07-14-2011, 09:51 AM | #1 |
Rep 407
A/T 2nd to 1st downshifting problem. Seriously need help.
I posted this under Engine, Exhaust, and Drivetrain Modification as well, but got no response. I'd really like some help.
The car: 2003 E85 3.0 M54 The problem: There is a bump when I'm coming to a stop and the car downshifts from 2nd to 1st gear. The car kind of bumps/lunges forward a bit almost as if another car very softly rear ended me. I have been experiencing this problem for at least 2 years now. Useful info: Earlier this year, I installed the TMS Underdrive Pulley kit and changed the coils and plugs. Before I began the installation, I disconnected the battery. The job took me about 2 hours. After reconnecting the battery, I noticed that the bump between 2nd and 1st was gone. I didn't run into the problem again until 3 months later. I'm assuming that when I disconnected the battery, the EGS unit was reset and during the 3 months, it was adapting to my driving. At the end of the 3 months I'm guessing it learned how I drive and that's when the bump returned. I've researched this as much as humanly possible and have found almost nothing. Could this be a problem with the EGS unit, which may need an update to fix the problem? Is it a sticky solenoid? I seriously need as much help as I can get with this because I'd like to fix this problem asap. Thank you. |
07-15-2011, 12:34 PM | #2 |
Rep 106
I cant help, but I suggest that you post in a 3,series forum, especially E46 focus since there are a LOT more of them around and tran and engine combo is common.
Jeff |
07-17-2011, 06:20 AM | #4 | |
Rep 407
I think it's only rare here on the forum. One of the forum recommended BMW mechanics in Belleville says it a common problem. But his statement only applies if it's a problem with the valve body. |
07-17-2011, 07:44 AM | #5 |
Rep 106
Regarding the transmission - yes, depending on the year. The Z4 is more closely related to the E46 than to the later E90 cars. And there are a lot more E46 3 series cars than Z4's.
07-17-2011, 07:47 AM | #6 |
Rep 331
Have a look at Service Bulletin 240203 and 240303. Sounds like the same issue you're having.
http://www.faqs.org/car/bmw-e46-series/power-train/ Good luck...
07-17-2011, 12:43 PM | #7 |
Rep 167
Drives: 2003 Z4 3.0i, Black Saphire
Sounds like a sticky valve? Have you tried changing the tranny fluid? There are also tranny additives out there that are supposed to alleviate problems like that by lubricating up the valves. Idk, it might be worth a try!
07-17-2011, 04:45 PM | #8 |
Rep 407
I'll be changing the A/T fluid and filter in 2 weeks. I plan to use Royal Purple. I've never heard of the additive you're talking about. Got a name or site? Thanks a lot.
07-17-2011, 04:46 PM | #9 | |
Rep 407
07-17-2011, 04:54 PM | #10 |
Rep 331
Dealer should fix it for free.
07-19-2011, 09:05 AM | #12 |
Rep 407
BMW won't cover it. I'm having a forum-recommended indy shop reprogram my EGS with all the updates tomorrow. Hopefully that will fix the problem.
I will probably still change the tranny fluid in a week or so. |
07-19-2011, 11:03 AM | #13 | |
Rep 167
As for using Royal Purple in the A/T..... I would stick with OEM fluid. You never know how finicky an auto is going to decide to be, so for longevity sake i would use OEM. Are you having an Indy change the fluid or are you DIY? As i recall from another thread, the process to change the fluid in the auto is quite difficult; requiring the fluid to be heated as so it expands and fills the whole trans.... Can someone chime in on this? I don't want to be blowing bad advice out my ass lol. |
07-20-2011, 06:16 PM | #14 |
Rep 407
Just had my EGS reflashed with updated software and the problem is gone. The software that was on it was the originally released software from March 2002!!
I'm crossing my fingers and hoping that when the tranny adapts to my driving style, the problem doesn't come back like it did 3 months after I disconnected by battery before. |
