      07-14-2014, 07:42 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
H&R riding harder and harder
Not sure if I'm getting older, but it seems like my H&R coilovers have gotten much tighter over the 20k miles that I had them. I'm on 275/35/18 tires, so I have some sidewall.
One of the shocks had a small leak, but has stopped, and the others are fine. When the car is stationary, and I press hard on the corners, the suspension is stiff and bounces back immediately on one bounce.
Is there something wrong with the shocks, or are there any other tests I can perform?
Right now I'm just about to raise the car up another half an inch...
      07-15-2014, 01:40 AM   #2
donoman
Rookie
31
Drives: 03 Z4 2.5i 5MT
Man those wheels look great. What fitment?
Regarding your shock leaking and stopping leaking ... whats up with that? Are you sure it's not out of juice?
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-15-2014, 04:05 AM   #3
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Well if your shocks were leaking, that would mean a blown shock, and that could be why.
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      07-15-2014, 09:46 AM   #4
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
You have done the proper test already. A bouncy corner means the shock is no longer doing its job.
The leak that stopped means the shock is finally dry inside.
      07-15-2014, 06:20 PM   #5
ZStig
279
so what are the symptoms of a "dry" shock? would it be more bouncy, or get really stiff?
      07-15-2014, 06:21 PM   #6
ZStig
279
thanks. in this picture its 18x9 et 20 rear and et 28 front. 265/35/18 all around
currently have 275/35/18 on front, which rubs, so I want to raise it a bit to help with ride and rub
      08-14-2014, 09:19 AM   #7
3002 tii
3002 tii's Avatar
2282
When he says dry, he means all the fluid has leaked, that's why the leak has stopped. No fluid means no rebound damping, hence the bounce. Bouncy means time for new shock.
Follow for latest mods
      08-14-2014, 09:31 AM   #8
Beedub
20k miles and you need new shocks... not really what i expect from H & R, i would be looking for some sort of goodwill.
Kw units are rebuildable... Are these??
      08-14-2014, 09:40 AM   #9
3002 tii
3002 tii's Avatar
2282
Depending on road conditions, I believe it. OE shocks probably lose effectiveness around 40k and whenever I see aftermarket shocks being sold on classifieds, they usually have 20k on them (convenient time to sell) or owners will even state how one is in need of rebuild.
