06-23-2013, 08:12 PM | #1 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Autosolutions SSK Installed - shifter rod angle changed ?
Just had my Autosolutions SSK Installed - feels great ! nice and firm... however it seems as if the angle of the shifter rod has changed and is now leaning towards the right.
This is how it sits in neutral This is 6th This is 1st Did anyone else notice this change or did something get installed incorrectly in my case ? Last edited by Daemonblitz; 06-23-2013 at 08:33 PM.. |
06-23-2013, 08:15 PM | #2 |
Rep 11,667
Looks a little strange
No such issue with mine.
06-23-2013, 08:32 PM | #3 |
Commander
221
Rep 850
Does the rod have a bit of a tilt towards one side ? is it possible it was put on backwards and it's leaning in the opposite direction ?
06-23-2013, 11:38 PM | #4 |
Rep 1,663
If you check the autosolution's page you'll see they bend it in both plains so the shifter ends up in the stock position.
My guess is it's installed backwards or you got the RHD version? The position in neutral looks wrong.
06-24-2013, 09:37 AM | #5 |
Rep 400
I think somebody else had this same problem after install. If you search you might be able to find it. They took it apart then put it back together and fixed itself. It should be in the stock position when done.
06-29-2013, 07:43 PM | #6 |
Commander
221
Rep 850
Had a chat with the tech who installed it, turns out that the shift rod itself was installed backwards - will be going in next week to get it switched over.
