      09-01-2010, 07:06 AM   #23
Shipkiller
Shipkiller's Avatar
Drives: Me
No I don't see any reason you can not piece this out. Just get the proper size/thread grade 10.5 bolts (stronger the better) and washers. Mic out the washers to get each washer pack the same thickness.
      09-01-2010, 05:09 PM   #24
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Originally Posted by Shipkiller View Post
No worries..
We all get confueseded.....
Thanks man - hey, regarding the HPDE at NCCAR, I was thinking of maybe trying to make it. Don't have a helmet, would need an inspection, and I'm out of town until Tuesday - have you heard anything more about it? I like the idea for a first time for me - flat, open, constant radius curves, might be a great place for the first HPDE. Just curious.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      09-01-2010, 05:35 PM   #25
Shipkiller
Shipkiller's Avatar
Drives: Me
You can register at http://www.motorsportreg.com/
It's an Asphalt Adventures event.
Never been there since it's so new. I am hoping it's a good track. It's closer than VIR.
      09-07-2010, 01:08 PM   #26
Drives: M2 Comp
Picked up my over the counter hardware and installed it this weekend.
Alignment is booked for Thursday and track on Friday.
I'll post up a few notes on the weekend.
      09-07-2010, 01:59 PM   #27
Shipkiller
Shipkiller's Avatar
Drives: Me
You'll be at the track a week before me.
      09-07-2010, 02:30 PM   #28
a_riddler
Bimmer Noob
a_riddler's Avatar
Installed camber bolts and manually adjusted for max camber.
I ended up with -2.5 Left side and -3.1 Right side.
After an alignment, I ended up with -2.5/-2.5.
The difference in the front handling is very noticeable during autocrossing. In fact, the back end came around on me once. I am used to the understeer so was surprised when the front held.
I highly recommend this mod. Cheap, quick and noticeable results!
      09-07-2010, 03:39 PM   #29
dekaliber
Could you share the hardware specs for what you purchased (i.e. bolt length, grade, washer thickness)?
I'd like to try sourcing these from McMaster-Carr using actual shims instead of washers for much closer tolerances.
      09-07-2010, 03:50 PM   #30
Drives: M2 Comp
The bolts are 10.9, M12 25mm
The washers are ~2.50mm each (3 per bolt)
The OE bolts are 20mm, so with the added 2 washers it is threaded in to the same point.
IMO shim stock is overkill.
With manufacturing tolerances, both sides will never be equal.
To fine tune the camber it will still need adjusting at the top.
      09-07-2010, 05:22 PM   #31
dekaliber
You wouldn't happen to know if the thread pitch on these bolts are 1.25mm, 1.5mm, or 1.75mm, would you?
      09-07-2010, 07:49 PM   #32
Drives: M2 Comp
oops... sorry
They are 1.75mm
      09-07-2010, 11:15 PM   #33
dekaliber
Thanks!
So, just to check, something like:
http://www.mcmaster.com/#90854a223/=8r2a9e
http://www.mcmaster.com/#91455a150/=8r2du0
I'll be happy to pass on the extra bits to anyone interested.
      09-08-2010, 07:36 AM   #34
Shipkiller
Shipkiller's Avatar
Drives: Me
Oh, I forgot to say that the stut hole must be perfectly lined op with the threaded hole in the kingpin. If it's not, the bolt won't thread and you could cross thread it.
      09-08-2010, 02:05 PM   #35
Drives: M2 Comp
FWIW, when I installed mine;
1. I just loosened the upper bolt and kept it in place to maintain bolt hole alignment.
2. I removed one of the lower OE bolts and turned in one of the new longer bolts (only 2-3 turns) sans washers.
3. I then removed the other OE bolt and pried a gap big enough to slide in two camber washers.
The 1st bolt (step #2) maintained hole alignment for the 2nd new bolt.
4. I removed bolt in step #2 and added washers, then re-installed.
As pointed out below, be sure to use red loctite
      09-08-2010, 02:11 PM   #36
a_riddler
Bimmer Noob
a_riddler's Avatar
Did same, but added Red Loctite to the threads of the camber bolts since the originals had it.
      09-08-2010, 02:37 PM   #37
Drives: M2 Comp
^ good point, I missed that in the write up.
      09-08-2010, 02:49 PM   #38
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
^ good point, I missed that.
Better reinstall before Friday...
2006 Z4MC - #LL93158
      09-08-2010, 03:03 PM   #39
Shipkiller
Shipkiller's Avatar
Drives: Me
Yes, add some Red Loctite. When I pulled my OEM bolts out, they had some on them.
      09-08-2010, 03:22 PM   #40
Drives: M2 Comp
LOL... I missed it on the write up; not the install.
...tough crowd
[fixed]
      09-08-2010, 04:42 PM   #41
hansaysso
hansaysso's Avatar
Drives: 07 Z4MC, 93 RX7 FD3S
what intgr8r said is spot on, do NOT completely remove the top bolt, it is an absolute PAIN to try and realign the bolt holes properly. just loosen (i made the ar-tard mistake of taking out the top bolt...) and slide the washers and bolts in. locktite is a must!
      09-08-2010, 05:40 PM   #42
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
...tough crowd
[fixed]
So we should not follow your DIY posts going forward
      09-08-2010, 05:43 PM   #43
Drives: M2 Comp
Do as I do, not as I say.
      09-08-2010, 06:43 PM   #44
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
So everyone comes to your house to watch you work on our cars Pat cooks dinner too
