11-17-2008, 04:42 PM | #1 |
Supreme Allied Commander
3847
Rep 54,378
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Quaife Differential for Z4 3.0
Quaife, The Ultimate Differential is now in stock for your Z4 3.0 at HP Autowerks, Inc.
"The Quaife Automatic Torque Biasing Helical LSD Differential enables a car to accelerate more rapidly and corner faster. How? Simply by getting the power to the ground. With an normal open differential, fitted as standard on most cars, much precious power is wasted through wheel spin under acceleration. This happens because the open differential shifts power to the wheel with less grip - along the path of least resistance. The Quaife differential, however, does just the opposite. It senses which wheel has the better grip, and automatically biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel. In cornering, while accelerating out of a turn, the unit biases greater power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed. The Quaife differential also controls loss of traction when the drive wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs. The Quaife ATB Helical LSD differential's unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage, whether on the track or on the street. The Quaife differential is extremely strong and durable, and since it is gear-operated, it has no plates or clutches that can wear out and need costly and regular replacement. There is no maintenance required to the unit, so you can fit and forget. The Quaife differential is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the cars towards its limits. The Quaife differential is proven in everything from SCCA Rallying to drag racing and Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort. Expand your vehicle's limits with the Quaife ATB Helical LSD Differential!" Here is a video on Quaife LSD: http://video.aol.com/video-detail/bm...tial/538903604 Top tuners using our Quaife LSD: Berk Technolgy's Redline Time Attack 135i Burger Motorsport world's quickest 135i Vishnu Tuning Price for 2009 is $1450, in stock ready to ship! Last edited by HP Autosport; 01-27-2009 at 12:45 AM.. |
12-07-2008, 10:15 PM | #3 |
Rep 1,224
According to the Quaife website, the only authorized fitting center in the US is Taylor Engineering in TX. If the Quaife LSD is installed by someone other then Taylor is the warranty voided?
12-08-2008, 11:07 PM | #4 | |
3847
Rep 54,378
Drives: F80 M3
Taylor Engineerings handles the motorsport division only, but you may want to ask if they will install your Z4 Quaife if you are in the area. If not, we can certainly recommend an installer nearest to you. Your warranty will not be voided if the Quaife is installed and used according to the warranty guidelines. |
12-09-2008, 09:13 AM | #5 | |
Rep 1,224
12-11-2008, 11:39 AM | #6 |
Rep 12,565
is the application the same for both 3.0i and 3.0si?
12-11-2008, 02:11 PM | #7 |
3847
Rep 54,378
Drives: F80 M3
Yes and no. Depends on your transmission type and final drive ratio.
12-12-2008, 09:14 AM | #9 |
Rep 12,565
6speed manual, i believe stock gearing is 3.46...
12-12-2008, 09:14 AM | #10 |
3847
Rep 54,378
Drives: F80 M3
12-12-2008, 09:21 AM | #11 |
Rep 1,224
Approximate installation time if car brought to you?
12-12-2008, 09:28 AM | #12 |
3847
Rep 54,378
Drives: F80 M3
12-12-2008, 11:07 AM | #13 |
Rep 1,224
Please do.
01-07-2009, 10:32 AM | #18 |
3847
Rep 54,378
Drives: F80 M3
There will be a drop in retail price on the Quaife for 2009.
Stay tuned! |
