07-08-2011, 02:10 AM | #1 |
First Class M
20
Rep 217
Drives: Z4M Coupe, E36 Coupe
M Coupe Horsepower
Guys wanna ask how much of rear wheel power hahttp://www.zpost.com/forums/showthread.php?p=9982006#post9982006ve you gained on your Z4M with your full mods?
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop. Last edited by IronZ4M; 07-08-2011 at 12:52 PM.. |
07-08-2011, 04:13 AM | #2 |
Rep 5,328
i have 450rwhp..... @ 8psi boost.
07-08-2011, 06:03 AM | #4 |
Rep 5,328
a tune would bring out your mods nicely.... get to it mayynnn!!!
07-08-2011, 06:52 AM | #5 |
Rep 191
300 with the Supersprint V1 stepped headers and current mods listed below. Haven't dynoed with the Euro headers. When I do I'll post both graphs.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
07-08-2011, 07:02 AM | #6 |
Rep 1,373
I put down 310rwhp with my mods and the same day an E46 M3 with just a catback put down 278rwhp.... So a rough guess with my mods i gained about 32rwhp
07 Z4 M Coupe AW/IR |
07-08-2011, 08:08 AM | #7 |
First Class M
20
Rep 217
I'm wondering how much I'll gain with my mods: it's Euro and I have SS X pipe and Race SS mufflers and I'm going to order ESS Flash and drop an air filter and RPI scoop etc... I'm comparing my car to My cousin 135i his car has a down pipe, JB4, BMS filters, and Active BOV anyway I had a race with him while My car is only having SS X pipe and SS Race mufflers and 20'' wheels. we were racing on 60 km/h up to 180 km/h both on second gear and the distance was almost 2 cars and he's still going more. If I had that mods that I didnt have them yet there will be a difference or not? what do you think?
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop. |
07-08-2011, 08:34 AM | #8 |
Rep 5,328
your 20s will be loosing you serious performance....... at most you want a nice lightweight 19, but for max performance 18 is perfect on this car..... or for a compromise a nice lightweight 19 will give you better look and performance, tyres will be expensive @ this size point.
07-08-2011, 10:10 AM | #9 | |
First Class M
20
Rep 217
07-08-2011, 12:05 PM | #11 |
Rep 784
Drives: 2011.5 E90 M3
07-08-2011, 12:49 PM | #12 |
First Class M
20
Rep 217
actually if I'm going for serious race I'm going to use the OEM wheels and happy with them. coz If i was going for high hourspower the OEM wheels will be enough put for extra mod I'll buy light weight wheels but for now a wanna make a full mod without any force injection for now.
07-10-2011, 12:46 PM | #13 |
Rep 84
Drives: 2006 Z4M SuperCharged
I make about 365 rwhp with the VT1-445. The only other mod are BBS LMR's, 19 inch with PS2s (245 front, 275 rear).
07-10-2011, 04:17 PM | #14 |
Rep 457
Full ss exhaust, ess tune, and an intake?
07-10-2011, 08:07 PM | #15 |
///M-fanatic
193
Rep 3,885
That sounds about right.
I did a dynojet quite a few months back (sans the section1 and section2), and got 295rwhp. This was without any fans up front to feed the motor. Relevant Mods at the time: AA Tune, BMC filter, JVT headers, stock section1, stock x-pipe, SS race mufflers, 3.91 ring & pinion, 19" Volks. I bet I'm now around the same power point as him, but obviously hoping for as much as possible Relevant Mods added: uncatted SS section1, SS x-pipe, and RPi scoop Hopefully a fan will help the scoop and motor maximize their potentials I'm expecting at least 305rwhp on a dynojet, and/or at least 315rwhp on a dynapack. Last edited by mfanatic325; 07-10-2011 at 08:20 PM.. |
07-15-2011, 08:17 AM | #17 | |
Rep 170
At least on the local dyno's I've been on. |
07-17-2011, 06:30 AM | #18 | |
///M-fanatic
193
Rep 3,885
But I've also heard rumors about this too, so I'm confused. Although, if you really think about it...logically-speaking, one should lose more power by having to transfer through a pair (or more) wheels/tires, especially when combating any frictional resistance from the rollers. And on the other side of the equation, we have the DynaPack, which hooks up directly to the hub, so there's practically no losses to be had. It all depends on what you use for baseline really...and as long as you stay consistent with it throughout the modding process. Kind of like a controlled environment; or as best as you can at least. |
07-17-2011, 06:58 AM | #19 |
First Class M
20
Rep 217
what is that mod?
07-17-2011, 07:31 AM | #20 |
First Class M
20
Rep 217
so you are not running any other mods. stoke Exhaust?
07-17-2011, 10:05 AM | #21 | |
Rep 170
however; Dynojets are an inertia type and Dynapack uses hydraulic pressure. How they calculate / measure power is very different. Maybe the gap in your results and mine are associated to how the Dynapack was set up. I have seen 10 HP increase on Dynopacks by simply adjusting them to accellerate more slowly on an power pull. One thing I didn't like about Dynojets is that drivetrain weight affects the numbers. If you install light weight Wheels, flywheel or rotors you HP will go up. |
