04-22-2013, 01:09 AM | #1 |
Rep 501
8000RPM Redline for Z4M?
Probably dumb/weird questions, but here it goes:
When accelerating hard it seems like there's a big loss of power before the 8000RPM redline (maybe around 7800RPM or so). Is this normal? The last orange/amber LED on the tachometer never turns off. Is this normal? What RPM do you recommend shifting at for maximum acceleration (stock)? |
04-22-2013, 01:30 AM | #2 |
///M-fanatic
193
Rep 3,885
Our fuel cuts out at 7900 RPM, so what you felt was probably the fuel cut. Shift at or just before fuel cut for best performance.
And obviously don't rev high for extended periods at a time. |
04-22-2013, 02:25 AM | #3 |
tosser
31
Rep 988
Yup you'll feel that serious loss in power around there...where the fuel cuts out.
My tune is for 8250 max and the motor is still running strong. Unfortunately I'm down on power due to a solenoid (alleged solenoid) but that's a whole other subject.
'07 MCoupe lots of mods |
04-22-2013, 03:22 AM | #4 |
Rep 503
Drives: Z4 M Coupe
This is normal.
04-24-2013, 08:00 AM | #6 |
Rep 299
I usually shift at around 7500 anyway, I don't think there's a lot of advantage shifting above there, and apparently the high RPM's is what kills the rod bearings.
- Wes
2007 BMW M Coupe 2016 VW GTI |
04-26-2013, 03:51 AM | #7 | |
Rep 222
For some reason, the Absolute Throttle Position on the Z4MC at WOT records as being 76.1% rather than 100%, whilst the Calculated Load records as 100% (I don't understand why this is the case, but some other cars also do this. Can anyone explain why ATP at WOT is less than 100%?). Since the throttle of the Z4MC is "drive by wire" the graph shows that the actual throttle position is reduced from WOT after the revs reach 7631rpm although the accelerator pedal was fully depressed. Therefore, it seems that the software is already commencing to reduce the air ingestion in anticipation of the engine rev limiter cutting out at 8,000rpm. The slope of the plot of engine rpm above 7,631rpm begins to fall away, therefore, I would suggest that the optimum rpm to gear shift is just as the needle reaches the amber zone in the tachometer. At this point you have also reached peak power output. |
04-26-2013, 12:20 PM | #8 |
Rep 11,667
hmmmm.... might that be related to your previous tune issue?
04-27-2013, 12:12 AM | #9 |
enthusiast
48
Rep 1,695
There are many reasons where it benefits speed to go above 7500 on a track, but if you don't need to.......
04-27-2013, 01:58 PM | #10 |
Rep 376
Very good information that further supports shifting at 8K doesn't help you.
If there were only a way to graph rod bearing wear in the 7500-8000RPM range.....
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
04-27-2013, 02:35 PM | #11 |
Rep 4,726
Whatever you used wasn't logging data with anywhere near often enough, it should be 10-20 times a second minimum, not 2.
04-28-2013, 02:06 AM | #12 | |
enthusiast
48
Rep 1,695
Carrol Smith explained this the best, but I will attempt to give an analogy. If you made a graph showing your hp at all the rpms, you will see something like this (just an analogy, not necessarily your hp numbers): 6500 at 240, 6750 at 245, 7000 at 250hp, 7250 at 255, 7500 at 260hp, 7750 at 265, 8000 at 260hp, 8200 at 255hp. If you were racing, if you shifted at peak power:7750 you would have at least a 1000 rpm drop and that is being very generous. More like a 1500-2000 rpm drop on most cars. Add all those numbers up between 6750 and 7750. If you shifted over the peak at 8200 with a 1000 rpm drop, you will only be at 7200 rpms. Add up all the hp numbers. The number that is the highest is where you should shift to give the most power. Also, rod bearings are not damaged by running at 8000 or even 10,000 rpms assuming you have adequate oil pressure at those rpm's. Most race motors have an upgraded oil pump, especially the s54. Upgrading the oil pump can also allow you to run a thinner oil and run cooler than stock and it will increase the power output of the motor to the rear wheels. There are other parts of the motor that won't handle 9000 rpm's well, but I won't get into that here. |
04-28-2013, 03:56 AM | #13 |
Rep 222
I agree it's not ideal but that's the "polling rate" that the ECU yields to an OBDII datalogger using all the cars OEM sensors 4 PIDs at a time. At the end of the day, ECU datalogging gives a series of "time-lapse snapshots" which gives a very good indication of what is happening and this doesn't devalue the information in any way. The Absolute Throttle Position still starts to reduce before the redline, which explains what the OP has observed.
04-28-2013, 04:15 AM | #14 | |
Rep 222
23.4m/sec Honda S2000 84mm stroke @ 8300rpm 24m/sec BMW S54B32 91mm stroke @ 7900rpm 25.1m/sec Formula 1 40mm stroke @ 19000rpm This gives some idea of the level of performance of the S54 engine. I've experience catastrophic bearing shell failure in my S54 Z3 M Coupe (redline at 7,600rpm) as in the photo below. |
04-28-2013, 08:06 AM | #15 |
Rep 441
^it's a shame bmw didn't extend the bearing recall to the early s54 z3m's, all the early s54's had that issue
iirc the s54 is the 4th fastest piston speed of any production car....quite impressive engineering |
04-28-2013, 08:15 AM | #16 |
Rep 222
04-28-2013, 08:59 AM | #17 | |
Rep 4,726
You are however correct that it closes some in anticipation, but nothing like your graph shows.
04-28-2013, 09:08 AM | #18 | |
Rep 4,726
As for the shift points, that is a very poor explanation, though it does sort of correlate with the correct. Shift points are wholly determined by thrust at the wheels. Thrust at the wheels is determined by torque and gearing. Essentially what you are looking for is where your wheel thrust in the current gear drops below where it will be in the next, that is the point you shift at. You cannot find this point simply by following your explanation and "adding up" HP numbers.
04-28-2013, 10:04 AM | #19 | |
Rep 222
04-28-2013, 02:15 PM | #21 |
Rep 4,726
Anything could have happened between those two data points. Just because I demonstrated to you why your results are invalid doesn't mean I'm going to correct them for you.
04-28-2013, 10:38 PM | #22 |
Rep 1,739
Drives: 2008 Z4MC
It's the same DashDyno unit that is telling him his stock Z4M is now making 370RWHP with the help of his home made intake (or roughly 450hp at the flywheel).
