01-04-2015, 04:55 PM | #23 |
Rep 12,565
He basically said the same thing, yes stiffer springs lead to a harsher ride but nothing to extent that would cause frequent tire bubbles. Luckily I've found used tires with similar matching tread on ebay for decent prices so it hasn't been too bad. Not sure what to do next though...
01-04-2015, 05:20 PM | #24 |
Rep 11,667
Were the other tires used as well?
My only thought is that you could have been dealing with previous unseen damage.
01-04-2015, 05:49 PM | #25 |
Rep 12,565
Nah, all 3 bubbles occurred on new tires. It's only the replacements which were used.
01-04-2015, 06:50 PM | #26 |
Rep 2,867
Can you claim some type of defect warranty on the tires if they were new?
01-04-2015, 06:58 PM | #27 |
Rep 12,565
Not really, I think you would've had to purchase some tire replacement insurance which I rarely do. In all the years I've been driving this is the first time I've had an issue like this. And not to mention the fact it's happened on 3 tires, and 2 different models it doesn't seem to be a tire [defect] issue.
01-07-2015, 08:38 PM | #28 |
I plead the 5th.
523
Rep 1,519
It may sound crazy but I'm going to chalk this one up to coincidence assuming you're *certain* you didn't happen to hit anything. Can't see any other factors at play here.
I once knew someone who's fitment was so aggressive/they rubbed so much they actually created a sidewall bubble that then blew out. You don't have any rubbing on your setup at all, correct? Nothing that could pinch the sidewall?
-Matt
01-08-2015, 10:41 AM | #29 | |
Rep 12,565
I'll try running different air pressures. Blegh... |
01-08-2015, 11:13 AM | #30 | |
I plead the 5th.
523
Rep 1,519
-Matt
