07-24-2012, 11:18 PM | #2 |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
camber is adjustable. telling us you are on a pro kit and giving a tire size tells us nothing about your camber. you are going to have to get an alignment to see how much camber you are running. btw too much or too little toe angle will wear your tires more than having too much camber.
07-25-2012, 04:15 PM | #3 |
enthusiast
48
Rep 1,695
Your front camber is very low for a BMW. The rear is a lot for a daily driver. It is actually a lot for the rear of a track car.
1.5-2 front and .5-1 rear is a decent daily driving amount. |
07-26-2012, 09:51 PM | #4 | |
Rep 55
I'll bring it back to see if he can adjust the rear into spec |
07-26-2012, 10:33 PM | #5 | |
Rep 4,531
Im running -2.3 w/zero toe upfront and -1.3 maxed out in the rear with 1/16 toe in. Excessive toe w/camber is asking for trouble |
07-27-2012, 03:57 PM | #6 |
Rep 55
The tech told me he can not turn this bolt any further (photo below) and that I need to get this bolt from the dealer, with a thicker washer, so he can adjust it back to spec.
Anybody knows what this bolt is called and anyone here had to replaced this bolt bc of the pro kit? |
07-27-2012, 05:22 PM | #7 |
Rep 2,138
Drives: Me
For a 3.0i Roadster:
http://www.realoem.com/bmw/showparts...39&hg=33&fg=30 You never stated what MY and car you drive. |
07-28-2012, 01:25 AM | #9 |
707
I believe the specs for the non-M are:
Front Camber = range of -0.5 deg to -1.4 deg Front Toe = +0.05 deg to +0.18 deg (toe in) Rear Camber = -2.6 deg to -3.1 deg Rear Toe = +0.17 deg to +0.37 deg (toe in) So you're within specs for your model. Front is fine, maybe a little less toe-in would help with tire wear, but you're not running that much negative camber, and the toe-in isn't excessive. You'd probably get better tire wear rear with it closer to -2.6, but getting it there with control arms is a PITA (DIY). |
07-28-2012, 05:58 AM | #10 |
Rep 2,138
Drives: Me
The question I have is HOW does one get that much rear camber on STOCK camber arms? Most I have ever seen on stock arms is -2.1. I personally cannot get more than -2.0.
This is not a criticism, just want to figure this out. |
07-28-2012, 06:46 AM | #11 | |
Rep 4,531
Mine are maxed at -1.3 rear |
07-28-2012, 08:20 AM | #12 | |
Not a New Member
94
Rep 925
basically, the dynamic suspension geometry and the power of the engine are considered when choosing the alignment of the wheels. if the ride is soft (and for the nit-pickers out there...yes, we all know there's nothing soft about a z4's ride) and the power is small, then dialing more aggressive alignment settings will give the car a sportier feel through the turns. guaranteed... if the non-///m cars had the same alignment as the ///m cars, they would feel much slower and sloppier.
07-28-2012, 08:48 AM | #13 | |
Rep 55
car is currently on the lift and the tech is going to adjust toe out to compensate for the neg camber New spec sheet below with rear camber at -2.9 |
07-28-2012, 03:47 PM | #14 | |
Rep 55
it's good to know I'm within spec, but unlike others here -2.9 is my minimum setting :0 |
07-28-2012, 08:11 PM | #15 | ||
707
07-28-2012, 11:07 PM | #16 |
enthusiast
48
Rep 1,695
When I bought my car, and before I raised the car-----it had nearly 4 degrees front and 3 degrees rear. So, I know it is possible with the M coupe.
07-29-2012, 04:49 PM | #17 |
Rep 881
ohhh there is a picture of your alignment specs! no wonder i didnt get your post...lol. looks like you got it all sorted out.
07-29-2012, 09:18 PM | #18 |
Rep 1,224
On my 07 Si I'm running -1.3 front and -2.5 rear with Eibachs and stock arms. Toe is 0.11 front and 0.13 rear degrees.
Car handles great, noticeably better then the original sport setup. Only have a few thousand miles since the springs/alignment so can't comment on tire wear.
