04-23-2017, 06:20 PM | #1 |
Rep 2,704
Drive wheels turning in neutral
Car is on jack stands, wheels off.
Engine idling. Clutch is engaged. I know there is residual pressure on the FW. Drive wheels are turning possibly 1 rev every 3 seconds.Is the speed that the wheels are turning an indication of how much clutch pressure is present. I really thought my clutch was going away last year but if that was the case wouldn't the wheels be stationary? Can't sort this out in my mind what the relationship is.
04-23-2017, 10:12 PM | #2 |
Rep 2,546
Without pressing in on the clutch pedal, every gear in the transmission is spinning, just none of them have been selected to spin the output shaft. It's normal gear drag on the output shaft, you can stop the wheels with your hands.
04-25-2017, 02:44 PM | #3 |
1821
Rep 5,337
Yep. I'd be more concerned if it is NOT moving.
04-27-2017, 05:29 AM | #5 |
Rep 2,704
Good to know thanks fellas
Still think my clutch is on it's way out
04-27-2017, 10:14 AM | #7 |
Rep 1,794
Drives: E86 3.0si
Here are two of my favorite engines (Porsche's flat 12 & Matra/Ligier's V12) doing the same as yours.
04-27-2017, 01:16 PM | #8 | ||
Rep 2,546
Start driving up a steep hill in 2nd or 3rd rpm near 3k, hammer the accelerator and determine if the clutch is slipping by monitoring rpm vs mph. Usually you can smell it if it's slipping. |
04-27-2017, 01:19 PM | #9 | |
Rep 912
04-27-2017, 01:56 PM | #10 |
Rep 1,794
Drives: E86 3.0si
The other side of clutch slippage is clutch drag...difficulty selecting or shifting gears. Causes can be: a sticking or warped clutch disc, a weak pressure plate, a worn throw out bearing, or a fault in the hydraulic system (leaking clutch master or slave cylinder). Think a clean, fresh fluid flush every two years is good insurance for long hydraulic life.
04-27-2017, 01:59 PM | #11 | |
Rep 2,546
The only other method I know, is to take the clutch out and measure the thickness of the friction material Last edited by pungo; 04-27-2017 at 03:23 PM.. |
04-27-2017, 02:04 PM | #12 |
Rep 2,704
Yea I have slippage based on accelerating hard up a grade.
LWF and HD clutch on the shelf for the inevitable day.
04-27-2017, 05:13 PM | #13 |
Rep 2,546
04-27-2017, 11:05 PM | #14 | |
636
Rep 3,124
Pilot bearing seized rather abruptly. Still had plenty of surface left on the disc.
