Go Back   ZPOST > Marketplace > Sponsors Classifieds
      09-14-2011, 11:41 AM   #1
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Jlevi SW | *NEW* Mechunik Magnetic Oil Drain Plug
As a new engine works itself in, and thereafter, it produces metal particles that get collected in your oil pan. These particles can be the size of a grain of sand or the as large as a splinter. When these As your oil pump pulls oil from the pan, it reintroduces these particles into the cars engine components, seals and filters. With the Mechunik Magnetic Oil Drain Plug you can gather most of these harmful particles and easily remove them from your engine by simply pulling out the plug and cleaning off the magnet holding the particles. Do this with every oil change for the best results. DO NOT USE AIRTOOL TO CLEAN PLUG.
Each plug comes with a copper washer that needs to be installed along with the plug. When you buy an OEM oil filter for your oil changes it comes with a replacement copper washer. Replace this washer with each oil change.
Fits the following vehicles:
(also any vehicle with a M12 x 1.5 metric oil plug size)
The BMW 1 series
E87 1 series (2004 - present) 116i, 118i, 120i, 130i
The BMW 3 series
- E30 3 series (1982 - 1994) 316i, 318i, 320i, 325i
- E36 3 series (1990 - 2001) 316i, 318i, 318is, 320i, 320is, 318ti, 323i, 323is, 325i ,325is ,328i ,328is ,M3 3.0 , M3 3.2 ,
-E46 3 series (1998 - present)
318i, 318ci, 320i, 323i, 323ci, 325i, 325ci, 328i, 328ci, 330i, 330ci, M3
- E90 3 series (2005 - present) 325i, 325ci, 325xi, 330i, 330ci, 330xi
The BMW 5 series
- E34 5 series (1987 - 1996) 518i, 520i, 525i, 535i, 540i, M5 (Does not fit 530i)
- E39 5 series (1995 - 2004) 525i, 528i, 530i (2001 and up),540i, M5
- E60 5 series (2003 - present) 525i, 525ix, 530i, 530ix, M5 V10 5.0 (does not fit 545i 2005> and 550i 2006>)
The BMW 6 series
- E63 6 series (2003 - present)
(does not fit 645ci and 650ci)
The BMW 7 series
- E32 7 series (1986 - 1994) 735i, 735il, 740i, 740il, 750i, 750il,
- E38 7 series (1994 - 2001) 740i, 740il, 750il,
- E65 7 series (2001 - present)
(does not fit 745i, 750i, 760i)
The BMW 8 series
- E31 8 series (1989 - 1999) 840ci, 850i, 850ci, 850CSI
The BMW M series
- E26 M1 (1979 - 1981)
- E30 M3 (1985 - 1992)
- E36 M3 (1992 - 2000)
- E46 M3 (2001 - present)
- E28 M5 (1985 - 1987)
- E34 M5 (1988 - 1995)
- E39 M5 (1998 - 2003)
- E60 M5 (2005 - present)
- E24 M6 (1983 - 1989)
- E63 M6 (2005 - present)
- Z3 M Coupe (1998 - 2000)
- Z3 M Roadster (1997 - 2001)
- Z4 M Coupe (2006 - present)
- Z4 M Roadster (2006 - present)
The BMW X series
- E83 X3 (2003 - present) 2.5i and 3.0i engines
- E53 X5 (1999 - 2007) 4.4i 1999-2004 3.0i 2001-present
(does not fit 4.4i from 2005 and up)
The BMW Z series
- E30 Z1 (1987 - 1991)
- E36 Z3 (1997 - 2002) roadster 1.9,roadster 2.5,roadster 2.8, M roadster 3.2 (coupe)
- E85 Z4 (2002 - present) roadster 2.5 ,roadster 3.0
- E52 Z8 (1999 - 2003) Z8 5.0
For Pricing and Ordering Information:
P: 1.888.JLEVISW (553.8479)
E: sales@jlevisw.com
W: http://www.jlevistreetwerks.com/
Retail Location:
Jlevi Streetwerks, Inc.
2942-2944 Scott Blvd
Santa Clara, CA 95054
Operating Hours:
M-F 9am-5pm PST
Payment Options:
Follow Us:
