04-14-2010, 10:34 PM | #1 |
Rep 129
Radiator Fan Problem
recently i've noticed that my fan (the one behind the radiator) comes on intermittently, even when it's not hot out and when the car has NOT been driven hard.
this fan will start up, get up to medium speed, then full blast for a few seconds before slowing down again, and then it will repeat this process continuously. i thought this was weird because i never realized it before. fuses were checked and none were blown... what could be my problem??? |
04-15-2010, 08:33 AM | #2 |
Certified Adrenaline Junkie
43
Rep 1,325
I'm not sure about this car but on my previous car, one of the fans was the AC fan. It comes on when the AC is on and the car requires more airflow through the radiator & condensor. Hopefully someone else can provide some insight.
04-15-2010, 09:32 AM | #3 |
Rep 129
yeah i thought this too at first, but i double checked and there is only 1 fan on the z4, the one behind the radiator, no fan in front
04-16-2010, 09:59 AM | #4 |
Rep 129
i tried it with AC off, same symptoms. when the AC is on, the fan is on continuously drawing air through the AC condenser/radiator.
now as far as i know, there is a coolant temp sensor on the lower radiator hose and another coolant temp sensor on the thermostat. i think my thermostat works perfectly fine... because i'm not getting any symptoms of the sticky or "stuck" thermostat. my car warms up in normal time and i'm not overheating. i think my coolant temp sensors are okay too, because the coolant temp gauge on my dash is in normal operating order.. right? there's 1cm of room between my AC condenser and my radiator and there's some leaves and crap stuck in-between there. i think i'm gonna clean it out and do a coolant flush (hasn't been done in a while). hopefully this solves the problem. please let me know any additional thoughts! much appreciated |
