04-08-2015, 11:52 PM | #1 | |
Rep 162
Drives: 2008 Z4 3.0si Coupe
Low beam issue [HID]
So I recently installed an aftermarket HID kit on my car (Opt7 Bolt). There's an issue I'm having where one of the HIDs don't ignite...initially. It's kind of weird (at least for me because I'm new at electrical), but here is what I've observed:
Possibly related: When I bought my car, it was in transport mode. It is my understanding that that can occur from a low battery. Nonetheless, I ran a diagnostic on my car and here are the fault codes. Any help on how to troubleshoot this would be appreciated. Sorry about the formatting below; fault codes are bold. Quote:
2008 Z4 3.0si Coupe
04-09-2015, 06:09 PM | #2 |
636
Rep 3,124
You might want to reset the existing codes and get a fresh start.
There's no telling when those codes set and under what circumstances.
04-09-2015, 08:22 PM | #3 |
Rep 2,547
When you buy a cheap $35 Chinese plug-and-play HID kit, you might not get the most reliable equipment. Maybe adding relays will get them to ignite consistently.
04-09-2015, 09:52 PM | #4 |
Rep 162
I'll definitely give this a try. Thanks.
2008 Z4 3.0si Coupe
04-09-2015, 11:56 PM | #5 |
Rep 162
You're absolutely right. I'll try a relay harness to see if that helps.
2008 Z4 3.0si Coupe
07-16-2015, 02:00 AM | #6 |
Rep 162
So I want to update this thread for those who may have had the same problem or were interested in what happened. Installing a relay most definitely solves the intermittent HID issue. No problem there now.
New problem is that by installing a relay, the passenger HID now has an unused connection. That connection supplies the signal for the bulb check. So I've had a bulb-out warning since installing the relay even though I have no issues with the HID's otherwise. After troubleshooting with customer service, they were ultimately unable to help resolve the issue other than offer a refund. So I decided to code out the bulb check for my low beams. It's a band-aid solution, but it'll do for now. Thanks to those who helped!
2008 Z4 3.0si Coupe
07-16-2015, 08:39 PM | #7 | |
Rep 2,547
07-16-2015, 11:15 PM | #8 |
Rep 162
Thanks again, pungo!
2008 Z4 3.0si Coupe
