      05-28-2014, 09:59 PM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Probably dumb question about bleeding brakes
I was planning on using a turkey baster or pump to remove the old brake fluid in the reservoir, but there's a screen blocking the entrance... how do you guys get rid of as much old fluid as possible before flushing with new fluid? Do you remove the screen somehow?
Also, I'm probably going to buy a Motive pressure bleeder to do the task. I have no compressor to run a vacuum bleeder. Any other tips/suggestions?
      05-28-2014, 10:29 PM   #2
The HACK
The HACK's Avatar
1821
Pull the screen out.
      05-28-2014, 10:38 PM   #3
intoflatlines
It's too simple!
      05-28-2014, 11:13 PM   #4
The HACK
The HACK's Avatar
1821
The screen is on a "cup" with 3 bumps that holds it to the lip of the reservoir. Remove the screen and you can remove most of the fluid in the reservoir with a syringe or turkey-baster.
I have the pressure bleeder from BavAuto and find the pressure release valve and the quick connect invaluable. I used to have a Motive and gave that to a friend after I bought the BavAuto bleeder.
      05-29-2014, 08:41 AM   #5
intoflatlines
Good advice, I'm ordering the Bav one and a couple of liters of Typ 200 now.
      06-04-2014, 08:16 PM   #6
rsutoratosu
Drives: Z4 3.0i
how much fluid to complete bleed all 4 corners ? and whats good ? regular generic dot 3 or find something better ?
-Roranji
      06-04-2014, 08:35 PM   #7
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
The ///M uses DOT4...not sure about non-M, but assuming would be the same. I did a complete bleed on all 4 corners plus clutch using less than 1L with plenty to spare.
      06-04-2014, 11:56 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
I divided up a liter, assuming a flush, as Hack points out below:
Reservoir 300 ml
RR 200 ml
LR 150 ml
RF 150 ml
LF 100 ml
Clutch 100 ml
Just rough guesses. Used Motul 600 and Speed Bleeders.
      06-05-2014, 12:01 AM   #9
The HACK
The HACK's Avatar
1821
Bleed or flush? Bleed takes less than 500ml if there's not a lot of air trapped in the line.
Flush take about 1 liter.
