      08-03-2017, 08:06 PM   #1
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
[Price Drop!] VMR V703 VB3 CSL Matte Black 18x9.5 +22/+33 Z4M
USD 500.00
I have a set of four VMR V703 VB3 CSL style wheels in Matte Black for sale that will be coming off my car in the next couple weeks or so. No issues with them at all - no curb rash or mounting damage, these wheels look new. These are deep concave CSL style wheels that will accept OEM BMW centercaps if you want an extra OEM look.
Asking price: $500
Can have these shipped for $100
Front: 18x9.5 ET33 5x120 72.6
Rear: 18x9.5 ET22 5x120 72.6
I ran these wheel specs with 255/35/18 front & 265/35/18 rear. I used 7mm spacers up front due to having rolled and lightly pulled front fenders. This staggered offset spec allows you to run 265/35/18 tires front and rear without much work per Apex wheels tech article here -> http://www.myapexparts.com/2012/05/1...t-ec-7-wheels/ They mention that camber plates are required, however I didn't find this to be the case (then again, my car gained a fair amount of camber when lowered).
Regarding front inner clearance on 9.5 ET33. Again, I didn't need camber plates but this is still important to consider:
The rear fitment is a direct bolt on, but the front fitment requires camber plates, and a suspension that can properly clear the wheel and tire. It is important that the lower spring perch remain above the tire. If the spring or perch is next to the tire, then a thick spacer may be required for clearance which makes the fitment far too aggressive. A 5mm spacer would be acceptable, but anything thicker would push the setup too far out. The stock strut’s integrated lower spring perch can clear the 265 setup, so a simple lowering spring and camber plate install can make for a very ideal track setup on the Z4 M.
Pics yanked from this thread -> http://www.zpost.com/forums/showthread.php?t=1391278 Will post individual wheel pics when they're off!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-08-2017, 04:25 AM   #2
Slickback_Ben
The Builder
Slickback_Ben's Avatar
Drives: 06 Z4MC
Hey Matt, these wheels you're selling come with tires? I may be interested, just gotta check if they would fit my GTI.
06 Z4MC
H.N.I.C. Don't ask what that stands for
      08-16-2017, 12:31 PM   #3
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Ah, definitely won't fit the GTI unfortunately
No tires included, but now have new wheels on so price drop to help move these
-Matt
      11-07-2017, 04:10 PM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Still have these bad boys in storage & ready to sell!
-Matt
      12-05-2017, 03:57 PM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Help me make room in my storage
-Matt
      12-06-2017, 07:37 AM   #6
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Buy with confidence. Good bloke this guy.
      12-20-2017, 09:50 PM   #7
Waoudi
Waoudi's Avatar
Drives: '17 X5 MSport, '16 M3 ZCP
Will they fit 07 z4 3.0si ?
      12-27-2017, 11:39 AM   #8
tiltmode43
I plead the 5th.
tiltmode43's Avatar
As far as I know, this fitment will only work with the Z4M platform - not so sure about 3.0si. Thanks for the interest though!
-Matt
      12-27-2017, 12:26 PM   #9
Steeler
Steeler's Avatar
2428
Just to add.
On my 04 3.0i I found et35 F8.5 R9.5 was optimum with a 1.5" drop. Front could have done with a 1/2" spacer maybe.
Here is a handy calculator
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
      01-16-2019, 11:53 AM   #10
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Boomp! Still have these :-)
-Matt
      01-17-2019, 03:09 PM   #11
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Originally Posted by dbarton62 View Post
Just to add.
David, should I buy them , sounds like very good deal for such brand
      01-17-2019, 03:24 PM   #12
Steeler
Steeler's Avatar
2428
Not sure they would fit Andrey
Put the specs I noted above and the OP’s specs in the calculator and see what the results are
