10-03-2010, 09:50 AM | #1 |
Rep 38
Installed H&R springs now Xenons won't auto level
Installed a set of H&R lowering springs yesterday and now my Xenons are aimed low and will not auto level. Tried to search the forums but did not really come up with any good answers. I read the auto-leveling function is tied to the front suspension but I am not sure what I can check to fix the problem. I am more concerned with the auto-leveling function suddenly locking up after lowering the car. Any help is much appreciated.
10-03-2010, 10:10 AM | #3 |
Rep 38
Tried flicking the highbeams on and off but that did not help. It seems the initial starting point of the auto-level function is too low. It appears the Xenons do raise or auto level just an inch or less. I think I may have to adjust the initial aim point at start up.
10-03-2010, 10:13 AM | #4 |
Rep 2,747
Check here. This controls the system level and is on the passenger side. You have to disconnect it when you intall/remove suspension.
10-03-2010, 10:44 AM | #6 |
Rep 421
I don't think you could have removed the strut/spring without disconnecting it, either intentionally or by accident. You need to pull the wheel and look in there and see if its damaged or disconnected.
10-03-2010, 10:55 AM | #7 |
Certified Adrenaline Junkie
43
Rep 1,325
On my E46, I forgot to disconnect it while doing suspension and it breaks the plastic clip. You may need a new sensor. I was able to drill a hole and fab it up to work. Pull the wheel off and take a look at the LCA.
10-03-2010, 01:24 PM | #8 |
Rep 4,320
Drives: '07 Z4 M Coupe
Like the other guys said; you probably disconnected it accidently.
Pull the front passenger wheel and take a look. If it's not broken, reattach it.
10-03-2010, 02:58 PM | #9 |
Rep 38
This is why I appreciate the forums and the help. You guys were right. Pulled the wheel off and the sensor had broke. A little fab job and all is good again. Thanks again for the quick responses and pics. I will post some pics with the lowering springs in a few. Thanks again.
