07-20-2017, 08:53 PM | #23 |
Rep 97
Headers are in!!! and apparently it's a 3.5". I must say the quality is AMAZING!! It comes with 2 o2 sensor bungs but no EGT sensor bung =( so additional modifications will be neccessary unless you eliminate the EGT and other 2 o2 sensors. As far as install, I will be attempting it next week either Monday or Tuesday. Stay tuned, Cheers!
Shutterspeed80.00 |
07-20-2017, 09:39 PM | #24 |
Rep 1,543
They look awesome! How will this mount to section 1?:
07-20-2017, 09:46 PM | #25 |
Rep 97
Either we will have to make a custom section 1, which I will be doing after ARH told me to or they will have to find a test car and do it for us which I kinda doubt. But we'll see after I test fit it and confirm everything with them.
07-21-2017, 02:15 AM | #26 |
636
Rep 3,124
Pffff ... Just run it out the sil panel like DTM!
07-21-2017, 06:04 AM | #28 |
Rep 11,667
The EGT can go in section 1 as in the euro setup.
07-21-2017, 09:20 AM | #29 |
Rep 9,004
NO point in splitting it again if you don't have to. I'd imagine there is enough space to run a single pipe all the way back.
07-24-2017, 07:10 AM | #31 |
Rep 626
That's how it's supposed to be, just like the E46 setup from ARH. I think they haven't developed the section 1 for our cars yet since they don't know if the headers will fit. Let's see if we can convince them to do a headers+section1 once the test fitment is done...
07-24-2017, 01:31 PM | #32 |
Rep 1,130
The whole idea of this was supposed to have a ONE (1) piece which consists of the headers attached to the S-Pipe. At the last minute, they only made the headers. Which now ConceptAutoGroup has to make a custom S-Pipe AND make a EGT bung. Pricey headers + custom work + which guarantees no results (yet) is a big NO for me. Unless the whole piece is made and shows a nice bump on HP/TQ, then I might consider it.
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI 2006 BMW Z4 M Roadster E85 2013 BMW S1000RR K46 R.I.P. 1998 BMW Z3 Roadster 1.9L E36 SOLD |
07-25-2017, 09:54 PM | #33 |
Rep 97
So, today I installed the ARH. I must say, they are a PITA compared to other headers due to the one piece design. Here's the summary.
IT RUBS BADLY on the transmission, so I had to hammer it down quite a bit. Right where the collector is. Also, the oil return pipe DOES NOT fit in it's original position, I had to to bend it and not use 1 of the bolts that mounts from the center. I will confirm if it's still rubbing the headers tomorrow as I am super exhausted... Also, you have to slightly reshape the heat shields around the exhaust area and control arm. The 3.5" exit is super close to the tunnel but it can work. I will be connecting my custom Section 1 to the OEM X-pipe Thursday (waiting on some exhaust parts). I will be adding 2 AR25 resonators to it to kill off all the rasp that it will have and to quite it down as well. I will post pictures once that is complete. Feel free to ask questions as I'm sure I left some stuff out. Cheers |
07-26-2017, 01:40 PM | #34 | |
Rep 270
07-26-2017, 04:34 PM | #35 |
Rep 754
07-27-2017, 08:21 AM | #36 |
Rep 2,665
I would assume they would want to see where all the interference is and try to do better on the 2nd go around? Seems like you make it fit with hammering the areas down and then send it back to them and they have good idea what needs to change on the 2nd one?
Maybe this would work with pictures but might be difficult.
07-27-2017, 11:55 AM | #37 | |
Rep 97
07-27-2017, 09:48 PM | #38 |
Rep 97
Hey guys,
So I completed my "temporary" section one today. Still need to weld in bungs for the rear 02 sensors and EGT sensor. Also might change up the design for better flow etc not sure yet. Anyways all is well with the current set up in terms of driving and power gains are very obvious. Please don't ask for sound videos cause the car has OEM mufflers at the moment so its silent. =( Here's a few pics of the set up. I'm still working on trying to get the oil return pipe set up properly. Cheers (p.s. I forgot to take pics when I completed the welding and pipes etc, but I'll snap a few more when I lift it up to install aftermarket mufflers) |
08-07-2017, 09:32 PM | #40 |
Rep 500
Curious ....... when they designed and made these, did they not check the design and fitment??? I'd find it odd that it would be conflicting with other components on the car so significantly. QA/QC seems to be missing here ......
08-07-2017, 09:51 PM | #41 | |
Rep 1,543
09-15-2017, 03:15 PM | #42 |
The Slip Angle
31
Rep 50
Drives: 2007 BMW Z4 ///M Coupe
Garage List 2005 Honda S2000 [0.00]
2006 Mazda RX-8 Shinka [0.00] 1994 Mazda Spec Miata [0.00] 2003 Honda S2000 [0.00] 1991 Mazda Miata [0.00] 1999 Mazda Miata [0.00] 1993 Mazda RX-7 [0.00] 1993 Mazda RX-7 [0.00] 2007 BMW Z4 M Coupe [0.00] |
Has there been any updates with these? I would be in for a group buy on a revised version and section 1 to fit the Z4M.
2007 BMW Z4 ///M Coupe | 1993 Mazda RX-7 Turbocharged 417 whp | 1999 Mazda Miata All Motor 185 whp | 1991 Mazda Miata N/A 13b PPort | 2003 Honda S2000 All Motor 238 whp | 2006 Mazda RX-8 | 1998 Lexus LX470 | www.instagram.com/garagequinnmotors
09-15-2017, 05:22 PM | #43 | |
Rep 626
I can ask ARH if we can get headers only, or if they'll consider doing a set for us from the ground up. I doubt he's gonna do it for a small audience, though. I'll let conceptautogroupla also respond, since he had taken over the communication with ARH at some point. |
09-16-2017, 12:14 AM | #44 | |
Rep 912
