      08-24-2018, 12:08 AM   #1
fgottlieb
Drives: 2007 BMW Z4 3.0si
Steering wheel buttons
Has anyone found a viable solution for replacing the steering wheel buttons? It seem that the trim is available, and the used buttons found on eBay are all worn out like mine.
The only other option I found is to buy the entire steering wheel for about $500.
      08-30-2018, 12:00 PM   #2
ShawnPaul
ShawnPaul's Avatar
Drives: 2007 Z4M Coupe
Is it the buttons worn or the casing for the buttons? I actually just buffed off all of the soft touch coating on my steering wheel and now everything is gloss black plastic. It looks brand new and was just labour in removing it. Just rubbed it for a long time with a micro fibre cloth until it all came off. An hour of my time. But cheaper than replacing. Pictures are of before and after buffing it off.
      08-30-2018, 12:51 PM   #3
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
I had one set of steering wheel buttons that I had to replace. I found the part# on RealOEM and ordered a new one from ECS Tuning. Not cheap, but better than the old buttons that had the base white plastic showing and a really poor touchup by a previous owner.
If it is just an issue of deteriorating coating, I did like ShawnPaul did and just rubbed off the old coating to uncover the glossy black plastic underneath. I just left it at that. Why one of my button groups had base white plastic, I don't know.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      09-08-2018, 12:30 PM   #4
markos_z4
instagram : https://www.instagram.com/markos_z4/
markos_z4's Avatar
Netherlands
64
Drives: BMW Z4 Coupe 3.0si 2006
just remove the casing and paint them
follow me on instagram:www.instagram.com/markos_z4/
      09-08-2018, 05:09 PM   #5
fgottlieb
I was able to remove one of the two buttons but not the smaller one of the two. It looks like It’s glued or screwed. And to clarify, I do mean the casing, not the buttons themselves. Thanks
