08-09-2011, 11:59 PM | #1 |
Rep 32
Post O2s and egt turned off. Will it be a problem?
Im soon gonna be getting a set of euro headers for my z4mcoupe and was planning to get the ESS tune with the after cats O2 sensors and egt turned off. (planning to have them unplugged al together and stored away). Is this gonna cause any problems performance wise? Will I get a CEL/SES? Dont really want to get into the hassle of welding bungs into the S pipe for the post cat O2s and egt. Still gonna run the stock S pipe with their cats just to keep things green. But since I live in Panama we dont have any type of emission test whatsoever. For my understanding post cats O2s and egt are only for emission purpose and monitoring the cats perfomace right?
08-10-2011, 03:08 PM | #2 |
instagram 997turbotom
279
Rep 7,377
You'll likely have issues with at least a check engine light, car may also run rough
ESS doesn't recommend running with no sensors connected The rear sensors should NOT affect performance, but if something is wrong with the engine, they're a backup failsafe to shut the engine down to save it Cut off the egt bung from your old headers, grab these adapters, and pay an exhaust shop to weld it in. Should NOT be expensive http://stores.channeladvisor.com/aut...temid=13552227
08-10-2011, 04:32 PM | #3 |
Rep 5,328
OP trust me Roffle knows more than most on this subject ;-)
08-11-2011, 12:47 AM | #5 | |
Rep 32
Whats the reason for relocating the egt to the "S" pipe? Cant I just weld it into the Euro Headers as in the US catted ones? |
08-11-2011, 04:49 PM | #6 |
279
Rep 7,377
read up on the sensor placement here
http://www.zpost.com/forums/showthread.php?t=519048 you're putting it BEHIND the section one cats for a reason, because... well... they need to be reading the ratios from behind the cats (since the euro headers have no cats, they go behind the secondary cats in the system)
08-11-2011, 10:20 PM | #7 |
Rep 32
I understand the relocation of the secondary O2s behind the catts of section 1. But reading through your thread link, "Jumbosock" made a comment about putting the egt bung in the Euro Headers (As in the same position of our US Headers) to avoid "EGT plausibility code" (2C93).
Has anyone besides Jumbosock installed their EGT into Euro headers instead of te section 1 pipe? |
