01-22-2015, 07:09 PM | #23 | |
Rep 666
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
01-22-2015, 10:48 PM | #24 |
636
Rep 3,124
In a can with a bolt through the top near the top front of the engine.
You can't miss it, but you might think it's something else.
01-23-2015, 12:01 AM | #25 |
Rep 25
For cars with oil filter housings up top, get a mityvac from Amazon and DIY.
1. Get oil to operating temp 2. Open oil filler cap (for air flow) 3. Stick mityvac tube down dipstick tube to the oil pan 4. Pump that nasty oil outta there. 5. Remove pump line. 6. Remove oil filter - use a grocery bag to catch it without a mess 7. Install new oil filter- wet the filter and housing with about .5 liter. Use new gasket that comes with the filter 8. Torque the oil filter housing to spec 9. Fill with oil through valve cover 10. Run engine for a minute to verify oil level. Add as needed. 11. Take dirty oil to recycle facility. It is free here. Takes 20 minutes max. No need to climb under there and deal with the drain plug. I do it in my work clothes. |
01-23-2015, 02:38 PM | #26 | |
Rep 2,665
Not a huge deal to get under the car either, just thought it would be easier to not deal with it. Once you have to get under the car for the filter probably not worth the purchase.
01-27-2015, 06:27 AM | #27 |
Rep 53
Hey Deutsch--couple of thoughts. Get the Mike Miller Lifetime Maintenance Schedule from Mike Miller at BMW Car Club of America. Free, tells how to maintain your car for a long time, not just the length of the warranty. You should probably change your oil at least every 7,500, and I think better at 5,000 even though I do use that expensive BMW 10-60 in my S54. Also this may be just me, others rave about it, but I can't seem to get the oil fully drained using the mighty vac, and once overfilled it by putting the recommended amount back in.
01-28-2015, 10:16 PM | #28 | |
Rep 1,907
I doubt it gets as much oil as drain plug, however it gets pretty damn close. |
01-28-2015, 10:25 PM | #29 |
Rep 115
Not having to get under the car to drain the pan does seem great. I will look into one of these vacuums. Is the Z4 oil filter near the top of the engine?
