12-31-2011, 06:18 PM | #1 |
Rep 55
Soft top drain holes clog - roof motor dead
These photos below depicts where the plugs are located and how to unclog them to prevent water damaging your roof motor. Just replaced my motor for $900
the plugs are in front of the rear wheels and very close to the fender you can reach in the pull it out without lifting the car up or taking the wheel out the plug on the driver side (motor location) is all filled with debris Compressed air gun blasted This is what it should look like. |
01-01-2012, 02:44 PM | #3 |
Rep 69
Good photos and info...I did the same not long ago and I blasted air up the drain tubes as well to blow them out..hopefully this procedure will save the motor if done each year
01-01-2012, 09:48 PM | #5 |
Rep 2,138
Drives: Me
If the debris check valve (what I call it) is that bad, the tube coming down is most likely not as clean as it could be and there is probably large debris (leaves and such) in the equipment wells (where the motor and hydraulic cylinders are located.
Make sure you clean and flush these also. |
01-03-2012, 08:55 AM | #6 |
Rep 1
I just unclogged both drains per this write up...and it helped a ton! Thanks. I ended up leaving the drain plugs out. The right side seems to be a bit harder to get to though. Running water through after cleaning out really helps you gauge how much more cleaning needs to be done.
02-26-2012, 08:45 AM | #7 |
Rep 56
does anyone have a picture showing where it is? (further away from the spot so i can get a better picture to where it is) i took out my rear wheels and couldnt find this plug anywhere in the wheel area.
04-21-2012, 10:08 AM | #9 |
Rep 55
I'm actually fingering the plug with my middle finger as of this photo That should be enough to unclog if you can get the tip of your finger through the soft rubber plug and fiddle with it for a few second and stuff be shooting down your finger Last edited by zzzzz; 04-24-2012 at 07:31 AM.. |
04-23-2012, 10:32 AM | #10 |
Rep 4
Hi Guys,
I am from sunny England..... yea I have a convertible and it rains constantly But I am trying to do this drain unclogging but for the life of me I can not find these drain plugs even from the pictures and I took some pictures and it does not look the same so I am struggling. Also I have the sport suspension so it is sitting very low which means I cant get my head under to see what im looking at... Can anybody give any further advice as to where they are? Thanks |
04-23-2012, 11:08 AM | #11 |
Rep 69
I was not able to do much without jacking up the car...Once you get your head under you can see the rubber plug in fron of the wheel well...use a light because it's difficult to see.
Try Shipkiller's site for DIY info..http://www.shipkiller.com/SoftTopDrains.html |
07-27-2014, 08:56 AM | #14 |
Rep 15
Just purchased my '04 2.5i last month. Even though the power top works great I was concerned about water damage. As per this write-up I was able to finger both the drain plugs. And to my delight both were clear of debris and were nice and dry. I, too, have rather large hands but I was able to get in there - it is a tight squeeze. Thanks for this tip!!
10-22-2014, 06:59 PM | #15 |
Rep 71
Got my z two weeks ago and we've had a day and half of rain here, so tonight I used this DIY to 'finger drain' both plugs. I dont have a jack so i had to just compare the photos and feel my way around. A bit hard to do but eventually found both; however, I managed to pull off and drop the drivers side plug somewhere in the compartment. Should I be worried about the missing plug?
Thanks for the DIY. |
10-23-2014, 06:39 PM | #16 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
I've had both of my drain plugs pulled for over a year without any problems. YMMV.
2008 ///M Roadster
