      05-07-2013, 10:47 AM   #1
sclui56
Drives: E86, IS-F, G42, G87
Rear side window molding replacement
The bottom strip of the rubber surround is getting gummy on my 3.0 coupe, does anyone know how this is fitted? From looking at the diagram, it appears to come with the glass (part 4)
04 Side window, rear left 1 51373420807 $97.29
04 Side window, rear right 1 51373420808 $97.29
      05-07-2013, 12:30 PM   #2
silverfishZ4M
Drives: 2007 Z4M Coupe
I took my car to the dealer for this, they said I would have to buy the whole window. I didn't end up getting it done (it's not covered under CPO).
      05-07-2013, 01:16 PM   #3
sclui56
It looks that way, will check out how the piece is attached, don't want to introduce leaks just to fix one thing. I noticed the rubber on the Z4 is somehat sub-par in general, my 6 year old 7 is still fine and my wife's 7 only had issue with the rear window molding after 8 years, and her vehicle is exposed to the elements everyday.
OTOH, the Z4 already shows issues with the 2 rear side windows as well as the windshield trim (cracks), and the cowl plastic has already been replaced once for warp.
      05-07-2013, 01:26 PM   #4
silverfishZ4M
i think my BMW dealer told me the window was $250. Crazy markup.
      08-07-2014, 06:34 PM   #5
shock311
Drives: 2008 BSM Z4MC
Apologies for resurrecting an old thread but I recently purchased an 08 coupe and I've noticed the same area gum up too. Any luck on anyone attempting a DIY on this or found an alternative to fix this area of the window?
      08-08-2014, 02:34 PM   #6
Schlesien
Drives: 2007 Bmw Z 4 M Coupe
I replaced my quarter glass a few months ago for the same reason; it comes as a unit with molding, you need to order the whole window; I had mine installed by an automotive glass shop since you always run a risk of leaks if you diy it and they guarantee the job; you need to cut the window out with a super-sharp blade very close to painted surfaces, you need to buy professional glass glue etc., too many things to worry about and too many liabilities for this little guy, paid $130 for glass delivered and $125 for install; not cheap for a piece of weathered rubber but then again your're looking at it everyday😶
      08-10-2014, 12:57 PM   #7
shock311
Thanks for the insight. I figured as much, this will now be on my refurb list for this car. I get up to Sonoma now and then again for work, what was the shop you took it to if you dont mind me asking?
      08-10-2014, 04:21 PM   #8
Schlesien
It's called Reliable Glass and they really are, they do work for local body shops; they are in Rohnert Park which is another 25 minutes northwest of Sonoma, or 15 if you own a car you do and have a good V1 on your windshield; their phone is 707-877-6978; also, the part #s for quarter glass you posted are correct, I got mine from Bmw of South Atlanta, lots of others wouldn't ship glass for some reason
      08-10-2014, 04:26 PM   #9
Schlesien
You might also consider that the job takes about 2 to 3 hours because of glue curing time
      08-10-2014, 10:42 PM   #10
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Would be cool if someone could do a DIY on this. Mine also needs replacement.
      08-10-2014, 11:21 PM   #11
Schlesien
Yes indeed, I'm sure human ingenuity will tackle this one at some point somewhere; in the meantime, however, any recycling ideas for the old window that's still perfect take away rubber?
      08-11-2014, 12:27 AM   #12
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Yeah mate, I'd keep it in case you need to gain access to your car unauthorized like one day.ask me how I know, I just finished getting my jeep window retinted.
      08-11-2014, 12:31 AM   #13
Schlesien
My idea was keep it for neighbourhood kids to watch next solar eclipse
      09-05-2014, 02:58 PM   #14
jpwbrown
jpwbrown's Avatar
Drives: 2007 Z4 coupe
yeah, I noticed that my rear windows seals were gummy and couple of yrs ago. I've had to replace windshield seals twice now. But I live in the southwest where the the sun beats down on us about every day.
      09-05-2014, 03:38 PM   #15
doozyj
doozyj's Avatar
14
Drives: 2007 M Coupe
Mine was like that and I was going to order both sides...but...
Before I did that I tried using WD-40 on them. Simply spray on the gummy part and rub with your index finger, don't rub it with rags as your finger will make sure it will be flat and smooth. You will notice it will start to dissolve the gummy layer only, Do this a few times till all the gummy part is dissolved. Simply clean area with soapy water and rinse then finish it off with your favorite protectant.
Please try this first before spending money on replacements and let us know your results. Mine came out beautifully!
      09-06-2014, 02:04 AM   #16
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
lol, recon if I did that, id have no rubber left
mines way to far gone for that. I can push my nail all the way to the paint if I apply a little px.
might give DIY a go before I get it done... bloody deer though...
Powered by
      09-06-2014, 09:58 AM   #17
OleSport
Drives: 07' M COUPE BLKonBLK
Originally Posted by doozyj View Post
Mine was lie that and I was going to order both sides...but...
Hmm... that sounds interesting. Yeah that gummy part is such an eyesore driving me crazy!
      11-01-2022, 03:08 PM   #18
lanoipat
Drives: BMW Z4 E86
Old post but I did what you suggest and came perfect !
Took me 10min
Then I applied Black Plastic Restorer from Garage Griot .
Thanks
      11-06-2022, 11:07 AM   #19
Landiko10
Drives: Z4 2008 Coupe
I just purchased my 2008z and it has the gummy feel in both sides. Plus the front windshield is blurry with cracked seals. Im gonna replace the front but I’m gonna try the dw-40. Thanks for the tip!
