Go Back   ZPOST > Marketplace > Sponsors Classifieds
      01-19-2018, 05:50 PM   #1
Expert@ApexRaceParts
Expert@ApexRaceParts's Avatar
403
Drives: M3
► APEX | 18 FL-5 & SM-10 Group Buy - Up to $300 OFF + Free Shipping
This group buy has ended, thank you all for your participation!
If you missed out, check out our current active group buys here.
      01-22-2018, 11:32 PM   #2
jns_e85
jns_e85's Avatar
25
Drives: 2004 z4 3.0i & 2006 z4M
Curious if a 18x9.5 et 35 SM-10 square set up would work on Z4M with 265/35/18 or 275/35/18 RE-71R tires for autocross.
(Currently on stock suspension with camber bolts, -2.8 front camber and -2.0 rear camber)
2006 Z4M - Epic Tune / Turner Pulleys / Eventuri / Euro Headers / Section 1 / Custom Stromungs / FA 500 + Camber Bolts / VT Engine Mounts / RE Trans Mounts / AS SSK / Arc 8s
2004 Z4 3.0i - Koni Yellows / Style 224s / AFE / Stromung Exhaust / Z4M Engine Mounts / M3 Trans Mounts / Beisan VANOS / GAS DISA
      01-23-2018, 02:10 PM   #3
403
Drives: M3
Thanks for the post! With your alignment, that setup would work perfectly with 265/35-18 tires. It may be necessary to add a 3mm or 5mm front spacer for suspension clearance as well, and a 12mm spacer in the rear is recommended for aesthetics.
The 275s may work too, but additional negative camber up front may be required to prevent rubbing.
jns_e8524.50
      02-02-2018, 08:49 PM   #4
403
Drives: M3
This is the biggest discount we'll likely ever offer on our new designs. Join now to secure your spot.
      02-07-2018, 02:40 PM   #5
403
Drives: M3
It's free & easy to join the group buy. There is no obligation to purchase and no up-front costs. And if we don't reach your required discount, you won't be charged at all. If we reach a higher discount than what you select, you'll save even more.
Let us know if you have any questions!
      02-09-2018, 08:58 PM   #6
403
Drives: M3
We have 33 pledges for this deal so far, and we only need 7 more to reach the maximum discount and guarantee $300 off to everyone who signs up!
There are 6 days remaining so help us spread the word!
      02-12-2018, 04:31 PM   #7
403
Drives: M3
We're now at 38 pledged with only 2 more needed to hit a guaranteed $300 off with only 3 days remaining!
Go here to sign up for this deal: https://www.gangup.com/apex/apex-18-...s-q1-2018.html
      02-15-2018, 05:53 PM   #8
403
Drives: M3
Great news! We've hit the max discount on this deal and we can now guarantee $300 off plus free shipping in the continental US.
This deal ends tonight so be sure to get your pledge in and reserve your set.
Search this Thread:
Advanced Search
