05-03-2015, 11:51 PM | #1 |
Rep 5
No Amp?
So I jus took possession of my (new to me) 2008 3.0I and after trying to keep it under 90 on the backroads, I started digging around the car and noticed that there is no Amp.
the window sticker from '08 says it's a 10 speaker system, which I've confirmed at least by looking behind the seats and seeing the grills for the Subs, but after reading for literally hours on the forum I could have sworn that BOTH 10 speaker set ups (the hifi and Top or Carver hifi) has an amp next to the battery. Well, I looked and I see the location where the amp would be..just behind the battery in the trunk..but no amp. Did they move the location in '08? or just kill the standard 6 speaker set up the final year of the E85? Thanks! |
05-04-2015, 11:45 AM | #2 |
Rep 5
Little more investigating and I notice two custom mics mounted in either vent, which I'm now thinking that perhaps the guy before did a custom install and just removed it after?
05-04-2015, 12:42 PM | #4 |
Rep 5
Hard to turn the radio on when the car is in California and I'm in MN! it was an Ebay car from a small independent dealer.
To be clear the radio works fine, just very curious why it works fine since I was under the impression the HiFi 10 speaker had an amp next to the battery. |
05-04-2015, 01:06 PM | #5 |
Rep 273
They moved the amplifier to the trunk bulkhead behind the driver seat in the facelift cars (2006+). It is behind the vertical carpet panel along with the telephony equipment (if installed).
05-04-2015, 01:38 PM | #6 |
Rep 218
What westCDA said.
It's almost dead center behind the rear trunk carpet. Takes removing a couple plastic pop fastners to get to it. Also- I think the "custom mics" you think you're seeing at the vents are just screw covers. |
