07-13-2013, 03:30 AM | #1 |
Rep 23
Any Z4 M coupe with polyurethane bushings all around?
Looking for E86 Z4M coupe or E46 M3 coupe owners who have replaced all suspension/subframe bushings with polyurethane or delrin solid upgrades.
I'm looking for reviews/observations from people that replaced all the bushings with polyurethane or solid and not just one or two spread out. -rear subframe bushings -differential mounts -rear trailing arm bushings (RTAB) -inner-upper rear control arm -sway bar Front+rear -Front control arm bushing (FCAB) These combined with a quality coilover kit would transform the car, but with how much added NVH. I've driven friends E46 M3's and have always felt that the ride was quite compliant (even with 19" wheels) and in need of firming up. Over a decade ago, I had an Acura RSX Type-S that I swapped out all the suspension bushings with hard compound polyurethane bushings. NVH was increased compared to stock, but definitely tolerable for everyday driving. I was mostly concerned with harshness but never got to play around with that since I didnt' want to mess around with different spring rates and such. Handling became much sharper and responsive. Steering is where I found the most benefit. Turn-in response was much improved along with feedback.Before, quick transient maneuvers like changing lanes felt lazy with delayed reaction. With polyurethane, reflexes were much quicker. The only drawback was the reduced ability to modulate anddampen transient undulations in road surface. At highway speeds, increased vibration was noticeable with all irregularites on the road felt. whereas before, small transient bumps in the road would be attenuated, now they were transmitted into the cabin felt at the steering wheel and seat. I found it quite tolerable, however, my mom would get carsick at times and considered the ride too harsh for street use. With the polyurethane bushings and new shocks in place, i'd be very curious to see how the Z4 M coupe stacks up to the Porsche Cayman S. Steering and shifting would become much more responsive and crisper. The Z4 M coupe already features the sharper steering rack from M3 CSL providing an excellent foundation. Had the M Division spent more time fine-tuning the suspension settings and calibration, this car could have been up there with the E30 M3 in the fun-to-drive department. |
07-13-2013, 07:52 PM | #2 |
Rep 11,667
I've done FCABs, RTABs, ARBs f&r
Very happy with the results, no noticable NVH difference. Re crisper shifting.... Trany bushings, Vibratech motor mounts & AS SSK are the answers there. They definitely tighten things up. A couple of weeks ago was the first track day on them & the car has never been better
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 07-13-2013 at 08:07 PM.. |
07-27-2013, 10:48 AM | #3 |
Rep 855
I second that on the transmission mounts and motor mounts.
One thing I noticed you said about comparing to the Cayman. Around a track the M Coupe is already directly comparable. In some ways it is better.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
09-29-2013, 06:56 AM | #5 |
Rep 11,667
MY FCABs are Superflex from UK.
http://www.superflex.co.uk/proddetai...od=SF095-2558K They were originally designed to provide different caster settings on the E46 M3, but work perfectly on our cars..
11-29-2013, 04:52 PM | #6 | |
Rep 3,004
The Superflex weblink for E46 will fit our Z4M? Did this help handling? Are they noisy? Presumably they fir the existing FCAB housing. Thanks! Racerbruce
Racerbruce
11-29-2013, 04:59 PM | #7 | |
Rep 11,667
The car felt great on my last track day! Installed pic
01-11-2016, 04:27 AM | #8 |
Rep 1,923
01-11-2016, 07:35 AM | #9 |
Rep 11,667
Not that I'm aware of.
The issue is finding a bush with the offset centre. Without the offset you lose caster.
01-11-2016, 11:38 AM | #10 |
Rep 1,923
01-11-2016, 12:55 PM | #11 |
10626
Rep 4,848
I've seen adjustable e46 lollypops with delrin inserts (or was it pillowball?) from some race supplier.
That's 100% firm and you can dial in the caster yourself. Loads of delrin offset bushings for the e30, z3 etc for sale, but I suspect that they are 60mm (but you can always ask various suppliers)
01-12-2016, 03:10 PM | #12 |
Rep 2,138
Drives: Me
01-12-2016, 03:55 PM | #13 |
Rep 11,667
They are the SuperFlex bush out of the UK
02-27-2016, 06:33 PM | #14 |
Rep 1,923
Just bought it! Do I need alignment again after?
