08-08-2013, 11:25 PM | #1 |
Rep 2,882
GROM Audio USB interface installed
After a few email exchanges with GROM Audio, we still cannot verified whether their BMW/Mini USB adapter (GROM-USB2P-BMWT) would work on my '08 MCoupe as their website have our cars listed as having the MOST bus, which isn't true. Also, I wasn't sure if I needed their DSP adapter either. Since they have a 30-days return policy, I decided to give it a shot and just ordered the unit by itself without the DSP adapter. As expected, it worked, but not without a few minor bugs.
Installation was quite straight forward. After taking the rear covers apart, I spent the most time looking for the 3 & 6-pins connectors. Found them taped to the body of the car behind the AMP, which is where I ended up stashing the GROM unit. My car has DSP, but it worked without needing their DSP adapter. The unit did come with a USB extension cable, but I found a Logitech extension cable that had a nice base, which provided a good surface for taping it to the console area. The extension cable was fed through an access hole under the center console by removing the breakout tab. The 32G flash drive will provide enough music that I don't think I will hear a repeated song for quite some time. Music is organized by making 6 main folders - 1 for each "CD". You can have as many subfolders as you wish, the unit will just flatten them all out. The unit isn't perfect...so now comes the bug list:
A Minor gripe about the text display...it's horrible as it can only display 10 characters and it toggles back & forth between Artist & Title. I'm hoping that GROM can correct this so it will display MP3 tags similar to the OE CD Player. I've reported these minor bugs to GROM, and hopefully, they can provide a cure for them. Overall, I'm very pleased with the unit. Last edited by XMetal; 08-08-2013 at 11:36 PM.. |
03-25-2018, 05:09 PM | #2 |
Rep 145
I know this is an old post, but I wanted to thank you for it. I was struggling with this install since GROM insisted i needed the DSP adapter. I couldn't get any audio for the life of me to work with the DSP adaptor. I stumbled across your post and tossed the DSP adaptor. What do you know...it all works now. iPhone 6s connects, charges and I get audio from it.
Thanks!!! |
03-25-2018, 06:57 PM | #3 |
Rep 2,882
You're very much welcome. That was my whole point of posting this, is to help others that may want to add this "feature" to our archaic infotainment system. Do you have NAV? If so, I was wondering if GROM had fixed some of my gripes?
03-26-2018, 09:55 AM | #5 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I have the USB3 unit and can confirm the 10 character limit for songs is still there. It's unfortunate GROM has not updated that.
2008 Z4 3.0si Coupe
03-26-2018, 01:10 PM | #6 |
1821
Rep 5,337
Lifesaver! XMetal you rock, and thank you SDMCoupe for bumping this up.
I just received my GROM trunk unit and realized what I probably wanted to install was the GROM behind dash, because originally I didn't think I'd be able to run the cable through to the front. This literally popped up at just the right time.
05-19-2018, 02:52 PM | #7 |
Rep 215
I am also thinking about getting this unit for my m coupe. I don't have the cd changer pictured and don't have NAV. Do I need those for this system to work?
And the USB cord you have coming out of it can be used for an Apple charge cord right? Info online about this product seems vague. Any guidance would be greatly appreciated. |
05-19-2018, 03:48 PM | #8 |
Rep 2,882
I don't have a CD changer either. The picture you see is the DVD drive for the NAV. You don't need to have NAV. I actually have 2 of these units - one on the Mcoupe, which have NAV and DSP and one for the X5, which does not have NAV nor DSP...it works in both.
I have actually never plugged anything in other than USB thumb drives, so I can't comment on it about charging. |
05-19-2018, 05:13 PM | #9 | |
Rep 215
05-19-2018, 07:22 PM | #10 |
1821
Rep 5,337
It charges my iPhone X just fine. Slow, but it charges.
ShawnPaul109.50 |
06-03-2018, 08:10 PM | #11 |
Rep 932
A little late for me. Not sure why I didn't find this. I was looking at Grom and wasn't sure it will work. I end up installing Intravee II. It was a pain removing center console to route cable to front.
06-22-2018, 02:09 PM | #12 |
Rep 1,248
One question I have - can you use a thumb drive AND bluetooth? Or does the Bluetooth dongle have to go into the only usb port? I'd like to have my songs on a thumb drive, but have the option to connect my phone when I want to for music or map guidance through the speakers.
Looks like these are more preferred over the Dice units
06-25-2018, 10:19 AM | #13 | |
Rep 162
Here's a diagram from their site:
2008 Z4 3.0si Coupe
06-26-2018, 08:18 AM | #14 |
Rep 1,248
OK - that makes sense. I can use the thumb and bluetooth at the same time, but can't connect directly to my phones while the thumb is in - which should be fine if I have a bluetooth connection anyway. Sounds like I have a new project to add to the list.
07-31-2018, 07:12 PM | #15 |
Rep 1,248
OK - so update for anyone wanting to do this - if you have an earlier E85 with a DSP system - good chance you will need the adapter. Before you order (unlike me) pull your carpet up and look for your connectors. If instead of a 3 pin and 6 pin connector like above....if you have a 3 pin and a coax - you will need to adapter to make this work. I have no 6 pin at all and after lots of searching - I see other with the same issue and why this adapter was made. You also have to tap power and ground with it - so not exactly plug and play like the 3/6 pin set up. Since my amp is in the battery well, I am not sure where I am going to tap acc power from, but I can either run a wire or maybe tap into the BMW assist deal?
I'm sure I'll figure it out - but FYI if you are reading this - check your connectors before you buy!
08-09-2018, 02:34 AM | #16 |
Rep 3
Groom working om Head unit without amp/DSP?
Hello!
I have a 2003 Z4 with the "Navigation system professional". 6 speaker setup with no amp or DSP. Will the Groom USB still work for me? Kind regards Jens |
11-01-2018, 08:00 PM | #18 |
your average JAMF
3194
Rep 4,116
I had a BMW CP600 in my original Z4MC. It was pretty cool - connected to the CD changer cable, supports an SD card, similar navigating & display to the Grom unit. But it didn't SOUND good. MP3 tracks played via the CD player sounded very noticeably better at the same bitrate than what came through the CP600. This is the little bugger I'm talking about...
https://www.maintronic.de/en/shop/cp...d-karte-detail Anyways.. my "new" Z4MC will be here soon and I'm trying to figure out what I'm going to do for tunes. My preference is just to load up a USB stick and slap it in the boot next to a Grom and be done with it. So my question for you guys who have a Grom - how does the USB output sound? Is it equally clean & clear as what you get from the CD player?
'21 M2 Comp
'19 Golf R |
11-01-2018, 10:27 PM | #19 | |
Rep 162
One thing I'd recommend is if you must play music via USB, put it on a media player like an iPod or MP3 player. The reason is that organizing and navigating a USB flash drive full of music is cumbersome. If there's a playlist or a song you have to play, it's easier to find it on your device than to use the GROM's built-in file navigation via CD changer "discs" (see page 12 of the manual here and you'll know what I mean).
2008 Z4 3.0si Coupe
11-01-2018, 11:44 PM | #20 |
your average JAMF
3194
Rep 4,116
Thanks Koruptor. I've read the Grom manual, navigating media is basically the same kludgy process as it was on the CP600. I will simply load up a USB stick with several long playlists and be done with it, so navigation won't be problematic. If I want to hear complete albums or anything not on the stick, I'll just hook up my phone via the aux port and roll that way - but I don't want to fumble with it all the time, hence looking for a Grom-type solution as well.
I could opt to connect something like an old iPod nano, but I don't think there's enough juice to keep it charged. The USB stick solution means I can just leave it there and forget it.
'21 M2 Comp
'19 Golf R |
11-05-2018, 09:00 AM | #21 |
Rep 145
Has anyone been able to get audio when connected to a Samsung S9+ or similiar? I get audio out of iphone but nothing from the S9. I've updated per Grom's instructions but nothing has worked yet.
