      12-03-2022, 05:43 PM   #1
Ranger_Vet68
Ranger_Vet68's Avatar
Drives: 2003 Z4 3.0i E85 Roadster
Car Battery
I own a 2003 BMW Z4, and I was wondering if the Z series or any other performance series of cars take special car batteries. I'm asking because I replaced the original battery with a new one without doing homework on the best battery for the vehicle. Could someone please help me out with this issue?
Thank you.
      12-03-2022, 07:12 PM   #2
pungo
pungo's Avatar
Nothing special about the battery on a 2003 as long as you get the correct size/capacity, even a Walmart battery will work fine.
wdb4732.00
      12-03-2022, 07:23 PM   #3
Piper1
Piper1's Avatar
Drives: E85
To add make sure you’ve got the vent tube being trunk mounted
      12-05-2022, 11:23 AM   #4
Ranger_Vet68
Yep, I made sure that the vent tube was mounted. Thank you all for the info. I guess I'm just behind in the times. I remember when certain cars took different types of batteries.
      12-06-2022, 06:49 AM   #5
bob'smerlot
Drives: 2004 bmw z4 3.0i
You want an AGM vs a lead-acid correct?
      12-06-2022, 08:31 AM   #6
wdb
dances with roads
wdb's Avatar
4732
Newer BMWs can be fussy about the ampere hours of the battery being replaced. This is because they over-engineered the charging system to be specific to the battery size. You have to either replace with the same capacity battery, or else get your car reprogrammed for the new battery capacity. Luckily that idiocy stayed out of our E85/6 cars.
