      10-16-2017, 02:16 PM   #1
Over it
Mad Man
Drives: car
Please Help Z4 M Coupe Pre-Purchase Time Sensitive
Thanks in advance for helping to make this Z4MC mine
I am about to buy this car. It is at the dealership now. I need advice please. Here are the inspection reports from the Z4 M Coupe I want to buy.
Inspection says:
Replace Alternator/AC Belts and tensioner
RED oil leaks
Oil sweating from O-ring on Constant Pressure Valve
Actual reports below. I want this car, does this report throw up any red flags, and anything that should be done at the same time as the Constant Pressure valve O-Rings?
Are there any hard to get at maintenance or preventative maintenance items that should be done at same time?
      10-16-2017, 03:02 PM   #2
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
The CPV oil leak is very common and no big deal. I have to do the work on my ride as well. I don't see any red flags from this list but then again sounds like you are purchasing the car from the same dealer who performed the PPI? They could be hiding major issues if there happens to be any and if they are dishonest. Just my 2 cents
The Raspinator
      10-16-2017, 03:14 PM   #3
Over it
Mad Man
Drives: car
Th
Car is private party. I chose the dealership since they have serviced it in the past. The first inspection notes were items I specified to be checked. Is the belt tensioner difficult to do?
Anyone else ? All input appreciated
SMOUPE thanks for the speedy reply.
      10-16-2017, 03:42 PM   #4
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
Reports look pretty good. The belt tensioners are approx a 3 hour job and $150(US) in parts according to pelican parts out of the usa. I would dump those tires asap and get michelin pilot sports. Mine had original contis which I changed out that rode like hockey pucks and u know how bad the roads are here! Try and get the dealer to print out a list of all service done at bmw dealers- I was able to get that. Good luck
      10-16-2017, 04:28 PM   #5
Over it
Mad Man
Drives: car
Current private party owner is going to replace the belts, tensioner, and oil control valve. He will buy new parts so I have the receipts. Dealer won't release the records to either one of us since the work was for the first owner. They show on Carfax though. Tires will be RE71R for B Street SCCA Autox. I will eventually get Apex wheels with PSS for daily duty. 18x9x9.5 square.
Cars not mine yet, hopefully the negotiations go well for both myself and the seller.
      10-16-2017, 09:35 PM   #6
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Carl, just an FYI, there is an alternative Viton o-ring for the CPV. It's only a $5 part, but will probably save you from having to deal with it again in the future. It's even available on Amazon, now.
Salty
      10-16-2017, 10:55 PM   #7
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3005
Drives: 340 6MT, 50e, others
84km quite a bit but no red flags.
      10-17-2017, 12:08 AM   #8
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
I don't see anything disastrous. However, since both left wheels have been repainted, I'd double check the car has not been in an accident - including potentially measuring paint thickness with a paint meter.
I hope this is the one for you!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      10-17-2017, 03:28 AM   #9
Over it
Mad Man
Drives: car
Salty
Thanks, I asked him to use the one you suggested
      10-17-2017, 03:35 AM   #10
Over it
Mad Man
Drives: car
The paint was checked, looks like the front bumper has been repainted, although only detectable because of no clear bra. All the usual culprits for rock chips are clear bra'd.
The owner said he thought it was repainted before inspection.
The dealer was asked to look for evidence but reported none which is neither here nor there.
Thank you to everyone who chimed in.
Carl
      10-17-2017, 06:00 AM   #11
Over it
Mad Man
Drives: car
Agreed, however the last Interlagos sold had 46500 on the clock, so 52K isn't too bad.
I continue to look although I have put a deposit on this car.
I expect money will change hands in about a week, perhaps sooner.
This has been a terrific introduction to a very informative community.
I have threads in tire and wheel plus the competition area with requests for guidance.
      10-17-2017, 07:20 AM   #12
chickdr
Drives: 2006 M Roadster
Only on a forum like this one would someone say a 10yr old car with 52k miles is "quite a bit" 5k/yr is pretty decent....
Over it24.00
      10-17-2017, 03:31 PM   #13
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I don't see any potential/possible concerns/issues other than those already called out. CPV leak, meh. Wheels/paint, interesting, might just go with the crazy tire combo though, worth a bit more of a check.
      10-17-2017, 10:59 PM   #14
Over it
Mad Man
Drives: car
This is a very nice car, but it will take a while to sort out the title. So I am still looking and still ready to buy.
Someone must have one sitting unused. I promise to use it well.
Thanks, Carl
      10-18-2017, 09:12 AM   #15
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Never mind...
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      10-18-2017, 03:20 PM   #16
dre99gsx
Drives: 1994 Toyota Supra
You know, for the right price, I could offer you mine Montego is very similar to Interlagos.
Although, finding the exact Z4M you want is a tough one, especially in Interlagos. Searched autotrader entire US, not one.
You also have a handful of honest people on here that can help with technical issues, and I've had great luck with buying/selling parts here as well. Good community.
      10-20-2017, 02:14 AM   #17
Over it
Mad Man
Drives: car
Tempting, your car is very nice, but I have a race car that I am rebuilding.
The photo of your garage is my inspirational photo till I get my own
      10-20-2017, 08:44 AM   #18
Twixboy
Drives: '04 Z4 3.0i 6spd
Welcome to the forum and good luck with your purchase! What part of Hawaii are you in? I just moved back to the mainland from Kauai and I'm already missing island life now that the morning temps here are like the top of Haleakala in the middle of winter.
      10-20-2017, 09:22 PM   #19
Over it
Mad Man
Drives: car
I'm on the Big Island. Just about to re-open the kart(autoX) course after a year of waiting.
Chassis inspection Sunday and then if no surprises I will be buying a car Monday. To ship the following Saturday to me two weeks after that so about a month from now
      11-05-2017, 10:30 AM   #20
Berto61
Berto61's Avatar
Drives: 2007 Z4 M Coupe
Ha, yep!
      11-05-2017, 05:57 PM   #21
Twixboy
It's not a MC, but I still shake my head at the guy on here who traded in his interlagos M roadster with 60k miles go for $16k a few years ago. I say he shoulda offered it to us, but oh well.
      11-07-2017, 03:36 AM   #22
Over it
Mad Man
Drives: car
Crazy tires that aren't even R Compounds, Meh
