08-10-2017, 04:12 PM | #1 |
Rep 662
When to change battery?
Ok so my Z4MC is a 2008 model and still has the original battery. Car has 62k kms.
My battery light and some other lights flashed flashed for a couple of seconds while I was driving it the other week. I had recently been overseas for 4 weeks so disconnected the battery while I was away. Did it have something to do with the battery disconnection, or should I be replacing it? I check the voltage last night, results were: 11.9 with car off. 14.1 to 14.3 with car on and all lights, hazards and air conditioning on fall. I would appreciate any comments. Thanks
Current: Z4MCoupe, Interlagos Blue, Carbon Extended Leather, Sat Nav, Heated Seats, Supersprint Exhaust, BBS CH19's, Stubby Aerial. AND E82 1M, Alpine White
Sold: 3 x 130i (White, Red & Black), Mk4 VW Golf R32, '03 Reno Clio Sport |
08-10-2017, 04:32 PM | #2 |
636
Rep 3,124
9 year old battery? I would say it's had a good run.
5 years is more typical. Make sure to get a size H6. Some auto chains list H5 for the ///M, which is incorrect.
mr_z4mc1m_oz271.50 |
08-10-2017, 04:39 PM | #3 |
Rep 662
Yeah that's what I think. I'm just going to get a genuine BMW battery. $500 here in Australia.
08-10-2017, 04:45 PM | #4 |
Rep 2,665
There's no point in doing this, BMW doesn't make batteries and all of the extra cost is the "BMW" on the label.
08-10-2017, 05:26 PM | #5 |
Rep 662
BMW quoted me for a 70 AGM battery
08-10-2017, 05:32 PM | #6 | |
Rep 3,004
Racerbruce
08-10-2017, 06:19 PM | #7 | |
636
Rep 3,124
They run about $175 U.S. here from the major chains. I think that's maybe 220 OzBucks?
08-10-2017, 06:33 PM | #8 | |
Rep 662
BMW want $560, but my mate that works there can get it for $500.
08-10-2017, 06:50 PM | #9 | |
701
With a battery of that age don't be surprised to find a lot of corrosion on the battery cables unless you've been super diligent about cleaning/protection. I let one of our batteries go 7 years. Big mistake. I spent a good several hours addressing the corrosion issues on cables. A new set of cables is, IIRC, 500-600 USD, not cheap, not easy, not fun. I've now added a 6M check/corrosion prevention approach to the care/feeding schedule. |
08-10-2017, 08:14 PM | #10 | |
Rep 662
Aren't these voltage readings perfectly normal? 11.9 volts when car switched off 14.1 to 14.3 volts when car on with everything turned on i.e. lights, high beams, air con full blast, stereo on, interior lights on.
08-10-2017, 08:21 PM | #11 | |
Rep 820
Drives: 2007 Z4MR silver grey
08-10-2017, 08:23 PM | #12 | |
Rep 820
08-10-2017, 08:25 PM | #13 |
Rep 2,542
The way to acuratly measure the voltage is to charge the batt with a good quality agm charger, then disconnect the batt and let it sit at least overnight, then measure the voltage. Chart voltage chart for AGM batt
08-10-2017, 09:09 PM | #14 | |
Rep 662
Therefore based on that chart it seems like its at 30-40%. So sounds like time to change battery
08-10-2017, 10:19 PM | #15 |
636
Rep 3,124
Another reason not to let the battery get weak is that our cars have a very bad reaction.
The car won't tell you that the battery is weak. It will go into limp mode and tell you that all manner of things are wrong with the fly-by-wire throttle system (EML).
Finnegan701.00 |
08-10-2017, 10:27 PM | #16 |
Rep 662
Battery ordered.
Finnegan701.00 |
08-11-2017, 08:25 AM | #17 |
Rep 1,989
08-11-2017, 08:34 AM | #18 |
Rep 2,665
As someone that rarely drives his car (at most on the weekends) I use the Battery Tender to help save the battery and the alternator. When I start the car the battery is fully charged and there is very little for the alternator to do. Should help the alternator last longer.
08-11-2017, 12:26 PM | #19 | |
dances with roads
4717
Rep 4,094
08-15-2017, 08:14 PM | #20 |
Rep 1,543
Just replaced mine last year.....for my 07 (06 build). Replacing is the safer thing to do at the age of your battery.
I went w/ an AGM from O'Reilly per other suggestions. Not sure if they have O'Reilly in Austrailia, but it saved quite a bit for the same battery.
- Jeff
bosstones' flickr |
08-17-2017, 01:41 PM | #21 |
Rep 1,130
StickMon suggested that you should get a H6 battery. I was running a H5 since October because Autozone indicated that was OEM size. I just found out that the H7 actually is the same size as the OEM battery my Z4M had when I got it back in 2011. So just recently I got the AGM battery from Autozone (H7) and fits perfectly fine, obviously more cold cranking amps.
2014 BMW X5 Sdrive35i F15
StickMon636.00 |
