      04-20-2010, 08:20 PM   #1
dyerkes
dyerkes's Avatar
Drives: 2005 Z4 3.0i/SMG
2005 Z4 3.0i  [0.00]
Z4M - Carbon filter canister
Can someone let me know where the carbon filter canister is located on a Z4M? I know non-M's have it mounted immediately behind the passenger side fender liner, but I don't imagine that's where the M's is because of the passenger side muffler would occupy most of that space.
Thanks,
David
      04-24-2010, 10:34 AM   #2
dyerkes
dyerkes's Avatar
2005 Z4 3.0i  [0.00]
If anyone else wants to know the answer, the Z4M hides the charcoal canister under a plastic cover mid-way between the two mufflers. On the non-M, this is where the batter box is.
- David
      05-03-2010, 03:36 PM   #3
Z4Mster
Drives: 2006 Z4M
What is the purpose of this device?
      05-10-2010, 09:50 PM   #4
dyerkes
dyerkes's Avatar
2005 Z4 3.0i  [0.00]
z4mster,
It's part of the emmissions system. It captures gas fumes escaping from the gas tank and redistributes to the intake system to be burnt.
David
      05-11-2010, 03:44 PM   #5
Z4Mster
Drives: 2006 Z4M
When does it need to be replaced?
      05-12-2010, 02:22 PM   #6
dyerkes
dyerkes's Avatar
2005 Z4 3.0i  [0.00]
The charcoal canister should last for quite sometime (100k+). A non-functioning canister will throw a check engine light if it does become clogged, or leaks.
-David
