06-28-2019, 01:59 PM | #1 |
Rep 347
aux\bluetooth adapter for stock radio?
Hi, new to this part of the forums, I just purchased an 06 Z4 roadster 3.0i for my daughters 16bday (her 1st car). Car has no aux port, after reading the forums for a while I came across this aux port for the ash tray but I cant find anyone that sells it anymore. by chance does anyone know where I can find one
BMW 82-11-0-142-174 https://www.amazon.com/BMW-82-11-0-1...4B3P4SWXXTJF80 Or has anyone ever tried bluetooth adapter for stock radio like this https://www.amazon.com/Bluetooth-Rec...teway&sr=8-103 https://www.ebay.com/itm/Car-Bluetoo...8AAOSwLdJcnY21
07-21-2019, 05:35 PM | #2 | |
Rep 2
09-11-2019, 09:57 PM | #4 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
Your daughter is very lucky and welcome to this corner of the forums!
There are many threads on this topic. The option I went with was installing the GROM USB-2 unit w/ BT adapter (may require a different setup/option for your specific car). The GROM retains stereo and steering wheel controls. It was a hassle to install but well worth it in my opinion. If you simply want Aux, you don't necessarily need the ashtray setup. Check out P/N 84109237655 (AUX Socket) and 51459128397 (cover). But before you go buying these, triple check if you already have one installed. You'd be surprised how well hidden it is.
2008 Z4 3.0si Coupe
10-02-2019, 07:14 AM | #5 |
Rep 8
i got an AUX IN "kit" from my local dealer in Australia no hassles. Lots of the specialist US shops should have them. easy to install. where you put the socket is up to you. the instructions suggested in the glovebox, but i fitted mine in the lower switch panel. works perfectly
