      11-15-2012, 03:51 PM   #1
mike519
mike519's Avatar
Drives: 2018 M240i
Diff and other fluid recommendation s
OK, before I store the M for the winter, I want to replace the fluids. As I am new to the M, I could use your advice...
1) the diff will need the friction modifier as it has the rubbing noise. I am confused though...do I just need a fluid with FM included (like Redline) or do I still need to do that AND add an FM booster? Redline or OEM in either case??
2) for brake fluid, am I better to wait until spring in case of water build up over the winter from it sitting in the heated garage or is this a non issue? Royal Purple seems to be the most popular...what line exactly for street use with a couple of track days thrown in?
3) for tranny fluid...Redline?? What line of fluid?
4) for engine, I assume OEM
Since we're on the topic (and I know this should maybe be a Brake Forum question), if I am flushing the fluid anyway, should I replace the brake lines to stainless steel while I am at it?
Lastly, any recomendations for a decent priced pressurized flusher?
Thanks
      11-16-2012, 09:08 AM   #2
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
26
Drives: '08 M Coupe
You wont do anything wrong with upgrading to stainless steel, so why not.
For the oils, no idea, I have pretty much everything OEM and it's sitting the winter in garage.
