      09-14-2010, 03:26 PM   #1
German Villa
Drives: 2003 Z4 2.5 Blue
Muffler delete on a 2.5 auto?
so i would love a little more sound on my 2003 - 2.5 roadster but unfortunately my car is an automatic...... do you think if i remove the muffler would it sound "stupid"?
      09-14-2010, 04:19 PM   #2
Incompatible
Drives: 07 AW Z4C 3.0Si
http://www.zpost.com/forums/showthre...muffler+delete
Good read.
      09-14-2010, 09:23 PM   #3
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Auto will drone like a bitch
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      09-15-2010, 09:35 AM   #4
German Villa
It was good read however didnt mentioned if it was automatic.....have anyone done this to an "Automatic"? i am dying to know how the sound will be...thx
      09-15-2010, 09:26 PM   #5
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
i had it done to mine not to long ago. its a manual, and it doesnt drone that bad. I can take a video if you would like
      09-15-2010, 10:12 PM   #6
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
If you're going to do this, I would suggest doing it in stages. Leave the resonator first and see how you like the Magnaflow. If you want it louder then remove the resonator.
I replaced my '99 323i's muffler with a Remus and needed a bit more so I removed the resonator after. Having seen me go through this, a friend of mine used Magnaflow on his 328i and removed the resonator at the same time. However, the Magnaflow is wayyyyy louder than the Remus and he ended up geting the resonator re-welded because he couldn't stand it.
But of course, exhaust sound is a personal thing. My MCoupe's exhaust is just right for me at this stage in my life so it's staying like that .... for now at least.
      09-15-2010, 10:19 PM   #7
The__J__Factor
Australia
88
Drives: ///M Coupe
Its just that its an auto, and autos like to spend most of their time lazying around low revs or holding it there. Which is usually drone city.
135i N54 manual
      09-16-2010, 10:27 AM   #8
2288
why not take out the midpipe muffler instead? or replace that with glasspack and slap on a magnaflow at the end.
      09-16-2010, 11:27 AM   #9
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
If I remove the resonator, will that add sound and will that effect performance?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      09-16-2010, 11:55 AM   #10
Incompatible
If all you do is to remove the resonator and leave the oe muffler in place, you should have a small increase in sound level/quality and no noticeable performance difference. If you have already removed the muffler, then the difference in sound increase/quality is more noticeable.
The presence or absence of your oe muffler has the greatest effect on performance, if any. I don't have first hand experience with this; comparative before and after dyno runs. There are plenty of individuals on the forums who will tell you: yes, no, somewhat...... I don't know. One thing to keep in mind however, is this is a street driven car and what you want in terms of "performance" is different from a race car.
      09-16-2010, 12:18 PM   #11
German Villa
which one is the midepipe muffler?
      09-16-2010, 03:45 PM   #12
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Thanks Inc . I would like a noticeable difference in performance, but will be content with a small increase in sounds especially considering that replacing the resonator with a pipe shouldn't cost much. I plan on getting a full cat-back exhaust down the road.
      09-20-2010, 08:47 AM   #13
German Villa
If you have a video would be awesome. did you do the muffler and resonator delete? thx
      09-20-2010, 08:51 AM   #14
German Villa
Does anyone knows what "Magnaflow" fits the Z4? Part #??? thx
      09-20-2010, 09:30 AM   #15
Incompatible
If you're going with dual in/out and install before the resonator or remove the resonator, and run straight pipes out the back, then #11378 or 11385 should work. If you're going to replace the rear muffler (axle back) only, then #11366 should work. There are other combinations which will work depending on where and how you want to do the install. One thing to keep in mind is that coupes tend to have a bigger problem with drone then roadsters due to the large "resonance chamber" trunk space they have. Get under the car, take measurements, and work from there.
My advice is to find someone who has the sound quality and volume you want and duplicate that system. You Tube posts are almost worthless due to the variations in recording conditions and equipment. AND, what sounds good to one person is a headache to another.
      09-20-2010, 10:58 AM   #16
German Villa
Thanks a lot. Looks like the muffler delete part #11366 is the best option for me. i do not want it too loud. Mine is a roadster but unfortunately is automatic but i still want to hear something..
