      06-18-2011, 12:53 PM   #1
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
07 Z4MR BMW Warranty Inspection 1 Complete....
Pleased w/the detail and expertise BMW Bellevue took w/my Red Roadster....
-The Red Roadster's mileage: 23,700
-4 Yr Warranty expires: Dec 2011
-Build date is Nov 06, so the 4.5 yr old battery was pro-actively replaced to prevent being stranded; replaced at my cost.
-RF inner fender trim (black plastic piece appx 1 ft below the headlight) was cracked; replaced at my cost.
-They honored my DO NOT WASH request
-Nice loaner....2011 328 four door w/6 speed auto and paddle shifters
Inspection 1 highpoints:
-Adjust valves (no adjustment required after checking w/engine cold)
-Four valve cover gaskets replaced
-Anyone know what / why this was replaced and what it is??
1 11-12-7-830-859 / Stud Bolt: 11109510
-Castrol synthetic oil change
-Oil filter
-Windsield washer antifreeze
-Cabin activated carbon microfilter
-Brake fluid flush
-New brake fluid
-Brake inspection
-M Mobilitiy Kit tire inflating bottle replaced (every 4 yrs)
....and all normal vehicle / undercarraige / engine compartment / body / electrical equipment items listed on the BMW Service Maintenance Checklist
Racerbruce
      06-18-2011, 01:07 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
did they give you the valve adjustment check sheet?
it should be included.
      06-18-2011, 01:38 PM   #3
jmillet
jmillet's Avatar
64
If they actually removed the valve cover to physically check the valves the work order should show these parts replaced:
Sealing rings, 6, 11-12-7-831-271
Cover gasket, 1, 11-12-7-832-034
Rubber grommets, 2, 11-12-1-437-395
Rubber grommets, 13, 11-12-7-830-972
Copper sealing rings, 2, 07-11-9-963-129
The stud bolt was replaced because they probably broke it off when tightening down the valve cover. If the grommets aren't replaced it's easy to over tighten the nuts as they are a contact torque against a sleeve inside the grommet.
As pointed out above they should have provided you with a record of the valve clearance measurements.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      06-19-2011, 10:20 AM   #4
racerbruce
racerbruce's Avatar
3854
Thanks Jim -
All gaskets are itemized on the report except Copper Sealing Rings last #'s 129. I didn't receive valve adjustment info - will pursue - thanks.
Racerbruce
      06-20-2011, 03:47 PM   #5
danlauz
Drives: z4m 2007+x5 2009+330 cic 2003
Did they replaced the m mobility kit free as the 4 years of the can was past ?
      06-24-2011, 01:59 PM   #6
racerbruce
racerbruce's Avatar
3854
Yes - free.
Racerbruce
