08-19-2013, 11:02 AM | #89 |
Rep 879
That sucks. Hope you are OK. Even low speed accident sometimes create back/neck problem.
One of my friend crashed his Lotus Seven a month ago and the next day a guy died at LCMT in a 997 GT3. This sport remains dangerous. So the limp mode problem would be cause by the sensor on the brake booster? Wonder how hard it would be to disable it. I hope ESS will consider to disable it now for guys who track their car at least... |
08-19-2013, 11:06 AM | #90 | |
#buildnotbought
10981
Rep 4,912
I don't know where 2F65 can originate. Maybe it's in the electrical connection to that valve? (so that the ecu measures its continuity or something like that) The strange thing is that that valve is only present on the z4m. The e46 m3/m3csl dont have an electical valve there; just a normal passive non return valve I think. 2F65 is indeed a brand specific code: Brake booster, system check
08-19-2013, 11:59 AM | #92 |
#buildnotbought
10981
Rep 4,912
brake booster uses vacuum force to assist in force of braking.
The brake booster is the large round black pot mounted to the back of the engine bay
08-19-2013, 12:02 PM | #93 | |
Rep 912
Could this be the case? check my Z4M crash thread. |
08-19-2013, 07:25 PM | #95 | |
enthusiast
48
Rep 1,695
08-19-2013, 07:48 PM | #96 |
Rep 2,706
I had the orange brake light come on on my car on Saturday as well as the ABS orange warning light during a car cruise in Detroit.
The brakes seemed to work as normal but I was not driving at speed either. Turning the ignition off and on cleared the light from the dash and all seemed normal after. My car is boosted with a VF kit. |
08-19-2013, 08:20 PM | #97 | |
#buildnotbought
10981
Rep 4,912
The chances of both having the same problem (expecially such a code, this is not a common problem!) after the install and unrelated to the instal are....probably 0% It seems to me the fix has to come from ess.... Normally i'd say that that code is maybe related to the DSC/ABS. There are 2 pressure sensors on the master cilinder itself. Maybe they can measure if something's wrong with the vacuum. But that has nothing to do with the sc install. I think it's an ECU/tuning problem and not a hardware problem.
08-20-2013, 12:32 AM | #99 |
636
Rep 3,124
I don't have FI, so I don't have any skin in this game, but I am a Rocket Scientist, so I can't help but make a basic observation.
If you're running positive manifold pressure, where do you get vacuum for the power brake booster? Granted you don't have positive manifold pressure all the time, and the check valve should allow the brake booster to store vacuum, but if it leaks just a little, and if you brake while you have positive manifold pressure and use it up ... low vac in the brake booster, warning light, "life saving" (lawyer thwarting) limp mode, and possible actual weak power braking. If you're driving "aggressively", you're kinda playing the odds. Especially if you heel-toe. Are you producing as much vacuum as you're consuming?
08-20-2013, 02:22 AM | #100 | |
Rep 912
But i understand what you're saying. |
08-20-2013, 07:31 AM | #101 |
Rep 915
With a turbo charger, as soon as your off the gas, you are in vacuum, even more so when decelerating. Since your blow off valve goes off relieving the intake tract pressure, as well as your exhaust energy dwindling, reducing turbo charger rotation, thus eliminating any chances of boost.
With a supercharger, she is always in boost, even when you let off the gas. The bypass valve will bleed off all of this extra air to atmosphere in a long deceleration. There should also be a one way valve into the booster. If either the bypass valve or one way valve malfunction, and you get pressure (or loss of vacuum) into the booster, you are essentially running "booster-less". Still, you should be able to apply enough manual braking force to slow down a vehicle in that situation. I would recommend installing a secondary one-way valve into the booster as a precaution. Us Supra guys come with a large one way valve right at your disposal going into the booster itself. Also, I don't believe the Z4M has an accumulator? There are vehicles with vacuum storage canisters for an extra supply of vacuum. If you don't supply additional vacuum to a brake booster, you have limited amount of braking "presses" before it stiffens up. As an aside, the M3 crowd has been Supercharging/ESS'ing for quite some time. Any input on their regarding brake booster modifications (since they have similar engines)?
Andre - 2J into a Z4 Coupe!
08-20-2013, 08:32 AM | #102 | ||
#buildnotbought
10981
Rep 4,912
Further more a bmw has a 'jet suction pump' which is a device that can draw extra vacuum by means of the venturi effect. (in theory the jet suction pump could draw vacuum when the tb's are open, but I don't know if that also effectively happens irl.) The jet suction pump uses a small bypass around the tb to create a small airflow to the cilinders. The strange thing is: the z4m has an electrically controlled valve between that, so the ecu can stop that flow and so stop the jet suction pump from functioning. Why is that. No other bmw has that, even not the the e46 m3 or m3csl (which presumably has exactly the same engine).
08-20-2013, 11:50 AM | #103 |
Rep 5,329
Think ESS could do with chiming in here tbh..... it really needs their input....
08-20-2013, 12:26 PM | #104 |
enthusiast
48
Rep 1,695
08-20-2013, 12:58 PM | #105 |
Rep 912
08-20-2013, 05:08 PM | #106 |
Rep 2,176
I'm still waiting to hear from AJ . I will let everyone know what we come up with . I know others have had the yellow brake light limp on track . The frustrating thing is it seems like it can occur from temp as well as possibly other sources. One thing I know for sure my brake booster was 100% great pedal feel no fade as usual with my PFC brakes . This time my oil temps were in the 240 range with water temps in the high 210's so temp doesn't make sense either . The real issue is the nature if the limp . A complete cut of the throttle . In my case it caused a wreck , and if I can't be sure it's 100% taken care of I am going to have to get rid of a car I've put a Ridiculous amount of money into setting up for the track .
08-20-2013, 08:26 PM | #107 |
Rep 879
Same thing here, I will most probably go back NA with my car in a near future and if the problem still happen, I might sell the car to get an E46 M3 and swap all my goodies on it.
Or maybe consider a Motec/AIM Pectel T2/KMS ... |
08-21-2013, 05:03 AM | #108 | |
Rep 2,176
08-21-2013, 06:47 AM | #109 |
Rep 912
08-21-2013, 10:39 AM | #110 |
Rep 879
