05-05-2009, 10:16 AM | #1 |
Rep 1,224
What's Inside an OE Muffler?
Has anyone opened up a factory muffler (back box) and looled inside? I'm curious why these are 1. so heavy and 2. if they use a baffle or packing design?
05-05-2009, 12:28 PM | #2 |
Rep 12,570
I've seen few posts from you on the topic of resonator, muffler, exhaust etc. It seems not many have experimented with going the custom route or messing with the stocker so unfortunately seems like only way you'll getyour answer is to be the guinea pig.
FYI I recall reading somewhere that the Dinan muffler is essentially a stock muffler that's been gutted? |
05-05-2009, 01:39 PM | #3 | |
Rep 1,224
Dinan probably has done a finese job of this, but it does seem that way. BMW has done a lot of work to make these flow well, sound decent, and be quiet to comply with the various sound level regulations. Maybe a bit of internal work..... Now to find a oe can for cheap.
05-05-2009, 03:11 PM | #4 |
Rep 12,570
honesty, if i could've gone custom (found a good reputable shop nearby), i would've done the same. but since there was none around me i just shelled out the money for a complete system. after having to go through trial and error with few systems, the one thing i learned end of day is that the stocker isn't that bad. some of my "errors" involved putting on some really loud systems with too much drone. i then appreciated the stock system - quiet enough where ride quality isn't sacrificed but still has enough of a low rumble to differentiate itself from others. 2 of my good friends both drove an e46 m3 before trading to their current whip and i recall both being impressed with the stock system.
why not just go simplest/cheapest in terms of order of mods. first start off with mid resonator, run straight pipe into stock muffler. if too loud, go no further and put on a glasspack. and if too quiet, work your way down to the muffler? |
05-05-2009, 05:49 PM | #5 | |
Rep 1,224
Part of the fun is doing the research and if it looks promising, the experimenting. BTW I've followed your posts about your exhaust experiences and have found them to be helpful.
06-05-2009, 12:46 AM | #6 | |
Rep 324
Eisenmann Sport
Take a look at the Eisenmann Sport. You can deal directly with the factory in Germany and they will give you a sweet deal. They will also ship tax free to the States. |
06-12-2009, 07:48 PM | #7 |
Rep 107
Resonators
The mid resonators on the Z4M are exactly that and not cats I was told by a dealership mechanic that the confusion stems from the cats being built into the headers for US versions. The Euro versions have the cats where our resonators are. Hope that helps.
06-13-2009, 11:02 AM | #8 | |
Rep 1,224
US Z4 3.0Si, 5/07 build, left hand drive: 02 Rmfd exhaust pipe with catalyt.converter ZYL. 1-6 18307562227 Euro Z4 3.0SI, 5/07 build, left hand drive: 01 Exhaust pipes with primary silencer 18107547103 Part 02 for US cars is identified as a catalyst and looks like what I have under my car. Part 01 for Euro spec cars is identified as a silencer and does not look like what I have under the car. I have been told that the US cars have the catalysts as part of the exhaust manifolds and the Euro cars do not. With that reasoning, the 02 part should be on the Euro cars and not the US cars. (If the parts diagram is correct for it's numbering/nomenclature.) To add to that, many here in the US have reported doing resonator deletes or "Cat back" systems without any problems with emissions testing. Being in Kalifornia, I haven't talked to anyone with an Si car who has done a delete/system and gone thorough the state's emissions test. Lastly, those inline twin cylinders on our cars sure resemble some of the aftermarket catalysts. Thanks again for the post, sooner or later I hope to track this down.
