      07-14-2013, 02:57 PM   #23
BMW Maniac
Drives: Former Z4M coupe owner
Because VF claims the kit to produce 570 hp to the crank....which is why it is named as such. But I do agree, you should expect at least 10 hp/pound of boost
      07-14-2013, 03:46 PM   #24
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by Endless619 View Post
But lets say a stock E86 M dynos at around 270 hp to the wheels. Slap on a 100 hp SC kit and he should be at 370 hp. I dont see whats wrong with that. Are some of you folks claiming the kits give an added 200-300 hp?
If my mind serves correctly the VF SC for the S2000 and the SC kits for the NSX only gave you about 80-100 extra hp with the bolt on kits, with tune.
Multiply your base horsepower by the ratio of the pressure increase. Atmospheric pressure on a standard day is 14.7 psi.
270whp x [(14.7 + boost_psi) / 14.7]
A ballpark estimate is 435 whp, not including variables such as drag, heat, tuning, efficiency ranges, or modifications in the exhaust. It is a quick down-and-dirty estimate. Considering the OP's mods, he's putting down similar power to a kit running 6 psi, not 9 psi.
If your pressure at the throttle bodies is 9 psi, I would start looking at the other factor - the engine and exhaust. It could be something mechanical (maybe a clogged cat) or the supercharger's tune. If AFR's look correct and the everything else that's external checks out, I would consider a compression/leakdown.
      07-14-2013, 04:06 PM   #25
Endless619
DHS
Endless619's Avatar
Got ya. Thought these kits were similar to the kits we had 10 years ago on our Hondas. Just a bolt on 80-100 hp.
2023 BMW M4
2016 X3
      07-14-2013, 05:33 PM   #26
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Yes sadly, RatedMRoadster is pulling 470+rwhp and 330+rwtq with the same hardware and software, hence why I'm so disappointed
I know Andrew's car has two cats LESS than mine, but that shouldn't account for my loss of 80-90rwhp
      07-14-2013, 07:39 PM   #27
seank
enthusiast
seank's Avatar
48
Have you recorded the timing to see if its taking it out due to pinging.
      07-14-2013, 08:09 PM   #28
mfanatic325
///M-fanatic
Taiwan
193
Not sure if VF did it while my car was in their shop :/
      07-14-2013, 08:55 PM   #29
seank
enthusiast
seank's Avatar
48
P3 gauge can do it and very affordable. It may give you some data.
What did they change while you were there and what do they say about your numbers? How did they tune it, if they didn't dyno it while you were there to see the numbers weren't fixed?
      07-15-2013, 12:10 AM   #30
mfanatic325
///M-fanatic
Taiwan
193
I have the P3C Gauge, but I always have AFR on rather than any other set of data.
VF said that they found throttle linkage hindered, some loose couplers, check valve, and other miscellaneous missing items when I bought from EAS. They tweaked my tune so that it wouldn't run so rich, and did before-and-after dyno on their in-house Mustang dyno. The improvement was significant, and car smoothed out a bit driveability-wise, but evidently not as strong as RatedMRoadster's car
      07-16-2013, 06:08 PM   #31
mfanatic325
///M-fanatic
Taiwan
193
Good news! VF says that they've been digging through their records and have found that my particular charger unit seems to be an old one with different impeller and stuff. They're going to send me a new unit free of charge since they for whatever reason didn't think about checking the serial plate on the charger last time when I was there in their shop in person
      07-16-2013, 06:20 PM   #32
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
That's great news! So you weren't making the same boost and it wasn't apples to apples with Rated's car.
You're probably going to want to change the tune. Isn't the one you're running custom-dynoed to the funky s/c?
      07-16-2013, 06:22 PM   #33
Z4inAZ
Drives: Z4 2.5 03
Seems like a bit of an oversight on VF's part but at least they are fixing the problem
      07-16-2013, 06:49 PM   #34
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
That's the most important part. To buy from a supplier that wants to deliver a good working system, and when things dont run up to specs keep digging until the problem is solved. (all these kits are alway's 'somewhat experimental')
That they oversee a compressor serial plate.....things happen.
      07-16-2013, 06:55 PM   #35
seank
enthusiast
seank's Avatar
48
But you said it made the correct boost? So, what is the new charger going to do?
      07-17-2013, 02:20 AM   #36
mfanatic325
///M-fanatic
Taiwan
193
Yeah it was up on boost, so I'm not sure what exactly the difference(s) will be
But I'm hoping for good numbers thereafter
      07-17-2013, 09:42 PM   #37
dre99gsx
Drives: 1994 Toyota Supra
If it was the older V3 series, they flow less at the same boost. That could account for the loss. I had read someone else on this forum had the same thing happen (may want to search).
This guy had similar incompatibility issue with an older VF charger
But, I thought EAS's kit was the "newest" version since it seemed to have been fairly recent? Not sure... worth investigating how long they had that kit before selling it.
      07-17-2013, 10:11 PM   #38
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
http://www.zpost.com/forums/showpost...0&postcount=34
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      07-17-2013, 10:36 PM   #39
dre99gsx
So this is the VF420? Confused
      07-18-2013, 01:02 AM   #40
mfanatic325
///M-fanatic
Taiwan
193
EAS originally had the 420 kit, then upgraded to the 570. Maybe that's where VF lost track of the history on this kit?
But yes, I strongly believe that my charger kit is flowing much less air at the same boost as the proper charger unit that I'm supposed to have.
Only one way to find out, and that's to get the charger units swapped out and go for a redyno
      07-18-2013, 05:01 PM   #41
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
This may make sense now
instagram: @ dubsesd
      04-16-2014, 02:19 PM   #42
mfanatic325
///M-fanatic
Taiwan
193
Never updated this thread. So, fast-forward a little over half a year or so.............
VF has rescinded their offer to update my blower for me, saying that they used to be able to make a little money off selling user blowers to an unnamed client, but they no longer purchase used blowers. They claim that it's a little over $400 to update the blower trim, but I haven't been able to contact the proper personnel over @ Vortech so I'll get to it eventually maybe.
But more importantly, I've since ditched VF's shitty in-house tune and went with a custom tune by Frank Smith. Frank and I are currently in on the third datalogging trial and the car has improved tremendously in both drivability and power output. Once everything's good to go, I will schedule for another dyno session at a local race shop that has a Dynojet. Will update thread when necessary
      04-16-2014, 04:05 PM   #43
chickdr
Drives: 2006 M Roadster
So they sent you an outdated/inferior kit and won't stand behind it? It is really even a 570 S/C unit? I would have tended to remove the kit, send it back and refuse payment(if you paid via CC). That is some crap CS by VF. Glad you are getting it done on your own.
      04-16-2014, 05:39 PM   #44
Rated M Roadster
160
At least you know what's going on... He bought the kit used; not from VF.
