02-12-2014, 09:20 PM | #1 |
Rep 770
M Roadster Inside of Trunk Color Question
I was told by a guy at CarMax to look at the inside of the trunk on BMW's and you can tell if the trunk lid has been replaced by looking to see if the inside of the trunk lid is the same color as the body of the car or if it's a flat black. If it's the same color, it has not been wrecked, but if it's black, then the trunk has been replaced at some point. Is this true? If so, I'm seeing a lot of M Roadsters out there for sale that have had the trunk replaced. I know the breaks are good, but do they all get rear ended at some point?!? Example is this blue one on the left that has 10,113 miles on it and a clean CarFax, selling for $31,900. The inside of the trunk is black. The CarMax guy showed me a red one (like the one on the right) they had for sale and how the inside of the trunk lid was red. The majority I see w/ black trunk insides have clean CarFax's. Hmmm...
02-12-2014, 09:25 PM | #2 |
Rep 1,443
I'm confused. He was talking about the metal floor not being painted body color after being replaced? All I see in the picture above is carpet and lining.
Edit: Oh, you mean the trunklid/hatch (for a coupe). I see. Couldn't tell you for sure, though. Pretty sure mine is body color but I don't know if it's the same for roadsters.
02-12-2014, 09:26 PM | #3 |
Rep 770
02-12-2014, 09:30 PM | #4 |
Rep 1,443
Sorry, took me a sec. I edited before I saw your reply. My guess is that the flat black is a more durable finish than exterior paint since there doesn't appear to be any sort of liner on the lid. I'm sure a roadster owner will chime in very soon to clear this up.
02-12-2014, 09:33 PM | #5 |
Rep 1,034
How the Z4 was painted
The paint section is 28 minutes in, the trunk is on the car and open when it goes though the process. The floor should be black because it's an installed piece and not part of the body (I think)
02-12-2014, 10:28 PM | #7 |
Rep 247
I don't know the answer, but when you look at a blue z4m, the engine bay strut towers are also black. In a red car, they're red. Silver car they are primer color. Kinda wondering if only the red ones have the painted engine bays and trunks?
02-12-2014, 10:38 PM | #8 |
Rep 892
Then I guess every Z4 that is black or blue (possibly others as well) has been wrecked. The info you received is completely wrong. You can watch the video closer if you like; you'll see black and blue trunks and engine compartments finished in flat black.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
02-12-2014, 10:58 PM | #9 | |
Rep 1,034
I tried to look at my own Toledo Blue car and the door jam? around the trunk is painted, but it's dark out ATM and hard to tell if the trunk lid is just primer black or unclearcoated dark blue. EDIT: If the trunk lid was replaced, it probably would not have the BMW Assist sticker on it.
02-13-2014, 08:53 AM | #10 |
Rep 452
My Roadster's paint is Titansilber and the inside of the trunk lid (and the engine bay area) are semigloss light gray.
This was probably the biggest disappointment in an otherwise great car. Seems that for $60K, BMW should have done all visible surfaces in body color.
02-13-2014, 10:01 AM | #11 | |
Rep 2,866
02-13-2014, 10:46 AM | #12 |
Rep 135
My Z4 is Monaco blue (dark blue) and the rear trunk is black on the inside, as well as the front hood. This is common for all dark colored Z4s. Only the first inch along the perimeter of the underside is painted on these panels, where the metal is folded over.
Obviously a way to save on paint without creating a contrast that is extremely noticeable to a discerning buyer. The Z4 is painted with a waterborn Glasurit paint that is super expensive. I can certainly see why they would want to save paint on the underside of hood/trunk panels. On the lighter cars they paint everything that could be visible. |
02-13-2014, 10:53 AM | #13 |
Rep 1,991
As already stated the Carmax guy is dead wrong. It varies by color but red cars have a flat version of red in the engine bay and trunk. The blue cars are all black in these areas. I think the white cars are like red in that they have flat white inside. In any event, don't use that as a measure of anything...
02-13-2014, 02:26 PM | #14 |
Rep 820
Drives: 2007 Z4MR silver grey
I think he's got it backwards. My silvergrey had that primer/slate grey finish on the inside of the trunk lid. I got rear ended in December, and had a new trunk lid put on. The BMW bodyshop painted the inside of the new trunk lid to match the outside of the car ......... based on that info, "if" there was a correlation to this, having the inside of the trunk lid painted the body color would mean the lid had been replaced....... "if"
John |
02-13-2014, 07:24 PM | #16 |
Rep 4,057
If you want to be absolutely sure, go to a site like eshine.ca and get a paint thickness gauge so you can find variations in the paint layer, indicating body work.
My blue roadster has it's original lid and the inside is flat black.
Huz-Z
02-13-2014, 08:11 PM | #17 |
Rep 770
Cool. Thanks. I had heard that and then started seeing way too may trunk lids that were black on the inside.
02-14-2014, 12:03 AM | #18 |
Enthusiast
17
Rep 245
Wouldn't it be just a base coat/primer coat anyway? Don't our cars have a multi-layering paint process?
2016 550i M-Sport
2008 328i M-Sport (Sold) 2007 Z4M Roadster (Sold) |
02-17-2014, 12:22 AM | #19 |
///Multiple
2992
Rep 4,243
The underside of the trunk lid and the underside of the hood and the engine bay on my Interlagos Blue Z4 M Roadster is a dark charcoal gray/black and it's original.
02-17-2014, 12:34 AM | #20 |
636
Rep 3,124
Yep. I have same car, same colors.
All original stickers. Update: I just removed one of my taillight assemblies, and it has blue over-spray on the housing. Hmmmm.
02-17-2014, 12:50 PM | #21 |
Mechanical Engineer
96
Rep 1,025
Maybe Red is the only one thats supposed to be body color? I have a red M roadster with an original trunk lid, and the inside is red (although its kind of a dull red, looks like maybe it gets the color but not the clear?) The inside of my engine bay is also red.
02-17-2014, 01:30 PM | #22 | |
Rep 1,034
Lighter colors like white and red and lighter blues will have a painted trunk lid and engine bay. If you're questioning if the trunk lid is the original look for the BMW assist sticker affixed to the bottom center of the open trunk lid.
