02-18-2010, 06:07 AM | #23 |
BMW Fan
11
Rep 553
I too have changed many sets of springs on BMWs. I have to disagree about the comments that you need an alignment. Lowering the car by one half inch will not cause a change in alignment sufficient to justify the expense. Tire wear will not be increased. In the rear, no parts are removed that would result in an alignment change, and the lowering by one half inch is insignificant. In the front, as long as the strut is replaced in the same position at the top (the upper strut mount) as it was originally, there should be a minimal increase in negative camber (which is good) and no change in front toe. Therefore an alignment after proper installation of these springs is unnecessary. If you are concerned about the expense of installation, wasting another $200 on an unnecessary alignment doesn't make sense.
02-18-2010, 09:59 AM | #24 |
Rep 94
Drives: 2005 Z4 3.0i/SMG
I'd be happy to assist you with this, and I have the tools necessary to complete the job. However, I am going out of town this weekend and won't be back until next Friday. You are more than welcome to borrow the spring compressors if you want to get started on this sooner. PM me your contact info and we can make arrangements (I live in Loudoun county as well).
Regards, David |
02-18-2010, 12:32 PM | #25 |
BMW Fan
11
Rep 553
A word of caution. Coil spring compressors are one of the more dangerous tools used in typical aftermarket parts installation. The compressed spring has stored a large amount of potential energy. If you don't use the spring compressors properly and a spring is released suddenly, serious injury could result. Please be careful and have someone show you how to do this who has experience.
02-18-2010, 05:30 PM | #27 |
Rep 1,721
True I bought the springs from vicj. I need to get wheels aligned anyway... Will BMW do this as part of the maintenance program?
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
02-18-2010, 06:06 PM | #28 |
Rep 316
No. You'll have to pay for it, unfortunately. And you WILL need to align the car, despite what these "experts" on a chat board are saying. Half an inch is plenty of drop to greatly effect the alignment, particularly the Camber. Since our cars already have a little extra camber in the set up, the drop will exaggerate this, greatly reducing your tire wear. Without camber plates, you won't be able to dial it all back out, but they'll be able to get close. IMO, it's worth the extra expense.
02-19-2010, 04:04 PM | #29 | |
BMW Fan
11
Rep 553
02-19-2010, 05:26 PM | #30 |
Rep 80
It's not so much that you need an alignment to reduce uneven tire wear. There are caster, camber and toe. When you lowered a car, even half inch, one, two or all three of these will be off. If the toe is off unevenly on both side, like toe-in on one side and toe-out on the other, the car will handle like crap. If the toe is off in the rear, sometime the steering wheel will sit crooked, and so on. So, if your car handles funny or the steering is crooked after lowering the car, then YES, you need an alignment immediately.
02-20-2010, 10:25 AM | #31 | |
Rep 316
Either way, a $100 alignment at a reputable BMW shop is pretty cheap insurance for your expensive tires...but that's just me.... |
02-20-2010, 07:13 PM | #32 |
Rep 1,721
Springs are installed! Thanks Wildng! Took longer than anticipated because the front struts need a 24mm and neither of us had one.
First impressions are that the ride quality is pretty much the same. Can't say any more than that because it's dark and the roads are frozen and have salt and gavel all over them. More to come...
02-23-2010, 09:16 PM | #33 | |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 02-23-2010 at 09:23 PM.. |
02-24-2010, 09:21 AM | #34 |
///M'n it Up
17
Rep 344
FYI, when we took off the stock springs, we had to use a spring compressor, but we really didn't have to compress them very much. When we installed the Dinan springs, we didn't have to use the compressors, because the springs were just barely short enough that we could thread the top nut without compression.
02-24-2010, 09:45 AM | #35 |
Rep 240
I'm no mechanic and did my own springs installed which took me 1hr in the rear and 2hr in the front for a total of 3 hours. 5hr for a spring install is not reasonable, find another shop.
