      02-11-2009, 11:37 AM   #1
Mikewarlover
Mikewarlover's Avatar
Drives: white
are csl headers a direct fit on to our cars.
Hi i have been looking into headers and just wonder are all m3 headers a direct bolt on ss, or csl . I think the cats are different. Also can u just run header with oem cats.
Modified CDV/Rogue Engineer Short Shifter/ RE Diablo Exhaust/ Matte Black Grill/Lighted ZHP shiftknob/Stubby Antenna / 19inch gunmetal Neez Super Euro Cross on Michelin
      02-11-2009, 03:17 PM   #2
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
The primary cats are in our header. Secondary cats are after headers. CSL should bolt up but I have no idea where to buy them or what the benefit would be over other headers...especially if cost is high.
      02-11-2009, 03:38 PM   #3
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
http://www.turnermotorsport.com/html...3-EURO-HEADERS
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      02-11-2009, 04:15 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Originally Posted by MVF4Rrider View Post
Euro headers (those euro headers) are NOT csl headers though they look similar.
That said, euro Z4 Ms use TRUE CSL headers, so yes they bolt right up.
Issue is you only have 2 bungs in the headers. You need a tune to delete the secondary o2s anyway, but you will need to find a way to get the EGT sensor into the headers or midpipe.
      02-11-2009, 04:16 PM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Also, turner advertises a lot of stuff for e46 M as for the z4m as well that does NOT work for the z4m so be very careful when purchasing anything for the z4 ms from them and get it in writing somewhere that they claim it's for our car. (like the shark injector, which will not work on our cars.)
      02-11-2009, 06:24 PM   #6
mpower03
Drives: 08 z4 M Coupe
here you go:
http://store.bimmerworld.com/shared/...t=products.asp
      02-11-2009, 06:26 PM   #7
mpower03
they look the exact same in both of the pictures... so idk.. they are probably advertising wrong
      02-11-2009, 08:50 PM   #8
Mikewarlover
Drives: white
so only true csl headers willl work not euro headers? wat other headers work for our car? Supersprint ?
      02-11-2009, 09:15 PM   #9
mpower03
any header off of a e46 m3 should work... for the most part. there is active autowork, agency power (same as ebay i believe), supersprint (ebay headers are a copy of ss, i believe), and more. i just bought the ebay headers last week and i am installing them this weekend. several people on the forum have them installed on their car, and haven't run into problems.
      02-11-2009, 09:19 PM   #10
mpower03
oh go on m3forum.net, search headers for the e46 m3. you will see a ton of stuff pop up, take your time and read them you will learn quite a bit from them.
      02-12-2009, 01:01 AM   #11
Mikewarlover
Drives: white
I am really concerned about the quality of the Ebay headers...
      02-12-2009, 02:21 AM   #12
O-cha
O-cha's Avatar
218
Drives: Mcoupe
No euro headers will work as well, but they arent the same as csl headers, same basic design but they are formed in a different way for instance.
A valid concern, just finished another set today and they were of course like all the rest.
If the Idea of hammering headers onto your engine bothers you enough to be worth 1kish (along with all the other stuff) I would not get the ebay headers.
      02-12-2009, 04:05 AM   #13
Mikewarlover
Drives: white
so ocha any idea of power gain from euro or csl header? more from csl maybe?
      02-12-2009, 10:06 AM   #14
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Probably not no.
      02-12-2009, 10:43 AM   #15
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Not sure the part numbers of what Turner sells, but the Euro Z4 M headers and M3 CSL headers share the same part numbers.
      02-12-2009, 10:46 AM   #16
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Are they? I had no idea.
      02-26-2009, 08:46 PM   #17
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
Is it worth the extra 500 bux to get the stepped headers from supersprint? What exactly is the benefit of this option?
      02-27-2009, 10:05 AM   #18
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
So by installing something like this:
http://store.bimmerworld.com/shared/...immerworl&All=
We would be effectively removing the first stage cats that exist in our stock headers, correct? The sensors pull data from these cats and not the secondary ones, right? So therefore we need to either tune to ignore the absence or install the sensors and tune to account for the change in data (so as to not throw a SES light).
      02-27-2009, 01:36 PM   #19
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Fuel is determined by the primaries, the secondaries read after the cats and look for a leaner change from the primaries. Without the cats, no change, without a change, unhappy ECU.
Most tunes remove them in the same fashion, that is basically disable them completely so that they don't even need to be plugged in (room for a wideband )
      02-27-2009, 01:38 PM   #20
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Stepped headers are bigger in diameter, the CSL or euro headers only have 1 set of bungs (can't put secondaries in or a wideband if you need/want to without some cutting and welding).
I think you have to use supersprint S pipes with the step headers though, which they do not make for our car.
      02-28-2009, 08:28 AM   #21
F360C
Drives: E86 S54
Here is a thread from m3 forum that sheds some light on the CSL vs Euro header debate. This guy after alot of trouble found out that the pre- 03/2005 m3's do use a different header then the CSL but post 03/2005 euro m3's use the same header as the CSL.
http://www.m3forum.net/m3forum/showt...ght=header+diy
07 Z4 M Coupe AW/IR
      04-20-2009, 12:38 PM   #22
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
Have you installed these yet?
If so, level of difficulty?
