel that you have a seal weeping or leaking, it really is an easy fix. |
08-22-2011, 06:06 PM | #18 | |
Rep 476
Does anyone know the purpose of these seals? That is, why does that circular area even exist, milled out of the side of the plug well? |
