02-08-2014, 10:08 PM | #1 |
Rep 24
Rain-sensing wipers question
So I just had my first rain experience after getting my Z4, and I got to test how the rain-sensing wipers work. However, I'm not sure if they're working quite right and I wanted some input from others who have this feature.
When I push the stalk to position "1", nothing happens for a few seconds, then the wipers do 1 sweep. If there's no rain, it seems that the wipers still wipe every 10 seconds or so. When I'm driving and there is rain, I notice that this interval changes to anywhere from 5 seconds to a little over 10 seconds. But, it never goes any faster that 5 second intervals, and never slower than 10. This is with the "sensitivity" adjustment on the highest setting. It almost feels like they are just doing speed-sensitive wiping instead of rain-sensitive, but I wasn't sure if these cars had that feature. I feel like there were situations when they should have been wiping much faster, but still stuck to that 5 second interval. Is this how your wipers work too? |
02-08-2014, 10:21 PM | #2 |
636
Rep 3,124
Mine seem to be the other way round.
Where I'm at, we get a lot of mist, rather than rain. They'll wipe every couple seconds, even in a light mist, and the sensitivity control seems to do next to nothing. I'm not even sure I've been able to figure out which direction to turn the knob. I know the sensor works, though. When it stops misting, they stop wiping.
02-09-2014, 12:21 AM | #3 |
Rep 24
Hmm ok, I might have to make a trip to the dealer then. I definitely have the sensor unit in front of my rear-view mirror, but the system behaves more like the regular intermittent mode instead of rain-sensing. Maybe the feature was disabled for some reason...
02-09-2014, 12:27 AM | #4 |
Rep 1,034
It also helps to make sure that the glass is clean over the sensor and that the wipers are good enough to actually move the water off of it.
02-09-2014, 05:44 AM | #7 |
Rep 1,134
Drives: '07 M Roadster
I have always wondered which position of the switch is more sensitive or however it works. The manual doesn't really clue me in and the lines on the stalk are a bit cryptic.
02-09-2014, 10:30 AM | #8 |
Rep 24
The sensor is stuck on the glass, on the inside, where the rear view mirror sits on the windshield. It looks like this (not my car, just a pic I found of the sensor that looks exactly like mine):
I'd assume that if I have the sensor, I'd have that feature right? |
02-09-2014, 03:22 PM | #10 |
Rep 820
Drives: 2007 Z4MR silver grey
02-09-2014, 04:17 PM | #11 |
Rep 1,910
FWIW, I love the rain-sensing wipers on my 2006 Z4. They do a great job of wiping as often or as rapidly as necessary to suit the conditions. I leave the little sensitivity lever on the bottom-most position (which I believe is the least sensitive setting).
When I first move the windshield wiper stalk to the first (rain-sensing) position, the wipers immediately do one swipe. From there, they'll either wipe intermittently as necessary or continuously, fast or slow, as needed. I smile every time I use them. Rick F. |
02-09-2014, 05:28 PM | #12 | |
Rep 24
02-10-2014, 12:18 AM | #13 | |
636
Rep 3,124
Mine are starting to cheese me off.
02-10-2014, 07:27 AM | #14 |
Mechanical Engineer
96
Rep 1,025
02-10-2014, 12:13 PM | #15 | |
Rep 4,057
Huz-Z
02-10-2014, 01:21 PM | #16 | |
Rep 1,034
Occasionally they act up, but a go at the windshield with some Invisible Glass™ helps (both the sensor and general visibility)
02-10-2014, 01:29 PM | #17 |
Rep 52
Drives: 2008 z4 3.0i roadster
I kind of like them especially when passing a semi on the hiway in the rain and the wipers pick up tempo to take care of the increased water spray.
02-10-2014, 02:37 PM | #18 |
Rep 251
I had my windshield replaced few months ago and the auto sensor didn't work correctly after that. I brought it back and the owner of the place blamed the sensor - told me that I needed a new one. Yes you can buy a new and I believe it will reset to normal setting again. basically it will work like it should, but they are like $100 or you can get INPA and reset it from there. I haven't had much luck getting INPA to work for me. For now, I disabled it with PA soft and it works fine but manually...
02-10-2014, 11:31 PM | #19 | |
Rep 820
02-11-2014, 08:28 AM | #21 |
Rep 1,543
I hate them. I always found them to be too sensitive. Then again, I tend to use the manual 'single wipe' most of the time. I usually only use the interval settings in heavier rains. I do, however, like that it slows the interval when you're stopped and resumes when you go again.
- Jeff
bosstones' flickr |
02-19-2014, 09:45 PM | #22 |
Rep 48
http://forums.bimmerforums.com/forum...-faulty-wipers
Mine always acted crazy since I bought the car 2 years ago. They stopped on me last fall on the way to work. I had to pull over and shut the car off and restart to get them to work again, and only for a short period of time. I found this thread for a fix. Took care of my stalling problem and all of the sensitivity issues I was having. The grease must be pretty conductive, as these photos in this thread appear to have a lot more grease between the contacts than my motor seemed to have. Worth trying rather than spending a lot of money or just hating to drive because there may be a chance of rain. |
