06-18-2018, 01:42 PM | #111 | |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
I would reach out to the guys at Turner since they put this package together and see if they can help. OEM LuK Clutch Throw Out Bearing / Release Bearing -- E46 M3, E39 M5 (Mfg Part # 21511223582) Sachs Performance Pressure Plate - E36 Z3 M3 3.2L (Mfg Part # 883082999792) E36 M3, MZ3 JB Racing Lightweight Aluminum Flywheel (Part Number: 520-010-240 ) https://www.turnermotorsport.com/p-8...-flywheel-kit/ |
06-18-2018, 01:58 PM | #112 |
Rep 506
Street Shoes vs Track Shoes, You gotta love HRE's but the square set up for the track handles so much better. DME should be back this week get it on the road and start getting her dialed in.
06-18-2018, 04:05 PM | #113 |
Rep 1,130
Wow this thread is insane! Great looking car, and the massive balls it takes to do this type of work! What wheels are those on the bottom picture?
2014 BMW X5 Sdrive35i F15
06-18-2018, 06:25 PM | #114 |
Rep 506
RossBMWZseries226.00 |
06-18-2018, 09:58 PM | #115 | |
1621
Rep 4,294
Thanks matey, yeah I think the difference is I have the 520-180-240 flywheel, not the 520-010-240 one. Thanks for the help though, and yeah trying to sort it out with Turners atm. Sorry to sidetrack you from your build thread. LOVING your car man, I just cant wait to see it running/going. going to be completely EPIC!!!!! as you said man, work of art of those parts going together. Love the new Titans, looks like they will be the goto track wheels. They look much better than the HRE's , esp on the front.
Powered by |
06-19-2018, 03:54 AM | #116 | |
Rep 506
No Worries, I am always available. |
06-27-2018, 04:37 AM | #117 |
Rep 506
Well, we finally figured out what was going on with the throttle actuator. The Dinan throttle bodies were not set correctly by the manufacturer and the fail-safe was cutting power and not allowing the car to complete the startup sequence. Since they specifically tell you not to mess with the settings or it will void the warranty it makes this hard to track down.
The next step is getting the new Epic Alpha tune flashed to the ECU and then off to the Dyno Next week. |
06-27-2018, 01:26 PM | #118 | |
Rep 211
Drives: 2007 BMW Z4M Coupe
Also what are you running exhaust wise? |
06-28-2018, 09:06 PM | #119 | |
Rep 506
The exhaust is a set of epic stepped headers, Supersprint straight, and x-pipe with RPI cans. |
crfine88442.00 |
06-30-2018, 06:34 PM | #120 |
Rep 506
I finally got her back out on the road for testing. All looking surprisingly good with only a few adjustments and we have not even completed the alpha tune yet. .
07-04-2018, 07:11 AM | #121 |
Rep 506
Getting close to scheduling our first Dyno. Trying to get a few miles on the car and work out some tweaks, But all is good!
07-10-2018, 12:33 PM | #123 |
Rep 133
Looks bad ass! engine bay is porn!! Congrats!
07-10-2018, 11:14 PM | #124 |
1621
Rep 4,294
hey buddy, just wondering if anyone has asked about it yet, but do you have 4 big yellow spotlights in front of your radiator core? what are those for?
Powered by |
07-11-2018, 04:03 AM | #125 |
Rep 506
We have evening track days at Road Atlanta and my night vision is not great, so I added them and swapped out all my OEM headlights to LED lamps, I get twice the vision without blinding the guys in front of me.
crfine88442.00 tiltmode43522.50 |
07-12-2018, 05:45 AM | #126 |
Rep 24
Holy $#%& I love the yellow fogs man! Your car has pretty much become my inspiration and I have been wondering how best to add fogs without making any permanent changes to the car..... this looks fantastic!
07-12-2018, 01:32 PM | #127 | |
Rep 506
I ended up finding a piece of Zinc-Plated Slotted Angle and attached it to the subframe. I had to grind down the corners, which I would have made a little cleaner if I did it again. The lights are 4"LED with a yellow tint and I have a toggle switch on the dash that turns them off and on. They are solid and fit perfectly behind the grill. |
07-16-2018, 07:02 AM | #128 |
Rep 133
This is just bad ass...
07-17-2018, 09:04 PM | #129 |
Rep 506
07-25-2018, 05:04 PM | #130 |
Rep 1,130
Even better. Your engine bay is GOALS! All that carbon fiber
08-17-2018, 05:22 PM | #131 |
Rep 506
First dyno session pushed a 377.48 to the wheels "dyno jet equivalent" and 266 lbs of torque. Sending my data logs back to Epic for tweaking. I stopped at 7200RPM because I am running a 4:10 rear diff.
08-17-2018, 11:16 PM | #132 |
I plead the 5th.
523
Rep 1,519
Those last HRE shots
-Matt
