07-02-2009, 12:14 PM | #1 |
Rep 140
Gas tank wont go to full
I got the car from a relative 2 weeks ago and got gas twice at Chevron. Both times it only went up to 7/8ths full. This last time it put in 10 gallons when the level was between 1/8 and 1/4. Do - really have 7/8 or is the guage broken?
07-02-2009, 01:12 PM | #2 |
Free Thinker
16788
Rep 7,454
If your feet smell like gasoline and the gauge says it's not full, you need a new gauge.
07-02-2009, 01:14 PM | #3 |
(oO (||||) (||||) Oo)
Rep 165
LMFAO Good one M six :P
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red |
07-02-2009, 02:10 PM | #4 |
Rep 274
Drives: 2010 128i Conv.
Run a tank with Techron added. This cleans the fuel system including the sensor. Might take two tanks to clean the system adequately. This treatment is recommended by BMW every 3K miles.
I also recommend you use "Top Tier" gas which has a cleaner in it. BTW, Chevron is one of the Top Tier gases. I personally use Shell V-tech here in SC and my particular station also advertises no ethanol added. Check out this web site: http://www.toptiergas.com/index.html |
07-02-2009, 06:22 PM | #5 |
Rep 14
I had this same problem using Chevron in my car a couple times over the 1st year I had the car (occurred using 92 and 94 octane). Once, the gas gauge wouldn't go past 2/3 full, but the next day it started to slowly go up to full.
Then I switched to Shell V-power 91 octane and have never had this happen again. I read somewhere that something in the Chevron gas makes the sensor dirty and read wrong. |
07-04-2009, 09:16 AM | #6 |
Rep 822
There are two sensors one inside the tank and one outside the tank IIRC. I just fill the tank and go. I do not always get the indication of a full tank on mine 7/8 just like you. the 03-04 had issues with this. Most had a larger issue than I have only showing 1/2 of a tank. IMHO as long as it tells me when empty I am good to go.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
07-14-2009, 06:40 PM | #7 |
Rep 140
I went with Shell V-Power 91 Octane today. I had driven about 298 miles, the gauge was just under the 1/8th mark, and the low level light was on. I filled it with 11.8 gallons. The level only went up to 7/8ths again. Is the tank really at 7/8ths or is it full?
I recently had inspection 1 done and they were supposed to add techron additive, so I assume I don't need to do that again, do I? |
07-14-2009, 09:06 PM | #8 | |
Rep 274
07-14-2009, 09:20 PM | #9 | |
Rep 140
07-14-2009, 09:26 PM | #10 | |
Car Geek
3612
Rep 3,576
The tank is about 55 litres / 14.5 US gallons, so 10 gallons from between 1/8 and 1/4 full will probably only take it to 7/8. |
07-15-2009, 06:20 AM | #11 |
Rep 274
The technician training manual says the light comes on when fuel level drops to 8 liters which is about 2 gallons. Mine comes on at around the the 1/8 mark. That equates to about 2 gal based on a 14.5 gallon tank.
07-21-2009, 10:27 PM | #12 |
Rep 31
try resetting the battery, i had the same problem and i thought i had a faulty gauge or sender unit. i unhooked the ground from the battery, waitied 20 min and put it back, it worked correctly right after.
08-03-2009, 10:47 PM | #13 |
Rep 140
I filled up again and this time I pumped a little more gas after it clicked. It clicked again pretty quickly after. The gas gauge went between the 7/8th mark and full. So I assume the gauge is working? It always went to the 7/8th mark before and not over. Is there a way to make the nozzle not sense the tank is full prematurely? I tried pumping the gas at the slowest rate and with the nozzle not fully in. I used Shell again.
