08-13-2009, 12:15 PM | #23 |
Imola Lover
26
Rep 749
The problem with your logic here is that BMW Service Techs at even good dealers are generally lazy and since it takes a lot of work (pulling wheels off, dismantling covers, etc) to just check the bolts, they just won't do it. Even if they're told to. I've seen a number of reports (me included) where the owner requested that the bolts be checked, and even though the SA says the job was done, a few months later, the bolts end up broken/missing/loose/etc -- So obviously they were not, in fact, checked.
08-13-2009, 01:53 PM | #24 | |
BMW Fan
11
Rep 553
http://www.mcmaster.com/#90854a172/=368vky http://www.mcmaster.com/#90854a167/=368w9d and two packs of these: http://www.mcmaster.com/#91812a230/=368wzf |
08-13-2009, 02:10 PM | #25 | |
Rep 421
http://www.bimmerfest.com/forums/sho...d.php?t=384257 Screw 07 11 9 913 653 $0.47r Screw 07 11 9 913 673 $0.62r Washer 07 11 9 903 078 $0.35r |
08-13-2009, 04:54 PM | #26 | |
BMW Fan
11
Rep 553
I have noted that your posts are very knowledgeable and informative 100% of the time. You are truly an authoritative source of information. Regarding this particular situation, having been given bad parts by BMW once, I won't give them the opportunity again and will take my business elsewhere. It does appear that you can get those for less than $10 altogether, while McMaster-Carr sells the bolts only in lots of 25 and you will spend about $30 with them. So there's an opportunity to save $20. However, the Nord Lock washers from McMaster are pretty unique and add an additional safety margin against bolts loosening. |
08-13-2009, 05:57 PM | #27 | |
Rep 421
I didn't use them on the motor mount brackets since they didn't have the OD of the stock washer. |
08-13-2009, 06:02 PM | #28 |
Rep 421
