06-18-2014, 10:46 AM | #1 |
Rep 509
Brake ducts on stock 3.0si front
Bought some ordinary bassports and drilled some holes
Now I just need to get some black flexible tubes and carry on with the plumbing
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
06-18-2014, 11:17 AM | #2 |
Rep 12,565
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.20] |
Nice, I did this a while back. The plumbing is by far the hardest part. Be sure to post pictures after everything's done. What size hoses are you going to use?
06-18-2014, 03:11 PM | #3 |
Rep 509
I will.
The hose I got my hands on is 76mm in diameter. The cut out for the port was 73mm. Not the best fit but I will make it work. Will also install same ports in the inner wheel wells for best possible fitment and look
06-18-2014, 04:04 PM | #4 |
#dubspec
6327
Rep 5,200
Keep us posted. I used generic backing plates and made a custom clip to attach
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
06-19-2014, 12:55 AM | #5 |
Rep 509
Dubsesd: Do you have any picture of this backing plate?
I bougth this flexible hose. I will remove the shiny bling things and use the hose clamps for fastening to my black tubes.
06-26-2014, 08:08 AM | #6 |
Rep 12,565
I used the Bimmerworld backing plates, not cheap but it was far cheaper than the other bling CF options. Sturdy as heck, although I removed the hoses last season b/c they were rubbing on my 255's up front but I'm considering re-installing them because I'm going through my front pads so quickly.
It's a shame nobody makes a bolt-on backing plate that uses a 2.5 or 2.75" hose. 3" hose is really wide and will inevitably rub when you run a wide square fitment which is what most track folks do. I installed my "collectors" in the same area of the bumper as you did but I had a tough time reinstalling the bumper because the hoses were too rigid and would apply pressure in the opposite direction of the bumper. You can relieve some of the tension by installing the collectors further apart, near the fogs -- or at least that was the case with my install on the Aero bumper. I plan to remove fogs and collect air that way. Last edited by 3002 tii; 06-26-2014 at 08:26 AM.. |
06-29-2014, 11:19 AM | #7 |
Rep 509
Ok. Finished for this time. I'll get some backing plates later on. Dont have any time to get that before next track event.
